电子发烧友论坛|
1个回答
功能概述
利用超声波模块测量距离并显示在数码管的后三位,单位是cm。如果距离超出量程,就在第一位显示‘F’ #include "stc15f2k60s2.h" /* Debug 总结: */ ***it TX = P1^0; // 发射引脚 ***it RX = P1^1; // 接收引脚 unsigned char code SMG_duanma[] = {0xc0,0xf9,0xa4,0xb0, 0x99,0x92,0x82,0xf8, 0x80,0x90,0x88,0x83, 0xc6,0xa1,0x86,0x8e, 0xbf,0x7f }; unsigned char Segbuff[] = {0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff}; unsigned int distance = 0; bit flag = 0; void SelectHC573(unsigned char channel) { switch(channel) { case 0 : P2 = (P2 & 0X1F) | 0X00;break; case 4 : P2 = (P2 & 0X1F) | 0X80;break; case 5 : P2 = (P2 & 0X1F) | 0Xa0;break; case 6 : P2 = (P2 & 0X1F) | 0Xc0;break; case 7 : P2 = (P2 & 0X1F) | 0Xe0;break; } } void InitSystem() { SelectHC573(5); P0 = 0x00; SelectHC573(4); P0 = 0xFF; SelectHC573(0); } void DispalySMG_Bit(unsigned char pos, unsigned char dat) { /**********消隐效果最佳******************/ SelectHC573(7); P0 = 0xff;//关闭所有段选 SelectHC573(6); P0 = 0x01 << pos; SelectHC573(0); P0 = 0xff; SelectHC573(7); P0 = dat; SelectHC573(0); /**********消隐效果最佳******************/ } void Timer1_Init() { TMOD = 0X00; TH1 = (65536 - 1000) / 256; TL1 = (65536 - 1000) % 256; EA = 1; ET1 = 1; TR1 = 1; } void Measure_Distance() { unsigned char num = 10;//??个方波信号 unsigned int time = 0; TMOD &= 0xf0; //方波信号的频率要在38-40khz,所以用定时器0制造一个周期为26us的占空比为50%的方波信号 TH0 = (65536 - 13) / 256; TL0 = (65536 - 13) % 256; TR0 = 1; TX = 0; while(num--)//连续发送8个波 { while(TF0 == 0); TX = ~TX; TF0 = 0; }//花费大约208us TR0 = 0;//发送完信号立即关闭定时器 TL0 = 0; // 设置定时初值 TH0 = 0; // 设置定时初值 TR0 = 1; while((RX == 1) && (TF0 == 0)); //等待超声波信号返回或者等到测量超出范围 TR0 = 0; //停止定时器 //**************最好严格按照这种if else 的格式写,否则容易出bug************ if(TF0 == 0) //正常测量范围 { time = TH0; time = (time << 8) | TL0; distance = time*0.017;//单位是cm,计算方法是:【(time/1000000)*340】/2*100 } else //超出测量范围 { TF0 = 0; distance = 9999; } //**************最好严格按照这种if else 的格式写,否则容易出bug************ } void Display_Distance() { if(distance == 9999) { Segbuff[0] = SMG_duanma[15]; //超出测量范围标志:F Segbuff[1] = 0xff; Segbuff[2] = 0xff; Segbuff[3] = 0xff; Segbuff[4] = 0xff; Segbuff[5] = 0xff; Segbuff[6] = 0xff; Segbuff[7] = 0xff; } else { Segbuff[0] = 0xff; Segbuff[1] = 0xff; Segbuff[2] = 0xff; Segbuff[3] = 0xff; Segbuff[4] = 0xff; Segbuff[5] = SMG_duanma[distance / 100]; Segbuff[6] = SMG_duanma[(distance % 100) / 10]; Segbuff[7] = SMG_duanma[distance % 10]; } } void main() { InitSystem(); Timer1_Init(); while(1) { if(flag)//间隔200ms测量一次数据 { Measure_Distance(); flag = 0; } Display_Distance(); } } void Timer1_Service() interrupt 3 { static unsigned char pos = 0; static unsigned char t_1ms = 0; t_1ms++; switch(pos) { case 0 : DispalySMG_Bit(pos, Segbuff[0]);pos++;P0 = 0XFF;break; case 1 : DispalySMG_Bit(pos, Segbuff[1]);pos++;P0 = 0XFF;break; case 2 : DispalySMG_Bit(pos, Segbuff[2]);pos++;P0 = 0XFF;break; case 3 : DispalySMG_Bit(pos, Segbuff[3]);pos++;P0 = 0XFF;break; case 4 : DispalySMG_Bit(pos, Segbuff[4]);pos++;P0 = 0XFF;break; case 5 : DispalySMG_Bit(pos, Segbuff[5]);pos++;P0 = 0XFF;break; case 6 : DispalySMG_Bit(pos, Segbuff[6]);pos++;P0 = 0XFF;break; case 7 : DispalySMG_Bit(pos, Segbuff[7]);pos = 0;P0 = 0XFF;break; } if(t_1ms == 200) {flag = 1;t_1ms = 0;} } 相关知识点 使用超声波模块之前记得要短接1、3和短接2、4 注意:一定要间隔一段时间再测量距离,本例程中间隔了200ms。如果在while循环里不断地使用测量函数的话,会造成数码管显示在一直跳变。 原因是,上一次的数据刚测量完成,还没来得及显示稳定,又立马执行了Measure_Distance()函数,数值又发生了变化,这样就会表现在数码管在不同测量值之间快速的跳变,你根本看不出结果是多少。 |
只有小组成员才能发言,加入小组>>
1634 浏览 0 评论
imx6ull 和 lan8742 工作起来不正常, ping 老是丢包
4741 浏览 0 评论
4231 浏览 9 评论
3824 浏览 16 评论
4400 浏览 1 评论
4213浏览 3评论
2381浏览 0评论
3394浏览 0评论
1159浏览 0评论
2844浏览 0评论
/9
GMT+8, 2025-12-2 12:46 , Processed in 0.465166 second(s), Total 46, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2076
