TCP 服务器模式
void ICACHE_FLASH_ATTR Wifi_conned(void *arg){ static uint8 count=0; struct ip_info info; //用于获取IP地址的信息 uint8 status; os_timer_disarm(&connect_timer); count++; status=wifi_station_get_connect_status(); if(status==STATION_GOT_IP){ os_printf("Wifi connect success!"); const char remote_ip[4]={192,168,1,103};//用于存放本地IP地址,一定要是自己的电脑真实的本地IP地址 wifi_get_ip_info(STATON_IF,&info); //my_station_init((struct ip_addr *)remote_ip,&info.ip,1025);//Client端初始化主函数 my_server_init(&info.ip,1213);//Server端初始化主函数 return; }else{ if(count>=7){ os_printf("Wifi connect fail!"); return; } } os_timer_arm(&connect_timer,2000,NULL); } user_main.c的所有代码: * user_main.c * * Created on: 2017脛锚3脭脗14脠脮 * Author: yuanlifu */ #include "ets_sys.h" #include "driver/uart.h" #include "user_main.h" #include "user_interface.h" #include "client.h" #include "server.h" ETSTimer connect_timer; void ICACHE_FLASH_ATTR Wifi_conned(void *arg){ static uint8 count=0; uint8 opmode; struct ip_info info; //用于获取IP地址的信息 uint8 status; os_timer_disarm(&connect_timer); count++; status=wifi_station_get_connect_status(); if(status==STATION_GOT_IP){ os_printf("Wifi connect success!"); const char remote_ip[4]={192,168,1,103};//用于存放本地IP地址,一定要是自己的电脑真实的本地IP地址 wifi_get_ip_info(STATON_IF,&info); opmode = wifi_get_opmode_default(); os_printf("rn当前的工作模式:%drn",opmode); //my_station_init((struct ip_addr *)remote_ip,&info.ip,1025);//Client端初始化主函数 my_server_init(&info.ip,1213);//Server端初始化主函数 return; }else{ if(count>=7){ os_printf("Wifi connect fail!"); return; } } os_timer_arm(&connect_timer,2000,NULL); } void ICACHE_FLASH_ATTR scan_done(void *arg,STATUS status){ uint8 ssid[33]; char temp[128]; struct station_config stationConf; if (status == OK) { struct bss_info *bss_link = (struct bss_info *)arg; bss_link = bss_link->next.stqe_next;//ignore first while (bss_link != NULL) { os_memset(ssid, 0, 33); if (os_strlen(bss_link->ssid) <= 32) { os_memcpy(ssid, bss_link->ssid, os_strlen(bss_link->ssid)); } else { os_memcpy(ssid, bss_link->ssid, 32); } os_sprintf(temp,"+CWLAP:(%d,"%s",%d,""MACSTR"",%d)rn", bss_link->authmode, ssid, bss_link->rssi, MAC2STR(bss_link->bssid),bss_link->channel); os_printf("%s",temp); bss_link = bss_link->next.stqe_next; } os_memcpy(&stationConf.ssid, "MERCURY_2784", 32); os_memcpy(&stationConf.password, "123456789", 64); wifi_station_set_config_current(&stationConf); wifi_station_connect(); os_timer_setfn(&connect_timer,Wifi_conned,NULL); os_timer_arm(&connect_timer,2000,NULL); } else { // os_sprintf(temp,"err, scan status %drn", status); // uart0_sendStr(temp); os_printf("%s","Error"); } } void to_scan(void) { wifi_station_scan(NULL,scan_done); } void user_init(){ struct softap_config config; uint8 opmode; uart_init(115200,115200); wifi_set_opmode(0x03);//设置为AP模式 opmode = wifi_get_opmode_default(); os_printf("rn当前的工作模式:%drn",opmode); wifi_softap_get_config(&config); os_memcpy(config.ssid,"ESP8266",strlen("ESP8266")); os_memcpy(config.password,"123456789",strlen("123456789")); config.ssid_len = strlen("ESP8266"); wifi_softap_set_config(&config); system_init_done_cb(to_scan);//扫描WiFi需要系统初始化完成之后 } void user_rf_pre_init(){ } 接下来就是写入TCP服务器的套路了
server.h
