你是改的源码里的小区吗,还是在子里的格式化的,还是在烧我们的板镜像也不行吗
在子里面格式化的,用网盘上的下载镜像也不行 otg烧写就报错 烧写板失败请用亮文件有效并且智能设备可以工作。 SD卡量产烧用终端正常查看
HELLO!BOOT0 正在启动! [ 0.35]你好!BOOT0 正在启动! [0.39] BOOT0提交:b58d49ff80aa5ff8865ab68aa2463d4ee0fe1e7d [0.46] BOOT0版本:4.0 [0.50]组PLL启动 [0.54]组PLL端 [0.89] RTC [0]值= 00000000 [0.92] RTC [1]值= 00000000 [0.95] RTC [2] 值 = 0x00000000 [0.98]rtc[3] 值 = 0x00000000 [0.102]rtc[4] 值 = 0x00000000 [0.105]rtc[5] 值 = 0x00000000 [ 0.105]rtc[5] 值 = 0x00000000 [0.100000000] DR100000000 [ 0.10000000] DR DRAM: 0.100000000 [ 0.10000000 ] V1.1 [ 0.115]发现A40 [0.117]找到A40 [0.119]找到A40 [0.121]找到A40 [0.123]找到A40 [0.129] PMU:[0.130] AXP221 [0.132] DDR电压= 1250 MV [0.139] PMU:[0.140] AXP221 [0.142] DDR电压 = 1250 mv [ 0.153] PMU: [ 0.154]AXP221 [ 0.156]ddr 电压 = 1500 mv [ 0.166]DRAM CLK =576 MHZ [ 0.169]DRAM 类型 =3 (2:DDR2,3:DDR3,6:LPDDR2) :LPDDR3) [ 0.174] DRAM zq 值:0x003b3bfb [ 0.180] DRAM SIZE = 2048 M [ 0.183] DRAM ** 测试OK。 [ 0.186] dram size =2048 [ 0.189] rtc 待机标志为 0x00000000,超级待机标志为 0x00000000 [ 0.196] 卡号为 0 [ 0.199]sdcard 0 line count 4 [ 0.202][mmc]: mmc driver ver 2016-07-01 15:30 [ 0.206][mmc]: sdc0 spd mode error, 2 [ 0.219][mmc]: Wrong media type 000000 [ 0.223][mmc]:***尝试 SD 卡 0*** [ 0.243][mmc]:HSSDR52/SDR25 4 位 [0.246][mmc]:50000000 Hz [0.249][mmc]:30436 MB [0.251 MB ] [mmc]: ***SD/MMC 0 init OK!!!*** [ 0.347] 成功从 sdmmc flash 加载 uboot。 [0.352]Entry_name = u-boot [0.368]准备禁用 icache。 [0.371]跳转到第二个启动。 U-Boot 2014.07 (Jan 19 2020 - 05:27:12) Allwinner Technology uboot commit : ffae925c54abddcfc8f616c65bb6eb8a3076b947 i2c_init: by cpux i2c_init ok [ 0.386]pmbus: 就绪 [ 0.400] PMU: AXP221 [ 0.400] PMU: AXP22x found [ 0.401] PMU: dcdc2 1160 [ 0.402] PMU: cpux 1008 Mhz6,Ahz0z0z0z0zAhz0 ,APB1 = 100Mhz的的MBus = 400Mhz的 上体积至设定的功率默认 dcdc1_vol = 3300,ONOFF = 1 dcdc2_vol = 1160,ONOFF = 1 dcdc3_vol = 1200,ONOFF = 1 dcdc4_vol = 1100,ONOFF = 0 aldo1_vol = 3300,ONOFF = 1 aldo2_vol = 1800, onoff=1 aldo3_vol = 3000, onoff=1 dc1sw_vol = 3000, onoff=0 dc5ldo_vol = 1100, onoff=0 dldo1_vol = 3300, onoff=1 dldo2_vol = 3300, on3off=0dldo_vol = 3300, on30_vol = 30d30d30 ,开关=1 eldo1_vol = 2800,ONOFF = 0 eldo2_vol = 1200,ONOFF = 1 eldo3_vol = 2800,ONOFF = 1 gpio0_vol = 3300,ONOFF = 1 gpio1_vol = 3300,ONOFF = 1 找到power_sply结束 VBUS存在 DRAM:2吉布 FDT地址:0xb6e8dbf8 搬迁偏移量是:75ee4000 axp: get node[charger0] error In: serial Out: serial Err: serial gic: normal mode [0.534]start drv_disp_init init_clocks: 完成init_clocks。 pwm_request: reg = 0x1c23400。pwm = 0. 请求 pwm 成功,pwm = 0. tv_init: tv_probe:000 tv0 没有 type1 tv0 没有 type2 tv0 没有 type3 没有报告hpd工作,您需要支持开关类! 屏幕 0 不支持电视! 屏幕1不支持电视! 屏幕 0 不支持 VGA 类型! 