- 全量编译成功,之后更新Ubuntu.img 到U盘,重启后使用boot烧写更新Ubuntu,成功之后重启,发现root账号登陆不了。有遇到同样问题的朋友吗?急急急!!!
- 今天买了sd卡,使用sd卡启动,U盘烧写自带的Ubuntu Image,发现内核启动失败,打印如下:
-Boot SPL 2018.03-dirty (May 26 2020 - 12:34:31 +0800)
Initialzing DDR using fixed setting
Configuring DDR for 2100 MT/s data rate
Trying to boot from MMC1
U-Boot 2018.03-dirty (May 26 2020 - 12:34:31 +0800)
SoC: LS1046AE Rev1.0 (0x87070010)
Clock Configuration:
CPU0(A72):1800 MHz CPU1(A72):1800 MHz CPU2(A72):1800 MHz
CPU3(A72):1800 MHz
Bus: 700 MHz DDR: 2100 MT/s FMAN: 800 MHz
Reset Configuration Word (RCW):
00000000: 0e150012 10000000 00000000 00000000
00000010: 10405559 40005012 60025000 c1000000
00000020: 00000000 00000000 00000000 00238802
00000030: 20044500 00001102 00000096 00000001
Model: OK1046-C
Board: LS1046ARDB, boot from SD/eMMC
SERDES Reference Clocks:
SD1_CLK1 = 100.00MHZ, SD1_CLK2 = 156.25MHZ
SD2_CLK1 = 100.00MHZ, SD2_CLK2 = 100.00MHZ
I2C: ready
DRAM: 1.9 GiB (DDR4, 32-bit, CL=15, ECC off)
SEC0: RNG instantiated
FSL_SDHC: 0
ppa_init: fdt_check_header() failed
DS2460 OK
Waking secondary cores to start from fbd45000
All (4) cores are up.
Using SERDES1 Protocol: 4160 (0x1040)
Using SERDES2 Protocol: 21849 (0x5559)
MMC: Loading Environment from MMC... OK
In: serial
Out: serial
Err: serial
SATA link 0 timeout.
AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
flags: 64bit ncq pm clo only pmp fbss pio slum part ccc apst
Found 0 device(s).
SCSI: Net:
MMC read: dev # 0, block # 18432, count 128 ...
Fman1: Uploading microcode version 106.4.18
PCIe0: pcie@3400000 Root Complex: no link
PCIe1: pcie@3500000 Root Complex: no link
PCIe2: pcie@3600000 Root Complex: no link
FM1@DTSEC1, FM1@DTSEC3 [PRIME], FM1@DTSEC4, FM1@DTSEC5, FM1@DTSEC6, FM1@DTSEC10, FM1@TGEC1
Hit any key to stop autoboot: 0
=> boot
starting USB...
USB0: Register 200017f NbrPorts 2
Starting the controller
USB XHCI 1.00
USB1: Register 200017f NbrPorts 2
USB XHCI 1.00
USB2: Register 200017f NbrPorts 2
USB XHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
scanning u*** for storage devices... 0 Storage Device(s) found
Device 0: device type unknown
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Scanning mmc 0:2...
