你好! 我的是OK1012A的开发环境,
我按照文档《OK1012A-C-1GHZ-Ubuntu-用户手册-V1.3-2020.05.25.pdf》的5.5节单独编译内核及模块,编译内核及模块; 每编译一次,windows 下磁盘空间占用大2G,window10 下的硬盘空间快不足了 但是ubuntu 下看磁盘大小占用不变 root@ubuntu:/home/forlinx/work/OK10xx-linux-fs/flexbuild# df -h Filesystem Size Used Avail Use% Mounted on udev 1.4G 0 1.4G 0% /dev tmpfs 281M 3.4M 278M 2% /run /dev/sda1 98G 18G 76G 19% / tmpfs 1.4G 0 1.4G 0% /dev/shm tmpfs 5.0M 4.0K 5.0M 1% /run/lock tmpfs 1.4G 0 1.4G 0% /sys/fs/cgroup /dev/loop0 87M 87M 0 100% /snap/core/4917 /dev/loop1 56M 56M 0 100% /snap/core18/1944 /dev/loop3 13M 13M 0 100% /snap/gnome-characters/103 /dev/loop4 3.8M 3.8M 0 100% /snap/gnome-system-monitor/51 /dev/loop2 15M 15M 0 100% /snap/gnome-logs/37 /dev/loop5 90M 90M 0 100% /snap/core/6130 /dev/loop6 2.4M 2.4M 0 100% /snap/gnome-calculator/180 /dev/loop7 98M 98M 0 100% /snap/core/10583 /dev/loop8 35M 35M 0 100% /snap/gtk-common-themes/319 /dev/loop9 65M 65M 0 100% /snap/gtk-common-themes/1514 /dev/loop11 384K 384K 0 100% /snap/gnome-characters/570 /dev/loop10 141M 141M 0 100% /snap/gnome-3-26-1604/70 /dev/loop12 1.0M 1.0M 0 100% /snap/gnome-logs/100 /dev/loop13 141M 141M 0 100% /snap/gnome-3-26-1604/100 /dev/loop14 2.3M 2.3M 0 100% /snap/gnome-system-monitor/148 /dev/loop15 15M 15M 0 100% /snap/gnome-logs/45 /dev/loop16 35M 35M 0 100% /snap/gtk-common-themes/818 /dev/loop17 3.8M 3.8M 0 100% /snap/gnome-system-monitor/57 /dev/loop18 13M 13M 0 100% /snap/gnome-characters/139 /dev/loop19 141M 141M 0 100% /snap/gnome-3-26-1604/74 /dev/loop21 2.5M 2.5M 0 100% /snap/gnome-calculator/826 /dev/loop20 2.3M 2.3M 0 100% /snap/gnome-calculator/260 tmpfs 281M 16K 281M 1% /run/user/121 tmpfs 281M 28K 281M 1% /run/user/1000 怎么解决这个问题啊! 按照方法做了,没有减少占用空间,每次编译内核都会增加,早上是占用76G 到现在已经是84G了 |
3个回答
可以给Vmware虚拟机清理瘦身
ubuntu中看根本没有涨,不知道你们用的vm版本是多少,是不是和vm有关
oot@ubuntu:/# du -sh * 13M bin 73M boot 4.0K cdrom 0 dev 14M etc 10G home 0 initrd.img 0 initrd.img.old 556M lib 4.0K lib64 16K lost+found 8.0K media 8.0K mnt 4.0K opt du: cannot read directory 'proc/1775/task/1775/net': Invalid argument du: cannot read directory 'proc/1775/net': Invalid argument du: cannot access 'proc/2004/task/2004/fd/4': No such file or directory du: cannot access 'proc/2004/task/2004/fdinfo/4': No such file or directory du: cannot access 'proc/2004/fd/3': No such file or directory du: cannot access 'proc/2004/fdinfo/3': No such file or directory 0 proc 60K root du: cannot access 'run/user/1000/gvfs': Permission denied 3.2M run 12M ***in 4.0K srv 2.1G swapfile 0 sys 88K tmp 2.6G usr 1.8G var 0 vmlinuz root@ubuntu:/# |
用这个方案解决问题:从86G降为24G
虚拟机内部执行 cat /dev/zero > zero.fill;sync;sleep 1;sync;rm -f zero.fill后关闭虚拟机 宿主win10机器上进入虚拟机文件目录执行 "C:Program Files (x86)VMwareVMware Workstationvmware-vdiskmanager.exe" -k Ubuntu18.vmdk |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 02:26 , Processed in 0.954067 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3912