屏幕 1 不支持 VGA TYPE! tv_init: drv_disp_init 完成 获取脚本数据 boot_disp.output_disp 失败 获取脚本数据 boot_disp.output_type 失败 获取脚本数据 boot_disp.output_mode 失败 获取脚本数据 boot_disp.auto_hpd 失败 disp0 设备类型(1) enable disp 0, clk: pll(3060000000) (3.06亿),DCLK(51000000)dsi_rate(3.06亿) CLK实:PLL(308571428),CLK(308571428),DCLK(51428571)dsi_rate(0) 使能电源VCC-LCD,RET = 0 [1.301]端 工作模式= 17,存储类型 = 1 [ 1.301]NAND_UbootProbe start [ 1.303]NB1 : enter phy init [ 1.306]nand_physic_init [ 1.423]Reset NDFC start 0 0 [ 1.423]Reset NDFC end 0 0 [ 1.424]n 不支持!通道0芯片0:fe fe fe fe fe fe fe fe [1.430]nand不支持!通道0芯片1:fe fe fe fe fe fe fe fe [1.436]nand不支持!通道0芯片2:fe fe fe fe fe fe fe fe [1.443]nand不支持!通道 0 芯片 3:fe fe fe fe fe fe fe fe [1.449] 没有找到! [1.452]nand_physic_init nand_build_nsi 错误 [1.498]nand_physic_init 错误-1 [1.498]NB1:nand phy init 失败 [1.500]NB1:输入 phy 退出 [ 1.503]nand_physic_exit [ 1.506]NAND_UbootProbe end: 0xffffffff try nand fail try nand fail try card 2 [mmc]: mmc driver ver 2016-07-01 15:50:00 [mmc]: mmc_update_timing_s SUNXINO/ 2 : 2 [mmc]: 50 MHz... [mmc]: 样本: 63 - 158(ps) [mmc]: ds: 63 - 158(ps) [mmc]: 100 MHz... [mmc]: 样本: 34 - 147(ps) [mmc]: ds: 34 - 147(ps) [mmc]: 200 MHz... [mmc]: 样本: 17 - 147(ps) [mmc]: ds: 17 - 147(ps) ) [mmc]: ************Try SD card 2************ [mmc]: mmc 2 cmd 8 timeout, err 100 [mmc]: smc 2 err, cmd 8, RTO [mmc]: mmc 2 关闭总线门控并复位 [mmc]: mmc 2 mmc cmd 8 err 0x00000100 [mmc]: mmc 如果 cond 失败则发送 [mmc]: mmc 2 cmd 55 timeout, err 100 [mmc]: smc 2 err, cmd 55, RTO [mmc]: mmc 2关闭总线门控并重置 [mmc]: mmc 2 mmc cmd 55 err 0x00000100 [mmc]: send app cmd failed [mmc]: ************Try MMC card 2****** ****** [mmc]:主机大写:0x6f [mmc]:MID 000013 PSN 112eff11 [mmc]:PNM Q2J55L -- 0x51-32-4a-35-35 [mmc]:PRV 1.0 [mmc]:MDT m-7 y-2020 [mmc]:MMC v5.0 [mmc]:速度模式:HSSDR52/SDR25 [mmc]:时钟:50000000 Hz [mmc]:bus_width:8 位 [mmc]:用户容量:7264 MB [ mmc]:启动容量:16384 KB [mmc]: rpmb 容量: 4096 KB [mmc]: ************SD/MMC 2 init OK!!!************ [mmc]:使用默认速度模式:1-HSSDR52/SDR25, ifreq: 2 [mmc]: ========best spd md: 1-HSSDR52/SDR25, freq: 2-50000000 [mmc]: 已经在 HSSDR52_SDR25 模式 [ mmc]:erase_grp_size:0x400WrBlk*0x200=0x80000 字节 [mmc]:secure_feature:0x55 [mmc]:secure_removal_type:0x1 [mmc]:EOL 信息(Rev blks):正常 [mmc]:磨损(类型) -10% life time used [mmc]: Wear out(type B): 0%-10% life time used [mmc]: mmc driver ver 2016-07-01 15:50:00 [mmc]: boot_card_no error 2 SUNXI SD/MMC: 2, SUNXI SD/MMC: 0 [mmc]: 50 MHz... [mmc]: 样本: 63 - 158(ps) [mmc]: 100 MHz... [mmc]: 样本: 34 - 147(ps) [mmc]: 200 MHz... [mmc]: 样本: 17 - 147(ps) [mmc]: **** ********尝试 SD 卡 0************ [mmc]:主机大写:0x27 [mmc]:MID 03 PSN a7e284e7 [mmc]:PNM SD32G -- 0x53- 44-33-32-47 [mmc]:PRV 8.5 [mmc]:MDT m-3 y-2021 [mmc]:速度模式:HSSDR52/SDR25 [mmc]:时钟:50000000 Hz [mmc]:总线宽度:4 位 [mmc]:用户容量:30436 MB [mmc]:************SD/MMC 0 init OK!!!************ [mmc]: erase_grp_size:0x1WrBlk*0x200=0x200 字节 [mmc]:secure_feature:0x0 [mmc]:secure_removal_type:0x0 mmc init ok 从启动 USB 烧毁:非启动模式 [1.948]inter uboot shell 不支持写入密钥!!! 