Found U-Boot script /boot/ls1046ardb_boot.scr
886 bytes read in 18 ms (47.9 KiB/s)
## Executing script at 80000000
** Unable to read file /boot/uEnv.txt **
21522944 bytes read in 1101 ms (18.6 MiB/s)
28972 bytes read in 17 ms (1.6 MiB/s)
## Flattened Device Tree blob at 90000000
Booting using the fdt blob at 0x90000000
Using Device Tree in place at 0000000090000000, end 000000009001a12b
WARNING: SEC firmware not running, no kaslr-seed
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.47 (zyh@1ffe9f7b637e) (gcc version 7.3.0 (Ubuntu/Linaro 7.3.0-27ubuntu1~18.04)) #1 SMP PREEMPT Sat Feb 22 16:00:07 CST 2020
[ 0.000000] Boot CPU: AArch64 Processor [410fd082]
[ 0.000000] Machine model: LS1046A RDB Board
[ 0.000000] earlycon: uart8250 at MMIO 0x00000000021c0500 (options '')
[ 0.000000] bootconsole [uart8250] enabled
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] OF: reserved mem: initialized node qman-fqd, compatible id fsl,qman-fqd
[ 0.000000] OF: reserved mem: initialized node qman-pfdr, compatible id fsl,qman-pfdr
[ 0.000000] OF: reserved mem: initialized node bman-fbpr, compatible id fsl,bman-fbpr
[ 0.000000] cma: Reserved 16 MiB at 0x00000000f7000000
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000fbdfffff]
[ 0.000000] NUMA: NODE_DATA [mem 0xfbdc9d80-0xfbdcb53f]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000fbdfffff]
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000f7ffffff]
[ 0.000000] node 0: [mem 0x00000000fb800000-0x00000000fbdfffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000fbdfffff]
[ 0.000000] percpu: Embedded 24 pages/cpu @ffff80007bd62000 s59992 r8192 d30120 u98304
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 485128
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: console=ttyS0,115200 earlycon=uart8250,mmio,0x21c0500 root=PARTUUID=537f607a-03 rw rootwait
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Memory: 1900328K/1972224K available (12988K kernel code, 1434K rwdata, 5320K rodata, 1216K init, 974K bss, 55512K reserved, 16384K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffff000000000000 - 0xffff000008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffff000008000000 - 0xffff7dffbfff0000 (129022 GB)
[ 0.000000] .text : 0xffff000008080000 - 0xffff000008d30000 ( 12992 KB)
[ 0.000000] .rodata : 0xffff000008d30000 - 0xffff000009270000 ( 5376 KB)
[ 0.000000] .init : 0xffff000009270000 - 0xffff0000093a0000 ( 1216 KB)
[ 0.000000] .data : 0xffff0000093a0000 - 0xffff000009506a00 ( 1435 KB)
[ 0.000000] .bss : 0xffff000009506a00 - 0xffff0000095fa390 ( 975 KB)
[ 0.000000] fixed : 0xffff7dfffe7f9000 - 0xffff7dfffec00000 ( 4124 KB)
[ 0.000000] PCI I/O : 0xffff7dfffee00000 - 0xffff7dffffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffff7e0000000000 - 0xffff800000000000 ( 2048 GB maximum)
[ 0.000000] 0xffff7e0000000000 - 0xffff7e0001ef8000 ( 30 MB actual)
[ 0.000000] memory : 0xffff800000000000 - 0xffff80007be00000 ( 1982 MB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Adjusting CPU inte**ce base to 0x000000000142f000
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] arch_timer: cp15 timer(s) running at 25.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x5c40939b5, max_idle_ns: 440795202646 ns
[ 0.000002] sched_clock: 56 bits at 25MHz, resolution 40ns, wraps every 4398046511100ns
[ 0.008362] Console: colour dummy device 80x25
[ 0.012855] Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=100000)
[ 0.023264] pid_max: default: 32768 minimum: 301
[ 0.027964] Security Framework initialized
[ 0.032895] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.040471] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.047576] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.054323] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.077523] ASID allocator initialised with 32768 entries
[ 0.082982] Hierarchical SRCU implementation.
[ 0.095751] EFI services will not be available.
[ 0.108311] smp: Bringing up secondary CPUs ...
[ 0.140935] Detected PIPT I-cache on CPU1
[ 0.140957] CPU1: Booted secondary processor [410fd082]
[ 0.168946] Detected PIPT I-cache on CPU2
[ 0.168959] CPU2: Booted secondary processor [410fd082]
[ 0.196969] Detected PIPT I-cache on CPU3
[ 0.196981] CPU3: Booted secondary processor [410fd082]
[ 0.197008] smp: Brought up 1 node, 4 CPUs
[ 0.228955] SMP: Total of 4 processors activated.
[ 0.233682] CPU features: detected feature: 32-bit EL0 Support
[ 0.239543] CPU features: detected feature: Kernel page table isolation (KPTI)
[ 0.249955] CPU: All CPU(s) started at EL2
[ 0.254077] alternatives: patching kernel code
[ 0.259045] devtmpfs: initialized
[ 0.264259] random: get_random_u32 called from bucket_table_alloc+0x108/0x258 with crng_init=0
[ 0.273081] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.282890] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.289408] xor: measuring software checksum speed
[ 0.334241] 8regs : 7660.000 MB/sec
[ 0.378459] 8regs_prefetch: 6686.000 MB/sec
[ 0.423027] 32regs : 8628.000 MB/sec
[ 0.467245] 32regs_prefetch: 7294.000 MB/sec
[ 0.471883] xor: using function: 32regs (8628.000 MB/sec)
[ 0.477309] pinctrl core: initialized pinctrl subsystem
[ 0.483073] DMI not present or invalid.