/** *server.h **/ #ifndef APP_INCLUDE_SERVER_H #define APP_INCLUDE_SERVER_H #include "user_main.h" #include "espconn.h" #include "mem.h" void my_server_init(struct ip_addr *local_ip,int port); #endif/*APP_INCLUDE_SERVER_H*/ server.c * server.c * * Created on: 2017年3月17日 * Author: yulifu */ #include "server.h" void ICACHE_FLASH_ATTR server_recv(void *arg, char *pdata, unsigned short len){//接收数据的回调函数 os_printf("收到PC发来的数据:%srn",pdata);//将客户端发过来的数据打印出来 espconn_sent((struct espconn *)arg,"发送已经收到rn",strlen("发送已经收到"));//往客户机发送数据 } void ICACHE_FLASH_ATTR server_sent(void *arg){//发送数据成功的回调函数 os_printf("发送数据成功!!rn"); } void ICACHE_FLASH_ATTR server_discon(void *arg){//断开连接的回调函数 os_printf("连接已经断开rn"); } void ICACHE_FLASH_ATTR server_listen(void *arg){//服务器监听函数 struct espconn *pespconn=arg; espconn_regist_recvcb(pespconn,server_recv);//注册一个接收数据的回调函数 espconn_regist_sentcb(pespconn,server_sent);//注册一个发送数据成功的回调函数 espconn_regist_disconcb(pespconn,server_discon);//注册一个断开连接的回调函数 } void ICACHE_FLASH_ATTR server_recon(void *arg,sint8 err){//重新连接回调函数 os_printf("连接错误,错误代码为:%srn",err);//输出重新连接的错误代码 } void ICACHE_FLASH_ATTR my_server_init(struct ip_addr *local_ip,int port){ LOCAL struct espconn esp_conn; esp_conn.type=ESPCONN_TCP; esp_conn.state=ESPCONN_NONE; esp_conn.proto.tcp=(esp_tcp *)os_malloc(sizeof(esp_tcp)); os_memcpy(esp_conn.proto.tcp->local_ip,local_ip,4); esp_conn.proto.tcp->local_port=port; //注册连接成功的回调函数和连接失败重新连接的回调函数 espconn_regist_connectcb(&esp_conn,server_listen);//注册一个连接成功回调函数 espconn_regist_reconcb(&esp_conn,server_recon);//注册一个连接失败重新连接回调函数 espconn_accept(&esp_conn); } 效果: PC端: 手机端APP效果:—— 找到了一份ESP8266关于TCP通信的源码感觉还不错,怕忘记放在这里: tcp.c /* * tcp.c * * Created on: 2017年3月23日 * Author: yuanlifu */ #include "ets_sys.h" #include "osapi.h" #include "user_interface.h" #include "mem.h" #include "espconn.h" #include "driver/uart.h" #include "tcp.h" typedef enum { teClient, teServer }teType; typedef struct { BOOL linkEn; BOOL teToff; uint8_t linkId; teType teType; uint8_t repeaTime; uint8_t changType; uint8 remoteIp[4]; int32_t remotePort; struct espconn *pCon; }linkConType; typedef struct { BOOL linkEn; BOOL teToff; uint8_t linkId; teType teType; uint8_t repeaTime; struct espconn *pCon; } espConnectionType; linkConType pLink; espConnectionType user_contype; static struct espconn *pTcpServer; //os_event_t procTaskQueue[procTaskQueueLen]; bool Connect_break; bool Send_Flag; /* * 函数名:void Wifi_AP_Init() * 功能wifi_ap初始化 */ void WIFIAPInit() { struct softap_config apConfig; /***************************模式设置************************************/ if(wifi_set_opmode(SOFTAP_MODE)){ // 设置为AP模式 }else{ } /***************************名字设通道置************************************/ os_bzero(&apConfig, sizeof(struct softap_config)); wifi_softap_get_config(&apConfig); apConfig.ssid_len=7; //设置ssid长度 os_strcpy(apConfig.ssid,"213联盟"); //设置ssid名字 os_strcpy(apConfig.password,"12345678"); //设置密码 apConfig.authmode =3; //设置加密模式 ETS_UART_INTR_DISABLE(); //关闭串口中断 wifi_softap_set_config(&apConfig); //配置 ETS_UART_INTR_ENABLE(); //打开串口 } /* *函数名:void TcpServer_Listen_Recv(void *arg, char *pdata, unsigned short len) *功能:接收监听函数 */ void TcpServer_Listen_Recv(void *arg, char *pdata, unsigned