闪秘错误!!! 按任意键停止自动引导:0 的工作模式= 0×11 运行卡精灵 尝试sprite_led_gpio配置 [1.958]精灵孙鑫开始 取脚本数据boot_disp.output_full失败 screen_id = 0,SCREEN_WIDTH = 1024,SCREEN_HEIGHT = 600 帧缓冲区地址b7f2eed0 board_display_show_until_lcd_open SCREEN_WIDTH = 1024 screen_height = 600 bar x1: 256 y1: 260 bar x2: 768 y2: 340 读取 font32.sft FAT:未对齐的缓冲区地址 (b8186ff8) 163 ms (2.1 MiB/s) 读取 357443 字节 [SFTE_Set_Pixel_Sizes_i] 407 buf_size is 2304 cur_pixel_size 32 pixel_size 32 [ 2.190]firmware probe ok [ 2.190]fetch download map *************DOWNLOAD MAP DUMP*********** * 总下载第 5 部分 下载部分[0] 名称:引导资源 下载部分[0] 下载文件:BOOT-RESOURCE_FE 下载部分[0] 验证文件:VBOOT-RESOURCE_F 下载部分[0] lenlo :0x3800 下载部分[0] addrlo :0x8000 下载部分[0] 加密:0x0 下载部分[0] 验证:0x1 下载部分[1] 名称:env 下载部分[1] 下载文件:ENV_FEX000000000 下载部分[1] 验证文件:VENV_FEX00000000 下载部分[1] lenlo :0x2000 下载部分[1] addrlo :0xb800 下载部分[1] 加密:0x0 下载部分[1] 验证:0x1 下载部分[2] 名称:引导 下载部分[2] 下载文件:BOOT_FEX00000000 下载部分[2] 验证文件:VBOOT_FEX0000000 下载部分[2] lenlo :0x8000 下载部分[2] addrlo :0xd800 下载部分[2] 加密:0x0 下载部分[2] 验证:0x1 下载部分[3] 名称:rootfs 下载部分[3] 下载文件:ROOTFS_FEX000000 下载部分[3] 验证文件:VROOTFS_FEX00000 下载部分[3] lenlo :0x200000 下载部分[3] addrlo :0x15800 下载部分[3] 加密:0x0 下载部分[3] 验证:0x1 下载部分[4] 名称:usr 下载部分[4] 下载文件:USR-RESOURCE_FEX 下载部分[4] 验证文件:VUSR-RESOURCE_FE 下载部分[4] ] lenlo :0xcf5800 下载部分[4] addrlo :0x21d800 下载部分[4] encrypt :0x0 下载部分[4] 验证:0x1 [ 2.328]fetch mbr 0 mbr 表正常 1 mbr 表正常 2 mbr 表好的 3 mbr 表没问题 *************MBR DUMP*************** 总 mbr 第 7 部分 [0] 名称:引导资源 部分[0] 类名:磁盘 部分[0] 地址:0x8000 part[0] lenlo :0x3800 part[0] user_type :32768 part[0] keydata :0 part[0] ro :0 part[1] name :env part[1] classname :DISK part[1] addrlo :0xb800 part [1] lenlo :0x2000 part[1] user_type :32768 part[1] keydata :0 part[1] ro :0 part[2] name :boot part[2] classname :DISK part[2] addrlo :0xd800 part[ 2] lenlo :0x8000 part[2] user_type :32768 part[2] keydata :0 part[2] ro :0 part[3] name :rootfs part[3] classname :DISK part[3] addrlo :0x15800 part[3] ] lenlo:0x200000 部分[3] 用户类型:32768 part[3] keydata :0 part[3] ro :0 part[4] name :private part[4] classname :DISK part[4] addrlo :0x215800 part[4] lenlo :0x8000 part[4] user_type :32768 part [4] keydata :0 part[4] ro :0 part[5] name :usr part[5] classname :DISK part[5] addrlo :0x21d800 part[5] lenlo :0xcf5800 part[5] user_type :32768 part[ 5] keydata :0 part[5] ro :0 part[6] name :UDISK part[6] classname :DISK part[6] addrlo :0xf13000 part[6] lenlo :0x0 part[6] user_type :0 part[6] ] 密钥数据:0 部分 [6] ro :0 *************MBR DUMP**************** 总 mbr 部分 7 部分 [0] 名称:引导资源 部分 [0] 类名:磁盘 part[0] addrlo :0x8000 part[0] lenlo :0x3800 part[0] user_type :0x8000 part[0] keydata :0x0 part[0] ro :0x0 part[1] name :env part[1] classname :DISK part [1] addrlo :0xb800 