电子发烧友论坛扫一扫,分享给好友
由于ESP8266本身的定位就是低成本的联网方案,所以它的性能不会太高,不适合做太复杂的事情。
后来,安信可又推出了非常2款WIFI/蓝牙模块ESP3,它可以说是ESP8266的增强版。除了增加了4.2之外,还增加了丰富的外设,如:ADC、SPI、IIIC、IIS、SDIO、UART 、红外传感器、RSA、带宽、带宽、AES、AES、PID、DAC、传感器传感器、低同步发射、温度传感器等。CPU频率高达240MHz,但,价格也不高。 STM32也推出了一款类似的芯片,就是STM32WB系列,也就是STM32增加了蓝牙5,的OpenThread,紫蜂3.0等功能。 TI也有类似的芯片CC2652R,集成了48MHz的主频的ARM M4F内核,支持蓝牙设备,可以在淘宝上比较贵的, 线程,ZigB开发者,平均价格优势和价格优势 三,解析代码 需要修改的信息有WIF名称,WIFI密码,邮箱地址,秘钥信息。 #include #include "esp_camera.h" #include #include #include #include "ESP32_MailClient.h" /*********************需要修改的地方**********************/ const char* ssid = "mywifi"; //WIFI名称 const char* password = "qweqwe123"; //WIFI密码 /********************************************************/ bool internet_connected = false; long current_millis; long last_capture_millis = 0; // CAMERA_MODEL_AI_THINKER #define PWDN_GPIO_NUM 32 #define RESET_GPIO_NUM -1 #define XCLK_GPIO_NUM 0 #define SIOD_GPIO_NUM 26 #define SIOC_GPIO_NUM 27 #define Y9_GPIO_NUM 35 #define Y8_GPIO_NUM 34 #define Y7_GPIO_NUM 39 #define Y6_GPIO_NUM 36 #define Y5_GPIO_NUM 21 #define Y4_GPIO_NUM 19 #define Y3_GPIO_NUM 18 #define Y2_GPIO_NUM 5 #define VSYNC_GPIO_NUM 25 #define HREF_GPIO_NUM 23 #define PCLK_GPIO_NUM 22 SMTPData smtpData; //void sendCallback(SendStatus info); void setup() { Serial.begin(115200); if (init_wifi()) { // Connected to WiFi internet_connected = true; Serial.println("Internet connected"); } camera_config_t config; config.ledc_channel = LEDC_CHANNEL_0; config.ledc_timer = LEDC_TIMER_0; config.pin_d0 = Y2_GPIO_NUM; config.pin_d1 = Y3_GPIO_NUM; config.pin_d2 = Y4_GPIO_NUM; config.pin_d3 = Y5_GPIO_NUM; config.pin_d4 = Y6_GPIO_NUM; config.pin_d5 = Y7_GPIO_NUM; config.pin_d6 = Y8_GPIO_NUM; config.pin_d7 = Y9_GPIO_NUM; config.pin_xclk = XCLK_GPIO_NUM; config.pin_pclk = PCLK_GPIO_NUM; config.pin_vsync = VSYNC_GPIO_NUM; config.pin_href = HREF_GPIO_NUM; config.pin_sscb_sda = SIOD_GPIO_NUM; config.pin_sscb_scl = SIOC_GPIO_NUM; config.pin_pwdn = PWDN_GPIO_NUM; config.pin_reset = RESET_GPIO_NUM; config.xclk_freq_hz = 20000000; config.pixel_format = PIXFORMAT_JPEG; //init with high specs to pre-allocate larger buffers if (psramFound()) { config.frame_size = FRAMESIZE_UXGA; config.jpeg_quality = 10; config.fb_count = 2; } else { config.frame_size = FRAMESIZE_SVGA; config.jpeg_quality = 12; config.fb_count = 1; } // camera init esp_err_t err = esp_camera_init(&config); if (err != ESP_OK) { Serial.printf("Camera init failed with error 0x%x", err); return; } } /********初始化WIFI*********/ bool init_wifi() { int connAttempts = 0; Serial.println("rnConnecting to: " + String(ssid)); WiFi.begin(ssid, password); WiFi.setAutoReconnect(true); while (WiFi.status() != WL_CONNECTED ) { delay(500); Serial.print("."); if (connAttempts > 10) return false; connAttempts++; } return true; } static esp_err_t sendMail2m() { //初始化相机并拍照 Serial.println("Taking picture..."); camera_fb_t * fb = NULL; fb = esp_camera_fb_get(); if (!fb) { Serial.println("Camera capture failed"); return ESP_FAIL; } Serial.println("Sending email..."); smtpData.setLogin("smtp.163.com", 994, "****@163.com", "****"); smtpData.setSender("ESP32", "***@163.com"); smtpData.setPriority("High"); smtpData.setSubject("ESP32CAM Photo Mail"); smtpData.setMessage("Hello pic!", true); smtpData.addRecipient("****@163.com"); smtpData.addAttachData("firebase_logo.jpg", "image/jpg", (uint8_t *)fb->buf, fb->len); //从内存中 smtpData.setSendCallback(sendCallback); if (!MailClient.sendMail(smtpData)){ Serial.println("Error sending Email, " + MailClient.smtpErrorReason()); esp_restart() ; } smtpData.empty(); //清空数据 esp_camera_fb_return(fb); } void loop() { //定时发送 //当前时间减去上次时间大于20S就执行拍照上传函数 delay(1000*20); sendMail2m(); //拍照上传函数,在需要的地方调用即可,这里是定时拍照 } void sendCallback(SendStatus msg) { Serial.println(msg.info()); if (msg.success()) { Serial.println("----------------"); } } 四、效果 展示1个邮箱收件箱 2个邮件附件查看 四、测试总结 20秒上传一次,可更改(本项目是自动上传,如需条件触发上传,在默认需要上传的时间,调用sendMail2m()即可) 目前没有实现自动配网,下个版本继续补充功能。 |
只有小组成员才能发言,加入小组>>
1599 浏览 0 评论
imx6ull 和 lan8742 工作起来不正常, ping 老是丢包
4738 浏览 0 评论
4229 浏览 9 评论
3822 浏览 16 评论
4398 浏览 1 评论
4210浏览 3评论
2379浏览 0评论
3393浏览 0评论
1158浏览 0评论
2843浏览 0评论
/9
GMT+8, 2025-12-2 02:52 , Processed in 0.798302 second(s), Total 74, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2431
