0.dts中配置1920x1080的分辨率 1.build.prop添加下面属性: persist.sys.framebuffer.main=1920x600@60 2.hardware/rockchip/hwcomposer合入下面修改: diff --git a/hwcomposer.cpp b/hwcomposer.cpp index 0fd2177..3ad13a9 100755 --- a/hwcomposer.cpp +++ b/hwcomposer.cpp @@ -3498,8 +3498,10 @@ static int hwc_get_display_configs(struct hwc_composer_device_1 *dev, char framebuffer_size[PROPERTY_VALUE_MAX]; uint32_t width = 0, height = 0 , vrefresh = 0 ; + if (display == HWC_DISPLAY_PRIMARY) property_get("persist.sys.framebuffer.main", framebuffer_size, "use_baseparameter"); - + else if(display == HWC_DISPLAY_EXTERNAL) + property_get("persist.sys.framebuffer.aux", framebuffer_size, "use_baseparameter"); /* * if unset framebuffer_size, get it from baseparameter , by libin */ @@ -2298,7 +2301,8 @@ static int hwc_prepare(hwc_composer_device_1_t *dev, size_t num_displays, hd->rel_yres = mode.v_display(); hd->v_total = mode.v_total(); hd->w_scale = (float)mode.h_display() / hd->framebuffer_width; - hd->h_scale = (float)mode.v_display() / hd->framebuffer_height; + //hd->h_scale = (float)mode.v_display() / hd->framebuffer_height; + hd->h_scale = 1.0; int fbSize = hd->framebuffer_width * hd->framebuffer_height; //get plane size for display std::vector @@ -3638,7 +3647,8 @@ static int hwc_set_active_config(struct hwc_composer_device_1 *dev, int display, return -ENOENT; } hd->w_scale = (float)mode.h_display() / hd->framebuffer_width; - hd->h_scale = (float)mode.v_display() / hd->framebuffer_height; + //hd->h_scale = (float)mode.v_display() / hd->framebuffer_height; + hd->h_scale = 1.0; c->set_current_mode(mode); ctx->drm.UpdateDisplayRoute(); |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
304 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4374 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1798 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2354 浏览 0 评论
2356 浏览 0 评论
/9
GMT+8, 2025-12-1 22:34 , Processed in 0.505796 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
894
