电子发烧友论坛|
1个回答
串口(中断设置)
1.中断 1.中断优先级分组 [tr]中断优先级分组BIN抢占优先级响应优先级[/tr]
SCB->AIRCR |=1<<8;//[10:8] SCB->AIRCR |=1<<10;//101 2组 2位抢 2位响 2.中断初始化 Nvic init() NVIC->IP[37]=5<<4;//0101 0000 NVIC->ISER[1]|=1<<5; //37位=1使能 NVIC->ISER 使能 ISER[0]的 bit0~31 分别对应中断 0~31 ISER[1]的 bit0~32 对应中断 32~63 ISER[2]的 bit0~3 对应中断 64~67 (使能某个中断,必须设置相应的 ISER 位为 1) NVIC->IP[] 中断优先级控制的寄存器组 IP[67]~IP[0]分别对应中断 67~0。 每个可屏蔽中断占用 8bit,每个8bit只用了高 4 位 对应的中断号: WWDG_IRQn = 0, /*!< Window WatchDog Interrupt */ PVD_IRQn = 1, /*!< PVD through EXTI Line detection Interrupt */ TAMPER_IRQn = 2, /*!< Tamper Interrupt */ RTC_IRQn = 3, /*!< RTC global Interrupt */ FLASH_IRQn = 4, /*!< FLASH global Interrupt */ RCC_IRQn = 5, /*!< RCC global Interrupt */ EXTI0_IRQn = 6, /*!< EXTI Line0 Interrupt */ EXTI1_IRQn = 7, /*!< EXTI Line1 Interrupt */ EXTI2_IRQn = 8, /*!< EXTI Line2 Interrupt */ EXTI3_IRQn = 9, /*!< EXTI Line3 Interrupt */ EXTI4_IRQn = 10, /*!< EXTI Line4 Interrupt */ DMA1_Channel1_IRQn = 11, /*!< DMA1 Channel 1 global Interrupt */ DMA1_Channel2_IRQn = 12, /*!< DMA1 Channel 2 global Interrupt */ DMA1_Channel3_IRQn = 13, /*!< DMA1 Channel 3 global Interrupt */ DMA1_Channel4_IRQn = 14, /*!< DMA1 Channel 4 global Interrupt */ DMA1_Channel5_IRQn = 15, /*!< DMA1 Channel 5 global Interrupt */ DMA1_Channel6_IRQn = 16, /*!< DMA1 Channel 6 global Interrupt */ DMA1_Channel7_IRQn = 17, /*!< DMA1 Channel 7 global Interrupt */ ADC1_2_IRQn = 18, /*!< ADC1 and ADC2 global Interrupt */ USB_HP_CAN1_TX_IRQn = 19, /*!< USB Device High Priority or CAN1 TX Interrupts */ USB_LP_CAN1_RX0_IRQn = 20, /*!< USB Device Low Priority or CAN1 RX0 Interrupts */ CAN1_RX1_IRQn = 21, /*!< CAN1 RX1 Interrupt */ CAN1_SCE_IRQn = 22, /*!< CAN1 SCE Interrupt */ EXTI9_5_IRQn = 23, /*!< External Line[9:5] Interrupts */ TIM1_BRK_IRQn = 24, /*!< TIM1 Break Interrupt */ TIM1_UP_IRQn = 25, /*!< TIM1 Update Interrupt */ TIM1_TRG_COM_IRQn = 26, /*!< TIM1 Trigger and Commutation Interrupt */ TIM1_CC_IRQn = 27, /*!< TIM1 Capture Compare Interrupt */ TIM2_IRQn = 28, /*!< TIM2 global Interrupt */ TIM3_IRQn = 29, /*!< TIM3 global Interrupt */ TIM4_IRQn = 30, /*!< TIM4 global Interrupt */ I2C1_EV_IRQn = 31, /*!< I2C1 Event Interrupt */ I2C1_ER_IRQn = 32, /*!< I2C1 Error Interrupt */ I2C2_EV_IRQn = 33, /*!< I2C2 Event Interrupt */ I2C2_ER_IRQn = 34, /*!< I2C2 Error Interrupt */ SPI1_IRQn = 35, /*!< SPI1 global Interrupt */ SPI2_IRQn = 36, /*!