电子发烧友论坛|
1)quartus ii编译成功后不产生.pof文件(用于AS模式的下载);
在assignments >>device>>device and pin option>>configuration >>勾上Use Configuration device,配置芯片(我的是epcs4)。 选择configuration scheme为Active Serial 即可 spi.h #ifndef __SPI_H #define __SPI_H #include "stm32l0xx.h" #ifdef SPI_GLOBALS #define SPI_EXT #else #define SPI_EXT extern #endif #define M_CS_H HAL_GPIO_WritePin(GPIOA, GPIO_PIN_3, GPIO_PIN_SET) #define M_CS_L HAL_GPIO_WritePin(GPIOA, GPIO_PIN_3, GPIO_PIN_RESET) #define S_CS_H HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, GPIO_PIN_SET) #define S_CS_L HAL_GPIO_WritePin(GPIOA, GPIO_PIN_4, GPIO_PIN_RESET) #define SCLK_H HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_SET) #define SCLK_L HAL_GPIO_WritePin(GPIOA, GPIO_PIN_5, GPIO_PIN_RESET) #define MOSI_H HAL_GPIO_WritePin(GPIOA, GPIO_PIN_6, GPIO_PIN_SET) #define MOSI_L HAL_GPIO_WritePin(GPIOA, GPIO_PIN_6, GPIO_PIN_RESET) #define MISO HAL_GPIO_ReadPin(GPIOA, GPIO_PIN_7) SPI_EXT uint32_t spi_send_byte32(uint32_t data); SPI_EXT uint32_t spi_send_bytes32(uint32_t *buf,uint16_t len); SPI_EXT uint32_t spi_read_bytes32(uint32_t *buf,uint16_t len); #endif **描 述 : STM32平台gpio模拟SPI通信实现 ** ********************************************************************************************************/ #define SPI_GLOBALS #include "string.h" #include "spi.h" /******************************************************************************* * 函数名称: uint32_t spi_send_byte32(uint32_t data) * 函数功能: 发送一个32位字 * 函数说明: gpio模拟spi * 输入参数: data 待发送字 * 输出参数: * 返回值 : 接收一个32位字 *******************************************************************************/ uint32_t spi_send_byte32(uint32_t data) { uint8_t i = 0; uint32_t temp=0x00000000; for(i=32;i>0;i--){ if(data&0x80000000){ //if((data&0x80000000) == 0x80000000){undefined GPIOA->BSRR = GPIO_PIN_6;//MOSI_H;//写1 }else{undefined GPIOA->BRR = GPIO_PIN_6;//MOSI_L;//写0 } data<<=1;//高位在前 GPIOA->BSRR = GPIO_PIN_5;//SCLK_H;//sck高 temp<<=1; if(MISO ==1){undefined temp++;//读到1 } GPIOA->BRR = GPIO_PIN_5;//SCLK_L;//sck低 } return temp; } /******************************************************************************* * 函数名称: uint32_t spi_send_bytes32(uint32_t *buf,uint16_t len) * 函数功能: 发送多个32位字 * 函数说明: gpio模拟spi * 输入参数: * 输出参数: * 返回值 : *******************************************************************************/ uint32_t spi_send_bytes32(uint32_t *buf,uint16_t len) {undefined uint16_t i; for(i=0;i } return 0; } /******************************************************************************* * 函数名称: uint32_t spi_read_byte32(void) * 函数功能: 读一个32位字 * 函数说明: gpio模拟spi * 输入参数: * 输出参数: * 返回值 : *******************************************************************************/ uint32_t spi_read_byte32(void) {undefined return spi_send_byte32(0); } /******************************************************************************* * 函数名称: uint32_t spi_read_bytes32(void) * 函数功能: 读多个32位字 * 函数说明: gpio模拟spi * 输入参数: * 输出参数: * 返回值 : *******************************************************************************/ uint32_t spi_read_bytes32(uint32_t *buf,uint16_t len) {undefined uint16_t i; for(i=0;i } return 0; } 1)宏定义解决GPIO_PIN_5,6,7等名字差别问题 #define GPIO_PIN_3 GPIO_Pin_3 #define GPIO_PIN_4 GPIO_Pin_4 #define GPIO_PIN_5 GPIO_Pin_5 #define GPIO_PIN_6 GPIO_Pin_6 #define GPIO_PIN_7 GPIO_Pin_7 #define HAL_GPIO_ReadPin GPIO_ReadInputDataBit #define HAL_GPIO_WritePin GPIO_WriteBit #define GPIO_PIN_SET Bit_SET #define GPIO_PIN_RESET Bit_RESET 3) 需要在主函数初始化PA5,6,7引脚(CS视情况初始化) /*定义一个GPIO_InitTypeDef类型的结构体*/ GPIO_InitTypeDef GPIO_InitStructure; /*开启LED相关的GPIO外设时钟*/ RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); /*设置引脚模式为通用推挽输出*/ GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; /*设置引脚速率为50MHz */ GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; GPIO_Init(GPIOA, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; GPIO_Init(GPIOA, &GPIO_InitStructure); 4)SPI发送单个u32时产生SCK不理想,加入2ms延时 uint32_t spi_send_byte32(uint32_t data) { uint8_t i = 0; uint32_t temp=0x00000000; for(i=32;i>0;i--){ if(data&0x80000000){ //if((data&0x80000000) == 0x80000000){undefined GPIOA->BSRR = GPIO_PIN_6;//MOSI_H;//写1 }else{undefined GPIOA->BRR = GPIO_PIN_6;//MOSI_L;//写0 } data<<=1;//高位在前 GPIOA->BSRR = GPIO_PIN_5;//SCLK_H;//sck高 temp<<=1; if(MISO ==1){undefined temp++;//读到1 } delay_ms(2); GPIOA->BRR = GPIO_PIN_5;//SCLK_L;//sck低 delay_ms(2); } return temp; } 5)波形基本正确,但单片机读不到,待解决。 |
只有小组成员才能发言,加入小组>>
1986 浏览 0 评论
imx6ull 和 lan8742 工作起来不正常, ping 老是丢包
4787 浏览 0 评论
4266 浏览 9 评论
3855 浏览 16 评论
4429 浏览 1 评论
4257浏览 3评论
2415浏览 0评论
3433浏览 0评论
1198浏览 0评论
2886浏览 0评论
/9
GMT+8, 2025-12-12 16:32 , Processed in 0.611746 second(s), Total 45, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1675
