验证是为了单网口ETH的方案(RGMII 的方案,在开发板试验中,进行删除 ETH0(SGMII)的复位复位 R21,嵌入式芯片 AR8031 处于备用状态) ,
运行默认的openwrt版本, uboot的提示信息 SCSI: Net: PFE classpe firmware PFEtmu pe firmware pfe_configure_serdes0 could not get PHY for PFE_MDIO: addr 1 phy_connect failed No ethernet found. 的OpenWrt [8.127382] pe_load_ddr_section:加载地址)和精灵文件地址(ffff00000948b000)RCVD [8.173327] PFE二进制版本:pfe_ls1012a_slowpath_03 [8.183188] pfe_load_elf [8.187069] pfe_ctrl_init [8.189810] pfe_ctrl_init成品 [8.193468] pfe_eth_init [8.196287] pfe_eth_mdio_init [8.207094] libphy :ls1012a MDIO总线:探测 [8.218904] pfe_phy_init INTE ** CE 3 [8.222829] libphy:PHY ls1012a-0:01未找到 [8.227606] pfe0.030pfe030pfe030pfe04003 .pfe的eth0的:pfe_eth_init_one:pfe_phy_init()失败 [8.290673] pfe_ctrl_exit [8.293306] pfe_firmware_exit [8.298353] pfe_hif_exit [8.314636] pfe_hif_release_buffers [8.318640] pfe_hif_free_descr [8.321975] pfe_hif_lib_exit [8.325241] pfe_hw_exit 根@的OpenWrt的:/#的使用ifconfig LO链路ENCAP:本地环回 INET地址:127.0.0.1掩码:255.0.0.0 INET6地址:: :1/128 作用域:主机 UP LOOPBACK RUNNING MTU:65536公制:1个 RX数据包:40个错误:0下降:0超支:0帧:0 TX数据包:40个错误:0下降:0超支: 0 组 :0 队列:0 txqueuelen:1 可看到SGMII不工作,两个网口都不能 按知识库 > LS1012A/LS1043A/LS1046A系列产品文档编号:501, 只保留RGMII单网口的修改方法,dts和pfe_eth.c,更新版本名称 如下 uboot的提示信息,(addr 1 是SGMII口,应该无法启动,去是对的) SCSI: Net: PFE class pe firmware PFE tmu pe firmware pfe_configure_serdes 0 could not get PHY for PFE_MDIO: addr 1 phy_connect failed No ethernet found . OpenWrt的修改有效果,可以顺利配置的eth0,ETH1,即使SGMII被复位住 pe_load_ddr_section:加载地址(3fb0000)和elf文件地址(ffff0000094ab000)RCVD [8.409017] PFE二进制版本:pfe_ls1012a_slowpath_03 [8.414884] pfe_load_elf [8.419007] pfe_ctrl_init [8.421877 ] pfe_ctrl_init 成品 [8.425394] pfe_eth_init [8.428166] pfe_eth_mdio_init [8.440814] libphy:ls1012a MDIO总线:探测 [8.452261] PFE 4000000.pfe的eth0的:pfe_eth_init_one:创建INTE ** CE,baseaddr:ffff00000a200000 [8.469230] pfe_eth_mdio_init [8.488017] libphy:ls1012a MDIO总线:探测 [8.498952] pfe_phy_init INTE 0.5033 pfe_phy_init inte.5033 pfe_init INTE ** 033 pfe_init INTE ** 0333 pfe_eth_mdio_init。 [8.488017]:ffff00000a220000 可以看到两个网口, 根@的OpenWrt:/#的ifconfig eth0的链接ENCAP:以太网的HWaddr 76:0C:45 :6A:F6:95 UPBROADCAST RUNING MULTICAST MTU:150 指标:1 RX 数据包:0 0 0 :0 错误:0 帧:0 TX 数据包:37 :0 :0 收费:0 过滤费:0 冲突:0 txqueuelen:1000 RX 字节:0 (0.0 B) TX 字节:4501 (4.3 KiB) eth1 Link encap:Ethernet HWaddr 62:71:65:C8:FA:CE inet6 addr: fe80::6071:65ff:fec8:face/64 Scope:Link UP 广播运行多播 MTU:1500 指标:1 RX 数据包: 12错误:0 删除:0 引用:0 包:TX 0 6 6 6 错误:0 帧数据00 删除:0 字节数据读取:0 文件传输:0 对等:txqueuelen:1000 RX:15075 (14.7 KiB) TX 字节:6932 (6.7 KiB) ETH1 (RGMII)口还可以顺利检测到网线的插拔, ETH0(SGMII)则没有响应 root@OpenWrt:/# [ 101.970697] pfe 4000000.pfe eth1: Link is Down [ 102.994826] pfe00.00.