< SPI2 global Interrupt */ USART1_IRQn = 37, /*!< USART1 global Interrupt */ USART2_IRQn = 38, /*!< USART2 global Interrupt */ USART3_IRQn = 39, /*!< USART3 global Interrupt */ EXTI15_10_IRQn = 40, /*!< External Line[15:10] Interrupts */ RTCAlarm_IRQn = 41, /*!< RTC Alarm through EXTI Line Interrupt */ USBWakeUp_IRQn = 42, /*!< USB Device WakeUp from suspend through EXTI Line Interrupt */ TIM8_BRK_IRQn = 43, /*!< TIM8 Break Interrupt */ TIM8_UP_IRQn = 44, /*!< TIM8 Update Interrupt */ TIM8_TRG_COM_IRQn = 45, /*!< TIM8 Trigger and Commutation Interrupt */ TIM8_CC_IRQn = 46, /*!< TIM8 Capture Compare Interrupt */ ADC3_IRQn = 47, /*!< ADC3 global Interrupt */ FSMC_IRQn = 48, /*!< FSMC global Interrupt */ SDIO_IRQn = 49, /*!< SDIO global Interrupt */ TIM5_IRQn = 50, /*!< TIM5 global Interrupt */ SPI3_IRQn = 51, /*!< SPI3 global Interrupt */ UART4_IRQn = 52, /*!< UART4 global Interrupt */ UART5_IRQn = 53, /*!< UART5 global Interrupt */ TIM6_IRQn = 54, /*!< TIM6 global Interrupt */ TIM7_IRQn = 55, /*!< TIM7 global Interrupt */ DMA2_Channel1_IRQn = 56, /*!< DMA2 Channel 1 global Interrupt */ DMA2_Channel2_IRQn = 57, /*!< DMA2 Channel 2 global Interrupt */ DMA2_Channel3_IRQn = 58, /*!< DMA2 Channel 3 global Interrupt */ DMA2_Channel4_5_IRQn = 59 /*!< DMA2 Channel 4 and Channel 5 global Interrupt */ 2.串口 (相关基础知识见正点原子) 除了串口 1 的时钟使能在 APB2ENR 寄存器,其他串口的 时钟使能位都在 APB1ENR 寄存器。 1.串口时钟使能 APB2ENR APB1ENR 除了串口 1 的时钟使能在 APB2ENR 寄存器 14口,其他串口的 时钟使能位都在 APB1ENR 寄存器。 RCC->APB2ENR|=1<<2; //使能PORTA口时钟 RCC->APB2ENR|=1<<14; //使能串口时钟 IO口设置: GPIOA->CRH&=0XFFFFF00F;//IO状态设置 GPIOA->CRH|=0X000008B0;//IO状态设置 2.串口复位 : APB2RSTR 寄存器 一般在系统刚开始配置外设的时候,都会先执行复位该外设的操作 RCC->APB2RSTR|=1<<14; //复位串口1 RCC->APB2RSTR&=~(1<<14);//停止复位 3,串口波特率设置 USART_BRR USART1->BRR=0x0271; // 波特率设置 115200 4.串口控制 USART_CR1~3 USART1->CR1|=0X202C; //发送接收使能 接收缓冲区非空使能 USART使能 5.数据发送与接收 USART_DR 6.串口状态 USART_SR RXNE(读数据寄存器非空 TC(发送完成) 中断函数 void USART1_IRQHandler(void) { u8 res; if(USART_GetITStatus(USART1,USART_IT_RXNE))//读数据寄存器非空 { res= USART_ReceiveData(USART1);//接收数据 USART_SendData(USART1,res); //发送 } } |
只有小组成员才能发言,加入小组>>
1599 浏览 0 评论
imx6ull 和 lan8742 工作起来不正常, ping 老是丢包
4738 浏览 0 评论
4229 浏览 9 评论
3822 浏览 16 评论
4398 浏览 1 评论
4210浏览 3评论
2379浏览 0评论
3393浏览 0评论
1158浏览 0评论
2843浏览 0评论
/9
GMT+8, 2025-12-1 22:57 , Processed in 0.621174 second(s), Total 44, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3021