[ 0.487081] NET: Registered protocol family 16
[ 0.492347] cpuidle: using governor menu
[ 0.496468] Bman ver:0a02,02,01
[ 0.501625] qman-fqd addr 0x00000000fb000000 size 0x800000
[ 0.507161] qman-pfdr addr 0x00000000f8000000 size 0x2000000
[ 0.512857] Qman ver:0a01,03,02,01
[ 0.516334] vdso: 2 pages (1 code @ ffff000008d36000, 1 data @ ffff0000093a5000)
[ 0.523804] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.531057] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.537358] Serial: AMBA PL011 UART driver
[ 0.544376] Machine: LS1046A RDB Board
[ 0.548150] SoC family: QorIQ LS1046A
[ 0.551824] SoC ID: svr:0x87070010, Revision: 1.0
[ 0.567598] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.639712] raid6: int64x1 gen() 1113 MB/s
[ 0.711715] raid6: int64x1 xor() 1008 MB/s
[ 0.783743] raid6: int64x2 gen() 1540 MB/s
[ 0.855766] raid6: int64x2 xor() 1459 MB/s
[ 0.927794] raid6: int64x4 gen() 2347 MB/s
[ 0.999810] raid6: int64x4 xor() 1643 MB/s
[ 1.071845] raid6: int64x8 gen() 2157 MB/s
[ 1.143874] raid6: int64x8 xor() 1610 MB/s
[ 1.215920] raid6: neonx1 gen() 2281 MB/s
[ 1.287929] raid6: neonx1 xor() 2506 MB/s
[ 1.359962] raid6: neonx2 gen() 3016 MB/s
[ 1.431986] raid6: neonx2 xor() 3137 MB/s
[ 1.504024] raid6: neonx4 gen() 3936 MB/s
[ 1.576047] raid6: neonx4 xor() 3476 MB/s
[ 1.648079] raid6: neonx8 gen() 4414 MB/s
[ 1.720112] raid6: neonx8 xor() 3767 MB/s
[ 1.724399] raid6: using algorithm neonx8 gen() 4414 MB/s
[ 1.729823] raid6: .... xor() 3767 MB/s, rmw enabled
[ 1.734810] raid6: using neon recovery algorithm
[ 1.739688] ACPI: Interpreter disabled.
[ 1.744843] vgaarb: loaded
[ 1.747678] SCSI subsystem initialized
[ 1.751648] u***core: registered new inte**ce driver u***fs
[ 1.757229] u***core: registered new inte**ce driver hub
[ 1.762593] u***core: registered new device driver u***
[ 1.767965] imx-i2c 2180000.i2c: can't get pinctrl, bus recovery not supported
[ 1.775342] i2c i2c-0: IMX I2C adapter registered
[ 1.780093] i2c i2c-0: using dma0chan16 (tx) and dma0chan17 (rx) for DMA transfers
[ 1.787744] imx-i2c 21a0000.i2c: fsl-scl-gpio not found
[ 1.793014] imx-i2c 21a0000.i2c: can't get pinctrl, bus recovery not supported
[ 1.800339] i2c i2c-1: IMX I2C adapter registered
[ 1.805068] i2c i2c-1: can't use DMA, using PIO instead.
[ 1.810472] imx-i2c 21b0000.i2c: can't get pinctrl, bus recovery not supported
[ 1.817768] i2c i2c-2: IMX I2C adapter registered
[ 1.822502] i2c i2c-2: can't use DMA, using PIO instead.
[ 1.828296] pps_core: LinuxPPS API ver. 1 registered
[ 1.833287] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.842486] PTP clock support registered
[ 1.846515] EDAC MC: Ver: 3.0.0
[ 1.849769] dmi: Firmware registration failed.
