敬爱的ti工程师,晚上好: 我在用你们提供的烧写脚本烧写EMMC后启动无输出,EMMC挂载在EMMC1上,下面是打印烧写打印日志: **************************************************** **************************************************** Sitara Example Flashing Script - 02/11/2014 1+0 records in 1+0 records out Found mounted partition(s) on /dev/mmcblk1: /media/mmcblk1p1 /media/mmcblk1p2 4k erase on /dev/mmcblk1p1 1+0 records in 1+0 records out 4k erase on /dev/mmcblk1p2 1+0 records in 1+0 records out Partitioning the eMMC... Checking that no-one is using this disk right now ... [ 64.472029] mmcblk1: unknown partition table OK Disk /dev/mmcblk1: 470 cylinders, 255 heads, 63 sectors/track sfdisk: ERROR: sector 0 does not have an msdos signature sfdisk: /dev/mmcblk1: unrecognized partition table type Old situation: sfdisk: No partitions found New situation: Units = cylinders of 8225280 bytes, blocks of 1024 bytes, counting from 0 Device Boot Start End #cyls #blocks Id System /dev/mmcblk1p1 * 0+ 8 9- 72261 c W95 FAT32 (LBA) /dev/mmcblk1p2 10 469 460 3694950 83 Linux /dev/mmcblk1p3 0 - 0 0 0 Empty /dev/mmcblk1p4 0 - 0 0 0 Empty Successfully wrote the new partition table Re-reading the partition table ... [ 64.676928] mmcblk1: p1 p2 If you created or changed a DOS partition, /dev/foo7, say, then use dd(1) to zero the first 512 bytes: dd if=/dev/zero of=/dev/foo7 bs=512 count=1 (See fdisk(8).) [ 65.249980] EXT4-fs (mmcblk1p1): VFS: Can't find ext4 filesystem [ 65.258169] EXT4-fs (mmcblk1p2): VFS: Can't find ext4 filesystem [ 65.265510] EXT3-fs (mmcblk1p1): error: can't find ext3 filesystem on dev mmcblk1p1. [ 65.274429] EXT3-fs (mmcblk1p2): error: can't find ext3 filesystem on dev mmcblk1p2. [ 65.283337] EXT2-fs (mmcblk1p1): error: can't find an ext2 filesystem on dev mmcblk1p1. [ 65.292466] EXT2-fs (mmcblk1p2): error: can't find an ext2 filesystem on dev mmcblk1p2. [ 65.301818] FAT-fs (mmcblk1p1): bogus number of reserved sectors [ 65.308116] FAT-fs (mmcblk1p1): Can't find a valid FAT filesystem [ 65.315328] FAT-fs (mmcblk1p2): bogus number of reserved sectors [ 65.321616] FAT-fs (mmcblk1p2): Can't find a valid FAT filesystem [ 65.352864] cramfs: wrong magic [ 65.360591] FAT-fs (mmcblk1p1): bogus number of reserved sectors [ 65.366941] FAT-fs (mmcblk1p1): Can't find a valid FAT filesystem [ 65.375395] F2FS-fs (mmcblk1p1): Magic Mismatch, valid(0xf2f52010) - read(0x0) [ 65.383007] F2FS-fs (mmcblk1p1): Can't find a valid F2FS filesystem [ 65.389871] cramfs: wrong magic [ 65.396804] FAT-fs (mmcblk1p2): bogus number of reserved sectors [ 65.403158] FAT-fs (mmcblk1p2): Can't find a valid FAT filesystem [ 65.424036] F2FS-fs (mmcblk1p2): Magic Mismatch, valid(0xf2f52010) - read(0x0) [ 65.431682] F2FS-fs (mmcblk1p2): Can't find a valid F2FS filesystem No partition found. Continuing. 1+0 records in 1+0 records out Formatting the eMMC into 2 partitions... mkfs.vfat 2.11 (12 Mar 2005) mke2fs 1.42.1 (17-Feb-2012) Discarding device blocks: done Filesystem label=rootfs OS type: Linux Block size=4096 (log=2) Fragment size=4096 (log=2) Stride=0 blocks, Stripe width=0 blocks 231072 inodes, 923737 blocks 46186 blocks (5.00%) reserved for the super user First data block=0 Maximum filesystem blocks=947912704 29 block groups 32768 blocks per group, 32768 fragments per group 7968 inodes per group Superblock backups stored on blocks: 32768, 98304, 163840, 229376, 294912, 819200, 884736 Allocating group tables: done Writing inode tables: done Creating journal (16384 blocks): done Writing superblocks and filesystem accounting information: done Formatting done. [ 78.733319] kjournald starting. Commit interval 5 seconds [ 78.741038] EXT3-fs (mmcblk1p2): using internal journal [ 78.746521] EXT3-fs (mmcblk1p2): mounted filesystem with ordered data mode Copying Files... real 0m 0.41s user 0m 0.23s sys 0m 0.14s Boot partition done. real 0m 0.96s user 0m 0.55s sys 0m 0.35s RootFS partition done. It took 20 seconds to complete this task... ******************************************** Sitara Example Flash Script is complete. |
10个回答
看打印已经烧写成功了啊,是在BBB板子上测试的么?
嗯嗯 是烧写成功了 不是用BBB的板子,我们参照BBB做的核心板 挂载emmc分区也可看到文件了 可拨回EMMC启动,串口就是没有任何输出 下面是分区情况: 看着感觉都没什么错误了 |
我在u-boot下加载emmc中的内核到DDR中,并去启动,是OK的, 问题可能是就出在启动上了 |
启动顺序是怎么设置的? |
您好,请问下: 如果我要把boot分区文件系统改成FAT16是否这样修改即可: sfdisk -D -H 255 -S 63 -C $CYLINDERS $DRIVE << EOF ,9,0x0e,* 10,,,- EOF mkfs.vfat -F 16 -n "boot" $[DRIVE]p1 可这样修改完的分区好像没有boot属性 就是system下的标识是c 而不是e 可能我的理解是错的 |
请问有移植SDIO WIFI 基于设备树的教程吗 我找到的 WL127x_Porting_Guide是板级代码的 |
咨询下,这个问题,你最后是怎么解决的。我这边,也是用了官方的脚本, 完成了烧写。但是也是启动的时候,一直在打印 CCCCCC。。 |
只有小组成员才能发言,加入小组>>
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
661 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
587 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1041 浏览 1 评论
720 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
516 浏览 1 评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
150浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
115浏览 14评论
在使用3254进行录音的时候出现一个奇怪的现象,右声道有吱吱声,请教一下,是否是什么寄存器设置存在问题?
119浏览 13评论
TLV320芯片内部自带数字滤波功能,请问linein进来的模拟信号是否是先经过ADC的超采样?
117浏览 12评论
TPA6304-Q1: TPA6304 两片公用一组I2C的话,其中一片配置不成功怎么办
159浏览 10评论
GMT+8, 2024-11-19 11:41 , Processed in 1.088788 second(s), Total 97, Slave 81 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