已启动- 100Mbps的/全-流量控制RX / TX [109.138705] PFE 4000000.pfe ETH1:链接已关闭 [111.186773] PFE 4000000.pfe ETH1:链接获得 但无法启动- 100Mbps的控制/ ethrx1tl通过DHCP获得IP,手动设置IP,也无法ping网关 root@OpenWrt:/# ifconfig eth1 192.168.3.66 root@OpenWrt:/# ping 192.168.3.1 PING 192.168.3.1 (192.168.3.1): 56 bytes 可能 会什么原因?单网口方案如何进行下去,请大家给点建议,谢谢 |
4个回答
一点呼吸,正常软件和硬件,如果在uboot中没有运行
=>fpe停止 进入openwrt,也是会网口无法接收的现象出现 uboot固定的SGMII会影响 初始化失败,会openwrt中的网口操作 |
在开发板尝试保留SGMII,复位RGMII,根据文档调整DTS,测试结果
的uboot中可以检测到的eth0,ETH1报错,配置完IPADDR,eth0的可以正常使 用 展示进入的OpenWrt,顺利初始化通过 根@的OpenWrt:/#的ifconfig BR -lan Link encap:Ethernet HWaddr 76:0C:45:6A:F6:95 inet addr:192.168.1.1 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fd7f:8300:1/Global Global inet6 addr: fe80::740c:45ff:fe6a:f695/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packet:0 errors:0 drops:0 overruns :0 frame:0 TX packets:39 errors: 0 丢弃:0 溢出:0 载波:0 冲突:0 txqueuelen:1000 RX 字节:0 (0.0 B) TX 字节:4801 (4.6 KiB) eth0 Link encap:Ethernet HWaddr 76:0C:45:6A:F6:95 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packet:0 errors:0 drop:0 overruns:0 frame:0 TX packets:39 errors:0丢弃:0 溢出:0 载波:0 冲突:0 txqueuelen:1000 RX 字节:0 (0.0 B) TX 字节:4801 (4.6 KiB) eth1 链接封装:以太网 HWaddr 62:71:65:C8:FA:CE inet addr :192.168.3.99 Bcast:192.168.3.255 掩码:255.255.255.0 inet6 addr: fe80::6071:65ff:fec8:face/64 Scope:Link UP BROADCAST RUNNING MULTICAST packet:4RX0:4RX 错误:0 溢出:0 帧:0 TX 数据包:93 错误:0 丢弃:0 溢出:0 载波:0 Collins:0 txqueuelen:1000 RX bytes:56025 (54.7 KiB) TX bytes:23426 (22.8 KiB) SGMII可以检测到网插拔,但无法获取ip,手动配置后,也无法ping通 网关 |
对的,直接把SGMII的复位电阻R21去掉,然后下拉到GND,软件直接按文档修改修改
弓/ arm64的/ boot / DTS /飞思卡尔/ FSL-ls1012a-rdb.dts 驱动器/分期/ fsl_ppfe / pfe_eth.c 然后重新生成的OpenWrt,需要注意生成的驱动pfe.ko,不会自动拷贝到STAGING_DIR目 录中根layerscape中,我都是从build_dir中linux的目录, build_dir /目标aarch64_generaic_musl / Linux的layerscape_armv8_64b 把FSL-ls1012- rdb.dtb和fpe.ko生成拷贝出来,可以检查一下时间,确认修改生效 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
谁有3566+电池+POE充电的方案,有个项目需要用该功能的主板
437 浏览 0 评论
RK3588的GMAC0与PHY的参考时钟电平匹配问题??????
4425 浏览 1 评论
请问各位大佬,如何解决,瑞芯微 RV1126B 使用 mpp 自带工具 调试时,内核直接报错崩溃!
1802 浏览 0 评论
使用rk3568开发板,核0\\1\\3运行linux,核2运行hal,在核0中怎么关闭核2
2359 浏览 0 评论
2363 浏览 0 评论
/9
GMT+8, 2025-12-2 02:38 , Processed in 1.965197 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1580
