再手动一步,到make时出错
root@hp-HP-348:/home/forlinx/imx8mm/OK8MM-linux-sdk#make ================== = ============ 构建Linux内核 ==================================== make -j 4 -C /home/forlinx/imx8mm/OK8MM-linux-sdk/OK8MM-linux-kernel defconfig LDFLAGS= make[1]: 进入目录'/home/forlinx/imx8mm/OK8MM-linux-sdk/ OK8MM- linux-kernel ***默认配置基于'x86_64_defconfig' ##配置'写入 .config # make[1]:离开目录'/home/forlinx/imx8mm/OK8MM-linux-sdk/OK8MM-linux-内核' make - j 4 -C /home/forlinx/imx8mm/OK8MM-linux-sdk/OK8MM-linux-kernel LDFLAGS= make[1]: 进入目录'/home/forlinx/imx8mm/OK8MM-linux-sdk/OK8MM-linux-kernel ' 脚本/kconfig/conf --silentoldconfig Kconfig CHK include/config/kernel.release CHK include/generated/uapi/linux/version.h DESCEND objtool CHK include/generated/utsrelease.h CHK scripts/mod/devicetable-offsets.h CHK include/generated/timeconst.h CHK include /generated/bounds.h CHK include/generated/asm-offsets.h CALL scripts/checksyscalls.sh CHK include/generated/compile.h CC驱动程序/md/dm-rq.o 驱动程序/md/dm-rq. c:在函数“dm_old_init_request_queue”中: drivers/md/dm-rq.c:716:2:错误:函数“elv_register_queue”的隐式声明[-Werror=implicit-function-declaration] elv_register_queue(MD->广播) ; ^ AR 驱动程序/md/dm-mirror.o CC 驱动程序/md/dm-log.o CC1:警告一些被视为错误 脚本/Makefile.build:328 :目标'的驱动/ MD / DM-rq.o的配方'失败 补充[3]:*** [驱动程序/ MD / DM-rq.o]错误 1 make[3]: *** 正在等待未完成的任务.... CC drivers/pci/access.o scripts /Makefile.build:587: recipe for target 'drivers/md' failed make[2]: *** [drivers/md] Error 2 make[2]: *** 正在等待未完成的任务.. CC驱动程序/pci/bus.o CC驱动程序/pci/probe.o CC驱动程序/ pci/host-bridge.o CC 驱动程序/pci/remove.o CC 驱动程序/pci/pci.o CC 驱动程序/pci/pci-driver。 ○ CC 驱动程序/pci/search.o CC 驱动程序/pci /pci-sysfs.o CC 驱动程序/pci/rom.o CC 驱动程序/pci/setup-res.o CC 驱动程序/pci/irq.o CC 驱动程序/pci/vpd .o CC 驱动程序/pci/setup-bus.o CC 驱动程序/pci/vc.o CC 驱动程序/pci/mmap.o CC 驱动程序/pci/setup-irq.o CC驱动程序/pci/proc.o CC 驱动程序/pci /slot.o CC 驱动程序/pci/quirks.o AR 驱动程序 /pci/host/built-in.o CC 驱动程序/pci/hotplug/pci_hotplug_core.o CC驱动程序/pci/pcie/aspm.o AR驱动程序/pci/switch /built-in.o CC驱动程序/pci/hotplug-pci.o CC驱动程序/pci/hotplug/acpi_pcihp.o CC驱动程序/ pci/msi.o CC 驱动程序/pci/pcie/portdrv_core.o AR 驱动程序/pci/hotplug/pci_hotplug.o AR 驱动程序/pci/hotplug/built-in.o CC 驱动程序/pci/htirq.o CC驱动程序/pci/ats.o CC 驱动程序/pci/pcie/portdrv_pci.o CC 驱动程序/pci/pci-acpi.o CC 驱动程序/pci/pci-label.o CC 驱动程序/pci /pcie/portdrv_bus.o CC 驱动程序/pci/ pcie/portdrv_acpi.o CC驱动程序/pci/pcie/aer/aerdrv_errprint.o CC驱动程序/pci/pcie/pme.o CC驱动程序/pci/pcie/aer/aerdrv_core.o AR驱动程序/pci/pcie/ pcieportdrv.o CC驱动程序/pci/pcie/aer/aerdrv.o CC驱动程序/ PCI / PCIE / AER / aerdrv_acpi.o AR驱动程序/ PCI / PCIE / AER / aerdriver.o AR驱动程序/ PCI / PCIE / AER /√in.o AR驱动程序/ PCI / PCIE /√ in.o AR驱动程序/pci/built-in.o Makefile:1039: 目标“驱动程序”的配方失败 make[1]: *** [驱动程序] 错误 2 make[1]: 离开目录 '/home/forlinx/imx8mm/OK8MM -linux-sdk/OK8MM-linux-kernel' Makefile:11: 目标 'linux' 的配方失败 make: *** [linux] 错误 2 |
2个回答
用我们提供的环境变量,环境变量都被设置了,启动虚拟机或者打开新的外壳窗口都需要重新设置执行环境变量。
刚开始用自己的linux,会出错,今天用虚拟机打开资料里面的开发环境,成功了。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1988 浏览 1 评论
synopsys 的design ware:DW_fpv_div,浮点数除法器,默认32位下,想提升覆盖率(TMAX),如果用功能case去提升覆盖率呢?
2490 浏览 1 评论
RK3588 GStreamer调试四路鱼眼摄像头四宫格显示报错
5272 浏览 1 评论
【飞凌嵌入式OK3576-C开发板体验】RKNN神经网络-YOLO图像识别
254 浏览 0 评论
【飞凌嵌入式OK3576-C开发板体验】SSH远程登录网络配置及CAN通讯
1336 浏览 0 评论
GMT+8, 2024-11-25 06:09 , Processed in 0.678614 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