part[1] lenlo :0x2000 part[1] user_type :0x8000 part[1] keydata :0x0 part[1] ro :0x0 part[2] name :boot part[2] classname :DISK part[ 2] addrlo :0xd800 part[2] lenlo :0x8000 part[2] user_type :0x8000 part[2] keydata :0x0 part[2] ro :0x0 部分[3] 名称:rootfs 部分[3] 类名:磁盘 部分[3] addrlo:0x15800 部分[3] lenlo:0x200000 部分[3] 用户类型:0x8000 部分[3] 密钥数据:0x0 部分[3] ro :0x0 部分[4]名称:私有 部分[4]类名:磁盘 部分[4]地址:0x215800 部分[4]lenlo:0x8000 部分[4]用户类型:0x8000 部分[4]密钥数据:0x0 部分[4]ro:0x0 部分[ 5] name :usr part[5] classname :DISK part[5] addrlo :0x21d800 part[5] lenlo :0xcf5800 part[5] user_type :0x8000 part[5] keydata :0x0 part[5] ro :0x0 part[6] ] 名称:UDISK 部分 [6] 类名:DISK part[6] addrlo :0xf13000 part[6] lenlo :0x0 part[6] user_type :0x0 part[6] keydata :0x0 part[6] ro :0x0 [2.568]开始擦除闪存 总部分:8 mbr 0, 8000 , 8000 boot-resource 1, 3800, 8000 env 2, 2000, 8000 boot 3, 8000, 8000 rootfs 4, 200000, 8000 private 5, 8000, 8000 usr 800 , 00 flash 07 不需要擦除00 cf8K 私有部分存在 0 mbr 表正常 1 mbr 表正常 2 mbr 表正常 3 mbr 表正常 *************MBR DUMP******** ******* 总 mbr 第 7 部分 [0] 名称:引导资源 part[0] classname :DISK part[0] addrlo :0x8000 part[0] lenlo :0x3800 part[0] user_type :32768 part[0] keydata :0 part[0] ro :0 part[1] name :env part [1] 类名:磁盘 部分[1] addrlo :0xb800 部分[1] lenlo :0x2000 部分[1] 用户类型:32768 部分[1] 密钥数据:0 部分[1] ro :0 部分[2] 名称:引导 部分[ 2] 类名:磁盘 部分[2] addrlo :0xd800 部分[2] lenlo :0x200000 部分[2] 用户类型:32768 部分[2] 密钥数据:0 部分[2] ro :0 部分[3] 名称:rootfs 部分[3] ] 类名:磁盘 部分 [3] 地址:0x20d800 part[3] lenlo :0x200000 part[3] user_type :32768 part[3] keydata :0 part[3] ro :0 part[4] name :private part[4] classname :DISK part[4] addrlo :0x40d800 part [4] lenlo :0x200000 part[4] user_type :32768 part[4] keydata :0 part[4] ro :0 part[5] name :usr part[5] classname :DISK part[5] addrlo :0x60d800 part[ 5] lenlo :0x200000 part[5] user_type :32768 part[5] keydata :0 part[5] ro :0 part[6] name :UDISK part[6] classname :DISK part[6] addrlo :0x80d800 part[6] ] lenlo :0x0 部分 [6] user_type :0 part[6] keydata :0 part[6] ro :0 开始存储数据 part name boot-resource keydata = 0x0 part name env keydata = 0x0 part name boot keydata = 0x0 part name rootfs keydata = 0x0 part name private keydata = 0x0 find keypart private keypart read start: 0x40d800, blocks 0x200000 sprite protection private data failure : cant malloc memory for part private, seconds 0x200000 sunxi sprite error: erase flash err sprite_test - do a sprite test sunxi# |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1630 浏览 1 评论
RK3568平台,进入烧录模式,部分电脑提示无法识别,无法烧录
5103 浏览 1 评论
【RK3568 Android11.0】如何在设置-显示-HDMI-分辨率设置中添加3840*2160的选项?
7537 浏览 1 评论
瑞芯微第二代8nm高性能AIOT平台 RK3576 详细介绍
1805 浏览 0 评论
7513 浏览 1 评论
GMT+8, 2024-5-21 11:50 , Processed in 0.713765 second(s), Total 74, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