[ 1.854243] bman-fbpr addr 0x00000000fa000000 size 0x1000000
[ 1.859948] Bman err interrupt handler present
[ 1.864722] Bman portal initialised, cpu 0
[ 1.868885] Bman portal initialised, cpu 1
[ 1.873047] Bman portal initialised, cpu 2
[ 1.877208] Bman portal initialised, cpu 3
[ 1.881322] Bman portals initialised
[ 1.885672] Qman err interrupt handler present
[ 1.890659] QMan: Allocated lookup table at ffff00000b37d000, entry count 131073
[ 1.898392] Qman portal initialised, cpu 0
[ 1.902551] Qman portal initialised, cpu 1
[ 1.906706] Qman portal initialised, cpu 2
[ 1.910862] Qman portal initialised, cpu 3
[ 1.914979] Qman portals initialised
[ 1.918606] Bman: BPID allocator includes range 32:32
[ 1.923707] Qman: FQID allocator includes range 256:256
[ 1.928960] Qman: FQID allocator includes range 32768:32768
[ 1.934588] Qman: CGRID allocator includes range 0:256
[ 1.939873] Qman: pool channel allocator includes range 1025:15
[ 1.945888] No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree
[ 1.952148] Advanced Linux Sound Architecture Driver Initialized.
[ 1.958569] clocksource: Switched to clocksource arch_sys_counter
[ 1.964767] VFS: Disk quotas dquot_6.6.0
[ 1.968735] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.975703] pnp: PnP ACPI: disabled
[ 1.981715] NET: Registered protocol family 2
[ 1.986330] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 1.993647] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 2.000535] TCP: Hash tables configured (established 16384 bind 16384)
[ 2.007149] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 2.013199] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 2.019741] NET: Registered protocol family 1
[ 2.024263] RPC: Registered named UNIX socket transport module.
[ 2.030223] RPC: Registered udp transport module.
[ 2.034952] RPC: Registered tcp transport module.
[ 2.039678] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 2.046497] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 2.054942] kvm [1]: 8-bit VMID
[ 2.058664] kvm [1]: vgic interrupt IRQ1
[ 2.062655] kvm [1]: Hyp mode initialized successfully
[ 2.068904] audit: initializing netlink subsys (disabled)
[ 2.074382] audit: type=2000 audit(1.944:1): state=initialized audit_enabled=0 res=1
[ 2.074519] workingset: timestamp_bits=44 max_order=19 bucket_order=0
[ 2.082380] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 2.082470] NFS: Registering the id_resolver key type
[ 2.082478] Key type id_resolver registered
[ 2.082479] Key type id_legacy registered
[ 2.082483] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 2.082531] fuse init (API version 7.26)
[ 2.082593] 9p: Installing v9fs 9p2000 file system support
[ 2.083714] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 2.087757] io scheduler noop registered
[ 2.087776] io scheduler cfq registered (default)
[ 2.087778] io scheduler mq-deadline registered
[ 2.087779] io scheduler kyber registered
[ 2.093746] OF: PCI: host bridge /soc/pcie@3400000 ranges:
[ 2.093756] OF: PCI: IO 0x4000010000..0x400001ffff -> 0x00000000
[ 2.093761] OF: PCI: MEM 0x4040000000..0x407fffffff -> 0x40000000
[ 2.093831] layerscape-pcie 3400000.pcie: PCI host bridge to bus 0000:00
[ 2.093834] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.093837] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.093840] pci_bus 0000:00: root bus resource [mem 0x4040000000-0x407fffffff] (bus address [0x40000000-0x7fffffff])
[ 2.094007] pci 0000:00:00.0: BAR 6: assigned [mem 0x4040000000-0x40400007ff pref]
[ 2.094010] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 2.094114] pcieport 0000:00:00.0: Signaling PME with IRQ 65
[ 2.094166] pcieport 0000:00:00.0: AER enabled with IRQ 66
[ 2.094245] OF: PCI: host bridge /soc/pcie@3500000 ranges:
