OKMX6X-C-Linux手册-V2.0-2018-03-30.pdf里面介绍了一个工具gstcamera,可以对焦。
af 自动对焦,sp0 对焦无穷远,sp255 对焦最近对焦距离。 手册里面说,输入sp0,sp100,sp255是指定焦距手动对焦,但是我实际测试,结果都是自动对焦。 从驱动程序看,存在问题。ioctl_send_command是响应sp命令的,但是,它调用了自动对焦配置函数ov5640_config_auto_focus()。 驱动程序应该怎么修改呢?应该联系谁呢? linux-3.0.35driversmediavideomxccaptureov5640.c static int ioctl_send_command(struct v4l2_int_device *s, struct v4l2_send_command_control *vc) { int ret = -1; int retval1,retval2; u8 loca_val=0; ret = ov5640_set_idle_mode(); if (0 != ret) pr_err("error %d setting idle moden", ret); ov5640_config_auto_focus(); switch (vc->id) { case 101: //step to near pr_debug("Stepping to near objectn"); retval1=ov5640_write_reg(REG_CMD_TAG, 0x01); retval2=ov5640_write_reg(REG_CMD_MAIN, 0x05); if(retval1 == 0 && retval2 == 0) ret = 0; break; case 102: //step to far pr_debug("Stepping to far objectn"); retval1=ov5640_write_reg(REG_CMD_TAG, 0x02); retval2=ov5640_write_reg(REG_CMD_MAIN, 0x05); if(retval1 == 0 && retval2 == 0) ret = 0; break; case 103: //step to furthest pr_debug("Stepping to furthest objectn"); retval1=ov5640_write_reg(REG_CMD_TAG, 0x03); retval2=ov5640_write_reg(REG_CMD_MAIN, 0x05); if(retval1 == 0 && retval2 == 0) ret = 0; break; case 104: //step to nearest pr_debug("Stepping to nearest objectn"); retval1=ov5640_write_reg(REG_CMD_TAG, 0x04); retval2=ov5640_write_reg(REG_CMD_MAIN, 0x05); if(retval1 == 0 && retval2 == 0) ret = 0; break; case 105: //step to specified position pr_debug("Stepping to position: %dn", vc->value0); if(vc->value0 < 0 || vc->value0 > 255) return ret; loca_val = vc->value0; retval1=ov5640_write_reg(REG_CMD_TAG, 0x10); retval2=ov5640_write_reg(REG_CMD_PARA0, loca_val); ret=ov5640_write_reg(REG_CMD_MAIN, 0x05); if(retval1 != 0 && retval2 != 0 && ret != 0) ret = -1; break; default: break; } return ret; } |
1个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1160 浏览 0 评论
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
1381 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
7174 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
2184 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2727 浏览 0 评论
/9
GMT+8, 2025-12-15 10:48 , Processed in 1.516180 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4000
