更换了mipi屏幕,使用ili9881c驱动,
设备树中修改内容如下: &mipi_dsi { status = "okay"; panel@0 { /*compatible = "forlinx,mipi7";*/ compatible = "ilitek,ili9881c"; reg = <0>; reset-gpios = <&gpio1 9 0>; dsi-lanes = <4>; vddio-mode = <2>; }; ... } 在drivers/gpu/drm/panel/中增加panel-ilitek-ili9881c.c,相应修改deconfg,Kconfig,Makefile。 编译通过,烧到板中以后打印信息如下: [ 1.247836] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 1.254493] [drm] No driver support for vblank timestamp query. [ 1.260528] imx-drm display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops) [ 1.268247] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200 [ 1.275376] ili9881c start probe [ 1.278731] ili9881c-dsi 32e10000.mipi_dsi.0: 32e10000.mipi_dsi.0 supply power not found, using dummy regulator [ 1.288904] get gpio suc [ 1.288907] find node backlight suc [ 1.295032] add panel suc [ 1.297803] imx-drm display-subsystem: bound 32e10000.mipi_dsi (ops imx_sec_dsim_ops) [ 1.309297] imx-drm display-subsystem: fb0: frame buffer device [ 1.315665] [drm] Initialized imx-drm 1.0.0 20120507 for display-subsystem on minor 0 …… [ 8.333126] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 8.352641] 8021q: 802.1Q VLAN Support v1.8 [ 8.586968] imx_sec_dsim_drv 32e10000.mipi_dsi: wait pkthdr tx done time out [ 8.594168] imx_sec_dsim_drv 32e10000.mipi_dsi: panel disable failed: -16 [ 8.858952] imx_sec_dsim_drv 32e10000.mipi_dsi: wait pkthdr tx done time out [ 8.920904] ili9881c start prepare [ 8.938885] power panel suc [ 9.098897] reset gpio suc [ 9.354907] imx_sec_dsim_drv 32e10000.mipi_dsi: wait payload tx done time out [ 9.362068] send cmd 0 times [ 9.365123] imx_sec_dsim_drv 32e10000.mipi_dsi: panel prepare failed: -16 [ 9.374332] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.391354] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.452893] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.463703] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.491609] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.502167] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.530326] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.541565] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.569021] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.580252] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.607761] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.618398] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.645975] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.656868] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.684645] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.695288] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.723336] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.733872] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.762061] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.772889] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.800797] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.811492] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.839470] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.850009] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.878203] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector [ 9.889162] imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector …… 请问imx_sec_dsim_drv 32e10000.mipi_dsi: no bus formats assigned by connector这个问题需要修改什么可以解决 |
1个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
基于米尔瑞芯微RK3576核心板/开发板的人脸疲劳检测应用方案
678 浏览 0 评论
920 浏览 1 评论
814 浏览 1 评论
2030 浏览 1 评论
3275 浏览 1 评论
GMT+8, 2024-12-25 03:15 , Processed in 0.401427 second(s), Total 42, Slave 36 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