[ 2.094251] OF: PCI: IO 0x4800010000..0x480001ffff -> 0x00000000
[ 2.094255] OF: PCI: MEM 0x4840000000..0x487fffffff -> 0x40000000
[ 2.094311] layerscape-pcie 3500000.pcie: PCI host bridge to bus 0001:00
[ 2.094314] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 2.094317] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x0000-0xffff])
[ 2.094320] pci_bus 0001:00: root bus resource [mem 0x4840000000-0x487fffffff] (bus address [0x40000000-0x7fffffff])
[ 2.094464] pci 0001:00:00.0: BAR 6: assigned [mem 0x4840000000-0x48400007ff pref]
[ 2.094466] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 2.094549] pcieport 0001:00:00.0: Signaling PME with IRQ 67
[ 2.094608] pcieport 0001:00:00.0: AER enabled with IRQ 68
[ 2.094687] OF: PCI: host bridge /soc/pcie@3600000 ranges:
[ 2.094693] OF: PCI: IO 0x5000010000..0x500001ffff -> 0x00000000
[ 2.094697] OF: PCI: MEM 0x5040000000..0x507fffffff -> 0x40000000
[ 2.094753] layerscape-pcie 3600000.pcie: PCI host bridge to bus 0002:00
[ 2.094755] pci_bus 0002:00: root bus resource [bus 00-ff]
[ 2.094758] pci_bus 0002:00: root bus resource [io 0x20000-0x2ffff] (bus address [0x0000-0xffff])
[ 2.094761] pci_bus 0002:00: root bus resource [mem 0x5040000000-0x507fffffff] (bus address [0x40000000-0x7fffffff])
[ 2.094907] pci 0002:00:00.0: BAR 6: assigned [mem 0x5040000000-0x50400007ff pref]
[ 2.094909] pci 0002:00:00.0: PCI bridge to [bus 01-ff]
[ 2.094991] pcieport 0002:00:00.0: Signaling PME with IRQ 69
[ 2.095040] pcieport 0002:00:00.0: AER enabled with IRQ 70
[ 2.098002] Freescale LS2 console driver
[ 2.098055] fsl-ls2-console: device fsl_mc_console registered
[ 2.098087] fsl-ls2-console: device fsl_aiop_console registered
[ 2.100790] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.101803] console [ttyS0] disabled
[ 2.393517] 21c0500.serial: ttyS0 at MMIO 0x21c0500 (irq = 39, base_baud = 21875000) is a 16550A
[ 2.402363] console [ttyS0] enabled
[ 2.409350] bootconsole [uart8250] disabled
[ 2.417966] 21c0600.serial: ttyS1 at MMIO 0x21c0600 (irq = 39, base_baud = 21875000) is a 16550A
[ 2.426944] 21d0500.serial: ttyS2 at MMIO 0x21d0500 (irq = 40, base_baud = 21875000) is a 16550A
[ 2.435919] 21d0600.serial: ttyS3 at MMIO 0x21d0600 (irq = 40, base_baud = 21875000) is a 16550A
[ 2.445112] SuperH (H)SCI(F) driver initialized
[ 2.449953] msm_serial: driver initialized
[ 2.457487] brd: module loaded
[ 2.463533] loop: module loaded
[ 2.524287] ahci-qoriq 3200000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 2.533250] ahci-qoriq 3200000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 2.543329] scsi host0: ahci-qoriq
[ 2.546803] ata1: SATA max UDMA/133 mmio [mem 0x03200000-0x0320ffff] port 0x100 irq 50
[ 2.555515] fsl-quadspi 1550000.quadspi: n25q128a13 (16384 Kbytes)
[ 2.563278] libphy: Fixed MDIO Bus: probed
[ 2.567756] tun: Universal TUN/TAP device driver, 1.6
[ 2.573435] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.579487] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.585526] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.590653] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.595776] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.600896] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.606025] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.611144] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.616266] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.621369] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.635052] Freescale FM module, FMD API version 21.1.0
[ 2.642277] Freescale FM Ports module
[ 2.645938] fsl_mac: fsl_mac: FSL FMan MAC API based driver
[ 2.651842] fsl_mac 1ae0000.ethernet: FMan MEMAC
[ 2.656459] fsl_mac 1ae0000.ethernet: FMan MAC address: 4e:d8:38:ab:8d:4b
