1个回答
一、最近碰到一个奇怪的问题,tc358749x碰到的问题还挺多,之前是打开一直黑屏,最后从硬件上解决了,现在又碰到了一个问题,HDMI+LVDS双屏显示,HDMIIN打开是黑屏的,表现形式跟之前的一样,会出现CamerIcIspIrq: pic err first,g_ispFrameNum == 1错误。只有单独打开HDMI通道HDMI IN才正常,一开始是怀疑LVDS的GPIO有服用,检查了好几遍,没发现问题有服用的GPIO口,测试几路电压也是正常的,问了芯片原厂,配合读出的寄存器也是正常的,做了好多实验,提高CPU、GPU、DDR频率,还是不行,最后发现是ISP_CLK频率驱动不足的原因所致,这里也要感谢原厂和芯片厂的大力支持。
修改点: rk3288kerneldriversmediavideork_camsyscamsys_marvin.c if (CHIP_TYPE == 3288) { //isp_clk = 420000000; //modiy by peng@ZY isp_clk = 550000000; camsys_trace(1, "%s isp_clk: 420Mhz; CHIP TYPE is %d", dev_name(camsys_dev->miscdev.this_device), CHIP_TYPE); } else { if (on == 1) isp_clk = 210000000; else //isp_clk = 420000000;/modiy by peng@ZY isp_clk = 550000000; } 二、HDMI uboot和kernel显示logo (1)rk3288u-bootincludeconfigsrk32plat.h 添加#define CONFIG_DRM_ROCKCHIP_DW_HDMI (2)dtsi route_hdmi: route-hdmi { status = "disabled"; logo,uboot = "logo.bmp"; logo,kernel = "logo_kernel.bmp"; logo,mode = "center"; charge_logo,mode = "center"; connect = <&vopb_out_hdmi>; }; (3)dts &route_hdmi { status = "okay"; }; 三、调试IR 硬件是连接到PWM0,PWM0系统默认是给了EDP/LVDS的背光,这里要先屏蔽掉LVDS上的背光PWM,(LVDS的背光硬件强制供电了,但是注意会有个问题,背光无法调节亮暗)将PWM0独立出来给IR用,dts配置:(注意usercode) &pwm0 { compatible = "rockchip,remotectl-pwm"; interrupts = remote_pwm_id = <0>; handle_cpu_id = <1>; status = "okay"; ir_key0 { rockchip,usercode = <0xffee>; rockchip,key_table = <0xa6 KEY_POWER>, <0xf2 KEY_HOME>, <0xfa KEY_BACK>, <0xba KEY_MENU>, <0xf9 KEY_UP>, <0xe9 KEY_DOWN>, <0xa5 KEY_LEFT>, <0xe4 KEY_RIGHT>, <0xe5 KEY_ENTER>, <0xec KEY_VOLUMEUP>, <0xe8 KEY_VOLUMEDOWN>, <0xe6 KEY_MUTE>, <0xed 388>, <0xad KEY_1>, <0xaf KEY_2>, <0xef KEY_3>, <0xa9 KEY_4>, <0xab KEY_5>, <0xeb KEY_6>, <0xb1 KEY_7>, <0xb3 KEY_8>, <0xf3 KEY_9>, <0xf0 KEY_0>, <0xae KEY_BACKSPACE>, <0xde KEY_SEARCH>; }; }; 编译烧录,打开debug echo 1 > /sys/module/rockchip_pwm_remotectl/parameters/code_print 触发遥控器按键,发现没信息出来,用示波器测量IR的PWM,按按键有波形,定位是系统没配置好。修改dits: pwm0: pwm@ff680000 { compatible = "rockchip,rk3288-pwm"; reg = <0x0 0xff680000 0x0 0x10>; #pwm-cells = <3>; pinctrl-names = "active"; //将activice改为default pinctrl-0 = <&pwm0_pin>; clocks = <&cru PCLK_PWM>; clock-names = "pwm"; status = "disabled"; }; 烧录查看键值正常。 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 04:04 , Processed in 0.600500 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7830
