电子发烧友论坛|
软件:本地服务器中的项目是使用JAVA,框架Springboot+Mybatis,数据库Mysql,在项目中开放一个可以直接向数据库存储数据的接口来接收arduino发出的请求。
硬件:Arduino UNO开发板,DHT11传感器+Ethernet W5100拓展板,将arduino中读出的数据以带参数的http请求的方式发送给本地服务器,其他传感器实现方式几乎相同,在此以DHT11温湿度传感器为例来进行阐述。 TP-LINK路由器+网线若干,尽量不要使用交换机,交换机无法自动分配IP并且兼容性一般比较差,造成无法设置静态IP,要使用带有DHCP功能的路由器,一些兼容性差的路由器会出现无法识别Arduino W5100的情况,造成无法自动分配IP地址,尽量选用兼容性较好的TP系列路由器(非广告,厚脸皮在省科技市场尝试了无数交换机和路由器血的教训) Springboot的application.yml配置文件: server: port: 8085 context-path: /arduino jsp-servlet: init-parameters: development: true spring: datasource: type: com.alibaba.druid.pool.DruidDataSource url: jdbc:mysql://localhost:3306/arduino driver-class-name: com.mysql.jdbc.Driver username: root password: cja mybatis: type-aliases-package: com.arduino.entity mapper-locations: classpath:edu/zzu/mapper/*Mapper.xml JAVA项目中开放的接口地址为:http://localhost:8085/arduino/data/set?tem=XXX 本地服务器IP地址为:192.168.1.129 Arduino的IP地址由路由器自动分配,使用路由器无需设置,但写上也无妨。 Arduino程序如下: /* Web client This sketch connects to a website (http://www.google.com) using an Arduino Wiznet Ethernet shield. Circuit: * Ethernet shield attached to pins 10, 11, 12, 13 created 18 Dec 2009 by David A. Mellis modified 9 Apr 2012 by Tom Igoe, based on work by Adrian McEwen */ #include 《SPI.h》 #include 《Ethernet.h》 #include《dht11.h》 dht11 DHT11; #define DHT11PIN 2 // Enter a MAC address for your controller below. // Newer Ethernet shields have a MAC address printed on a sticker on the shield byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; // if you don‘t want to use DNS (and reduce your sketch size) // use the numeric IP instead of the name for the server: //IPAddress server(74,125,232,128); // numeric IP for Google (no DNS) char server[] = “192.168.1.129”; // name address for Google (using DNS) // Set the static IP address to use if the DHCP fails to assign IPAddress ip(192, 168, 1, 102); IPAddress myDns(192, 168, 1, 1); // Initialize the Ethernet client library // with the IP address and port of the server // that you want to connect to (port 80 is default for HTTP): EthernetClient client; // Variables to measure the speed unsigned long beginMicros, endMicros; unsigned long byteCount = 0; bool printWebData = true; // set to false for better speed measurement void setup() { // You can use Ethernet.init(pin) to configure the CS pin //Ethernet.init(10); // Most Arduino shields //Ethernet.init(5); // MKR ETH shield //Ethernet.init(0); // Teensy 2.0 //Ethernet.init(20); // Teensy++ 2.0 //Ethernet.init(15); // ESP8266 with Adafruit Featherwing Ethernet //Ethernet.init(33); // ESP32 with Adafruit Featherwing Ethernet // Open serial communications and wait for port to open: Serial.begin(9600); while (!Serial) { ; // wait for serial port to connect. Needed for native USB port only } int chk =DHT11.read(DHT11PIN); // start the Ethernet connection: Serial.println(“Initialize Ethernet with DHCP:”); if (Ethernet.begin(mac) == 0) { Serial.println(“Failed to configure Ethernet using DHCP”); // Check for Ethernet hardware present if (Ethernet.hardwareStatus() == EthernetNoHardware) { Serial.println(“Ethernet shield was not found. Sorry, can’t run without hardware. :(”); while (true) { delay(1); // do nothing, no point running without Ethernet hardware } } if (Ethernet.linkStatus() == LinkOFF) { Serial.println(“Ethernet cable is not connected.”); } // try to congifure using IP address instead of DHCP: Ethernet.begin(mac, ip); } else { Serial.print(“ DHCP assigned IP ”); Serial.println(Ethernet.localIP()); } // give the Ethernet shield a second to initialize: delay(1000); Serial.print(“connecting to ”); Serial.print(server); Serial.println(“。。。”); // if you get a connection, report back via serial: if (client.connect(server, 8085)) { Serial.print(“connected to ”); Serial.println(client.remoteIP()); // Make a HTTP request: //char* pre = ‘GET /arduino/data/set?tem=’; //char* data = DHT11.temperature; //char* posta = “ HTTP/1.1”; //char *result = (char*)malloc(strlen(pre)+strlen(data)+strlen(posta)+1); //strcpy(result,pre); //strcpy(result,data); //strcpy(result,posta); //client.println(result); //Serial.println(*result); client.println(“GET /arduino/data/set?tem=”+String(DHT11.temperature)+“ HTTP/1.1”); client.println(“Host: 192.168.1.129”); client.println(“Connection: close”); client.println(); } else { // if you didn‘t get a connection to the server: Serial.println(“connection failed”); } beginMicros = micros(); } void loop() { // if there are incoming bytes available // from the server, read them and print them: int len = client.available(); if (len 》 0) { byte buffer[80]; if (len 》 80) len = 80; client.read(buffer, len); if (printWebData) { Serial.write(buffer, len); // show in the serial monitor (slows some boards) } byteCount = byteCount + len; } // if the server’s disconnected, stop the client: if (!client.connected()) { endMicros = micros(); Serial.println(); Serial.println(“disconnecting.”); client.stop(); Serial.print(“Received ”); Serial.print(byteCount); Serial.print(“ bytes in ”); float seconds = (float)(endMicros - beginMicros) / 1000000.0; Serial.print(seconds, 4); float rate = (float)byteCount / seconds / 1000.0; Serial.print(“, rate = ”); Serial.print(rate); Serial.print(“ kbytes/second”); Serial.println(); // do nothing forevermore: while (true) { delay(1); } } } 使用此段代码可以将DHT11传感器读取到的数据通过http请求的方式发送至后端服务器,由服务器将将数据进行持久化后,通过前端的Ajax异步请求并集成ECharts数据可视化工具来完成数据的折线图等统计图展示和实时更新。 |
只有小组成员才能发言,加入小组>>
1599 浏览 0 评论
imx6ull 和 lan8742 工作起来不正常, ping 老是丢包
4738 浏览 0 评论
4229 浏览 9 评论
3822 浏览 16 评论
4398 浏览 1 评论
4211浏览 3评论
2380浏览 0评论
3394浏览 0评论
1158浏览 0评论
2843浏览 0评论
/9
GMT+8, 2025-12-2 07:01 , Processed in 0.496539 second(s), Total 46, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
616