[ 2.663326] fsl_mac 1ae4000.ethernet: FMan MEMAC
[ 2.667942] fsl_mac 1ae4000.ethernet: FMan MAC address: 56:82:00:44:b5:93
[ 2.674808] fsl_mac 1ae6000.ethernet: FMan MEMAC
[ 2.679424] fsl_mac 1ae6000.ethernet: FMan MAC address: ba:28:85:8e:5f:61
[ 2.686454] fsl_mac 1ae8000.ethernet: FMan MEMAC
[ 2.691069] fsl_mac 1ae8000.ethernet: FMan MAC address: ca:96:e2:64:71:ac
[ 2.698101] fsl_mac 1aea000.ethernet: FMan MEMAC
[ 2.702717] fsl_mac 1aea000.ethernet: FMan MAC address: 16:ca:5c:81:67:30
[ 2.709586] fsl_mac 1af0000.ethernet: FMan MEMAC
[ 2.714201] fsl_mac 1af0000.ethernet: FMan MAC address: a2:38:63:a2:af:39
[ 2.721236] fsl_mac 1af2000.ethernet: FMan MEMAC
[ 2.725851] fsl_mac 1af2000.ethernet: FMan MAC address: 96:53:29:bc:ae:70
[ 2.732664] fsl_dpa: FSL DPAA Ethernet driver
[ 2.740097] fsl_dpa: fsl_dpa: Probed inte**ce eth0
[ 2.747853] fsl_dpa: fsl_dpa: Probed inte**ce eth1
[ 2.755651] fsl_dpa: fsl_dpa: Probed inte**ce eth2
[ 2.764194] fsl_dpa: fsl_dpa: Probed inte**ce eth3
[ 2.772813] fsl_dpa: fsl_dpa: Probed inte**ce eth4
[ 2.781798] fsl_dpa: fsl_dpa: Probed inte**ce eth5
[ 2.791043] fsl_dpa: fsl_dpa: Probed inte**ce eth6
[ 2.796101] fsl_advanced: FSL DPAA Advanced drivers:
[ 2.801063] fsl_proxy: FSL DPAA Proxy initialization driver
[ 2.806851] fsl_oh: FSL FMan Offline Parsing port driver
[ 2.812446] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[ 2.819536] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 2.825306] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 2.831137] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.837093] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 2.844057] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.849642] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 2.857468] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 2.863630] sky2: driver version 1.30
[ 2.867537] PPP generic driver version 2.4.2
[ 2.868756] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.877269] PPP BSD Compression module registered
[ 2.881970] PPP Deflate Compression module registered
[ 2.887029] PPP MPPE Compression module registered
[ 2.891816] NET: Registered protocol family 24
[ 2.896280] u***core: registered new inte**ce driver asix
[ 2.901705] u***core: registered new inte**ce driver ax88179_178a
[ 2.907808] u***core: registered new inte**ce driver cdc_ether
[ 2.913649] u***core: registered new inte**ce driver net1080
[ 2.919315] u***core: registered new inte**ce driver cdc_subset
[ 2.925244] u***core: registered new inte**ce driver zaurus
[ 2.930829] u***core: registered new inte**ce driver cdc_ncm
[ 2.936499] u***core: registered new inte**ce driver huawei_cdc_ncm
[ 2.942773] u***core: registered new inte**ce driver qmi_wwan
[ 2.948760] VFIO - User Level meta-driver version: 0.3
[ 2.955507] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.962033] ehci-pci: EHCI PCI platform driver
[ 2.966489] ehci-platform: EHCI generic platform driver
[ 2.971827] ehci-orion: EHCI orion driver
[ 2.975902] ehci-exynos: EHCI EXYNOS driver
[ 2.980153] ehci-msm: Qualcomm On-Chip EHCI Host Controller
[ 2.985779] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.991958] ohci-pci: OHCI PCI platform driver
[ 2.996414] ohci-platform: OHCI generic platform driver
[ 3.001715] ohci-exynos: OHCI EXYNOS driver
[ 3.006159] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.011647] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 3.019502] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x22010810
[ 3.028214] xhci-hcd xhci-hcd.0.auto: irq 47, io mem 0x02f00000
[ 3.034335] hub 1-0:1.0: USB hub found
[ 3.038090] hub 1-0:1.0: 1 port detected
[ 3.042105] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.047591] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 3.055249] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 3.062035] hub 2-0:1.0: USB hub found