short len) { uart0_sendStr(pdata); } /* * 函数名:void TcpServer_Listen_Recb(void *arg, sint8 errType) * 功能:连接监听函数 */ void TcpServer_Listen_recon_cb(void *arg, sint8 errType) { struct espconn *pespconn = (struct espconn *)arg; linkConType *linkTemp = (linkConType *)pespconn->reverse; Connect_break=0; } /* * 函数名:void Tcp_Server_Listen_discon_cb(void *arg) * 功能:正常断开时监听函数 */ void Tcp_Server_Listen_discon_cb(void *arg) { struct espconn *pespconn = (struct espconn *) arg; linkConType *linkTemp = (linkConType *) pespconn->reverse; Connect_break=0; } /* * 函数名:void Tcp_Server_Listen_sent_cb(void *arg) * 功能:发送成功监听函数 */ void Tcp_Server_Listen_sent_cb(void *arg) { struct espconn *pespconn = (struct espconn *) arg; linkConType *linkTemp = (linkConType *) pespconn->reverse; Send_Flag=0; } /* * 函数名:void TcpServer_Listen_PCon(void *arg) * 功能:手机连入AP监听函数 */ void TcpServerListen_PCon(void *arg) { struct espconn *pespconn = (struct espconn *)arg; pLink.teToff = FALSE; pLink.linkId = 1; pLink.teType = teServer; pLink.repeaTime = 0; pLink.pCon = pespconn; pespconn->reverse = &pLink; espconn_regist_recvcb(pespconn, TcpServer_Listen_Recv); //注册接收监听函数 espconn_regist_reconcb(pespconn, TcpServer_Listen_recon_cb); //注册连接监听函数 espconn_regist_disconcb(pespconn, Tcp_Server_Listen_discon_cb); //注册正常断开时监听函数 espconn_regist_sentcb(pespconn, Tcp_Server_Listen_sent_cb); //注册发送成功监听函数 } /* * 函数名:void WIFI_Server_MODE() * 功能:设置服务器模式 */ void WIFIServerMode(void) { espconn_tcp_set_max_con(1); //设置TCP连接的最大多少 pTcpServer = (struct espconn *)os_zalloc(sizeof(struct espconn)); pTcpServer->type = ESPCONN_TCP; //TCP服务 pTcpServer->state = ESPCONN_NONE; //状态 pTcpServer->proto.tcp = (esp_tcp *)os_zalloc(sizeof(esp_tcp)); pTcpServer->proto.tcp->local_port = 8888; //断开号 espconn_regist_connectcb(pTcpServer, TcpServerListen_PCon); espconn_accept(pTcpServer); espconn_regist_time(pTcpServer, 180, 0); //设置超时断开时间 单位s } /* * 函数名:void WIFI_TCP_SendNews(unsigned char *dat) * 功能:像TCP服务器发送消息 */ void WIFI_TCP_SendNews(unsigned char *dat,uint16 len) { espconn_sent(pLink.pCon,dat,len); } /*void SendTask(os_event_t *events) { struct station_info *pstation_info=wifi_softap_get_station_info(); if((pstation_info!=NULL)&&(Connect_break==1)){ if(Send_Flag==0){ Send_Flag=1; WIFI_TCP_Send(xReceive,xLen); }else{ uart0_sendStr("bus"); } }else{ Send_Flag=0; uart0_sendStr("NO device"); } xLen=0; } void Task_Init() { // uart_init(BIT_RATE_9600,BIT_RATE_9600); system_os_task(SendTask, procTaskPrio, procTaskQueue, procTaskQueueLen); }*/ tcp.h /* * tcp.h * * Created on: 2017年3月23日 * Author: yuanlifu */ #ifndef APP_USER_TCP_H_ #define APP_USER_TCP_H_ void WIFIAPInit(); void WIFIServerMode(void); void TcpServerListen_PCon(void *arg); void WIFI_TCP_SendNews(unsigned char *dat,uint16 len); //void Task_Init(); #endif /* APP_USER_TCP_H_ */ |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
RK3568 Android11让系统ntp校准时间生效,需要设置些什么
1555 浏览 1 评论
2750 浏览 1 评论
3679 浏览 2 评论
RK3568平台,进入烧录模式,部分电脑提示无法识别,无法烧录
6556 浏览 1 评论
【RK3568 Android11.0】如何在设置-显示-HDMI-分辨率设置中添加3840*2160的选项?
9137 浏览 1 评论
GMT+8, 2024-6-28 10:18 , Processed in 0.528118 second(s), Total 42, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