[ 3.065789] hub 2-0:1.0: 1 port detected
[ 3.069886] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 3.075375] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[ 3.083190] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x22010810
[ 3.091903] xhci-hcd xhci-hcd.1.auto: irq 48, io mem 0x03000000
[ 3.097990] hub 3-0:1.0: USB hub found
[ 3.101744] hub 3-0:1.0: 1 port detected
[ 3.105753] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 3.111238] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[ 3.118894] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 3.125685] hub 4-0:1.0: USB hub found
[ 3.129439] hub 4-0:1.0: 1 port detected
[ 3.133477] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 3.138964] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 5
[ 3.146825] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x22010810
[ 3.155533] xhci-hcd xhci-hcd.2.auto: irq 49, io mem 0x03100000
[ 3.161612] hub 5-0:1.0: USB hub found
[ 3.165366] hub 5-0:1.0: 1 port detected
[ 3.169372] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 3.174859] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 6
[ 3.182516] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[ 3.189301] hub 6-0:1.0: USB hub found
[ 3.193056] hub 6-0:1.0: 1 port detected
[ 3.197238] u***core: registered new inte**ce driver cdc_wdm
[ 3.202936] u***core: registered new inte**ce driver u***-storage
[ 3.208975] u***core: registered new inte**ce driver u***serial
[ 3.214819] u***core: registered new inte**ce driver u***serial_generic
[ 3.221352] u***serial: USB Serial support registered for generic
[ 3.227371] u***core: registered new inte**ce driver option
[ 3.232947] u***serial: USB Serial support registered for GSM modem (1-port)
[ 3.239993] u***core: registered new inte**ce driver pl2303
[ 3.245570] u***serial: USB Serial support registered for pl2303
[ 3.253173] i2c /dev entries driver
[ 3.257821] IR NEC protocol handler initialized
[ 3.262350] IR RC5(x/sz) protocol handler initialized
[ 3.267396] IR RC6 protocol handler initialized
[ 3.271923] IR JVC protocol handler initialized
[ 3.276447] IR Sony protocol handler initialized
[ 3.281058] IR SANYO protocol handler initialized
[ 3.285755] IR Sharp protocol handler initialized
[ 3.290453] IR MCE Keyboard/mouse protocol handler initialized
[ 3.296279] IR XMP protocol handler initialized
[ 3.302003] imx2-wdt 2ad0000.watchdog: timeout 60 sec (nowayout=0)
[ 3.308731] qoriq_cpufreq: Freescale QorIQ CPU frequency scaling driver
[ 3.315352] CPUidle arm: CPU 0 failed to init idle CPU ops
[ 3.320998] sdhci: Secure Digital Host Controller Inte**ce driver
[ 3.327175] sdhci: Copyright(c) Pierre Ossman
[ 3.331643] Synopsys Designware ** Card Inte**ce Driver
[ 3.338253] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.382588] mmc0: SDHCI controller on 1560000.esdhc [1560000.esdhc] using ADMA 64-bit
[ 3.394212] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.401660] platform caam_qi: Linux CAAM Queue I/F driver initialised
[ 3.408196] caam 1700000.crypto: device ID = 0x0a11030100000000 (Era 8)
[ 3.414841] caam 1700000.crypto: job rings = 3, qi = 1, dpaa2 = no
[ 3.423538] caam algorithms registered in /proc/crypto
[ 3.430036] platform caam_qi: algorithms registered in /proc/crypto
[ 3.437123] caam_jr 1710000.jr: registering rng-caam
[ 3.442123] caam 1700000.crypto: caam pkc algorithms registered in /proc/crypto
[ 3.449740] u***core: registered new inte**ce driver u***hid
[ 3.455358] u***hid: USB HID core driver
[ 3.459806] Freescale USDPAA process driver
[ 3.463986] fsl-usdpaa: no region found
[ 3.467816] Freescale USDPAA process IRQ driver
[ 3.473042] optee: probing for conduit method from DT.
[ 3.478182] Internal error: undefined instruction: 0 [#1] PREEMPT SMP
[ 3.484614] Modules linked in:
[ 3.484670] mmc0: new HS200 MMC card at address 0001
[ 3.484844] mmcblk0: mmc0:0001 Q2J55L 7.09 GiB
[ 3.484924] mmcblk0boot0: mmc0:0001 Q2J55L partition 1 16.0 MiB
[ 3.485022] mmcblk0boot1: mmc0:0001 Q2J55L partition 2 16.0 MiB
[ 3.485112] mmcblk0rpmb: mmc0:0001 Q2J55L partition 3 4.00 MiB
[ 3.485830] mmcblk0: p1 p2 p3
[ 3.517817] CPU: 3 PID: 1 Comm: swapper/0 Not tainted 4.14.47 #1
[ 3.523814] Hardware name: LS1046A RDB Board (DT)
[ 3.528508] task: ffff800074f74d00 task.stack: ffff000008070000
[ 3.534426] PC is at __arm_smccc_smc+0x0/0x2c
[ 3.538776] LR is at optee_smccc_smc+0x18/0x28
[ 3.543211] pc : [] lr : [] pstate: 80000045
[ 3.550598] sp : ffff000008073d10
[ 3.553903] x29: ffff000008073d20 x28: ffff00000938a720
[ 3.559209] x27: 0000000000000007 x26: ffff00000930e068
[ 3.564515] x25: ffff00000950b000 x24: ffff00000927046c
[ 3.569820] x23: ffff000008eec000 x22: ffff00000930e078
[ 3.575125] x21: ffff000008b2fac8 x20: ffff7dfffe80ead8
[ 3.580430] x19: ffff000008073db0 x18: 0000000000000010
[ 3.585735] x17: 0000000000000001 x16: 0000000000000019
[ 3.591039] x15: ffffffffffffffff x14: ffffffffffffffff
[ 3.596344] x13: 0000000000000018 x12: 0101010101010101
[ 3.601649] x11: 0000000000000018 x10: 0101010101010101
[ 3.606953] x9 : ffffffffffffffff x8 : ffff000008073db0
[ 3.612258] x7 : 0000000000000000 x6 : 0000000000000000
[ 3.617562] x5 : 0000000000000000 x4 : 0000000000000000
[ 3.622866] x3 : 0000000000000000 x2 : 0000000000000000
[ 3.628170] x1 : 0000000000000000 x0 : 00000000bf00ff01
[ 3.633475] Process swapper/0 (pid: 1, stack limit = 0xffff000008070000)
[ 3.640167] Call trace:
[ 3.642604] Exception stack(0xffff000008073bd0 to 0xffff000008073d10)
[ 3.649037] 3bc0: 00000000bf00ff01 0000000000000000
[ 3.656860] 3be0: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
[ 3.664682] 3c00: 0000000000000000 0000000000000000 ffff000008073db0 ffffffffffffffff
[ 3.672504] 3c20: 0101010101010101 0000000000000018 0101010101010101 0000000000000018
[ 3.680326] 3c40: ffffffffffffffff ffffffffffffffff 0000000000000019 0000000000000001
[ 3.688148] 3c60: 0000000000000010 ffff000008073db0 ffff7dfffe80ead8 ffff000008b2fac8
[ 3.695970] 3c80: ffff00000930e078 ffff000008eec000 ffff00000927046c ffff00000950b000
[ 3.703792] 3ca0: ffff00000930e068 0000000000000007 ffff00000938a720 ffff000008073d20
[ 3.711614] 3cc0: ffff000008b2fae0 ffff000008073d10 ffff000008090b8c 0000000080000045
[ 3.719436] 3ce0: ffff000008073db0 ffff000008073db0 ffffffffffffffff ffff00000930e078
[ 3.727257] 3d00: ffff000008073d20 ffff000008090b8c
[ 3.732128] [] __arm_smccc_smc+0x0/0x2c
[ 3.737519] [] optee_driver_init+0x114/0x4a8
[ 3.743344] [] do_one_initcall+0x38/0x120
[ 3.748908] [] kernel_init_freeable+0x188/0x22c
[ 3.754995] [] kernel_init+0x10/0x100
[ 3.760211] [] ret_from_fork+0x10/0x18
[ 3.765516] Code: 2a080042 b8236885 29008829 17ffffc0 (d4000003)
[ 3.771607] ---[ end trace f35df01daf70c87e ]---
[ 3.776228] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 3.776228]
[ 3.785355] SMP: stopping secondary CPUs
[ 3.789269] Kernel Offset: disabled
[ 3.792748] CPU features: 0x1802000
[ 3.796227] Memory Limit: none
[ 3.799274] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 3.799274]
1个回答
