电子发烧友论坛扫一扫,分享给好友
[OHOS ERROR] ~/tools/gcc-arm-none-eabi-10-2020-q4-major/bin/arm-none-eabi-objcopy -O binary -R .xip audio_demo.elf audio_demo.bin
[OHOS ERROR] ~/tools/gcc-arm-none-eabi-10-2020-q4-major/bin/arm-none-eabi-size audio_demo.elf [OHOS ERROR] text data bss dec hex filename [OHOS ERROR] 1152240 8032 76248 1236520 12de28 audio_demo.elf [OHOS ERROR] ~/tools/gcc-arm-none-eabi-10-2020-q4-major/bin/arm-none-eabi-objcopy -O binary -j .xip audio_demo.elf audio_demo_xip.bin [OHOS ERROR] cp audio_demo_xip.bin ../image/"xr806"/app_xip.bin [OHOS ERROR] cd ../image/"xr806" && [OHOS ERROR] chmod a+r *.bin && [OHOS ERROR] ~/tools/gcc-arm-none-eabi-10-2020-q4-major/bin/arm-none-eabi-gcc -E -P -CC -DCONFIG_CHIP_ARCH_VER=3 -DCONFIG_ARCH_APP_CORE -DCONFIG_CPU_CM33F -DPRJ_XIP_SIZE=8M -DPRJ_BOOT_CERT=""null"" -DPRJ_IMAGE_BOOT_ATTR=""0x1"" -DPRJ_IMAGE_APP_SRAM_OFFS=""0x00201000"" -DPRJ_IMAGE_APP_EP=""0x00201101"" -DPRJ_IMAGE_BOOT_SRAM_OFFS=""0x00230000"" -DPRJ_IMAGE_BOOT_EP=""0x00230101"" -DPRJ_IMAGE_TZ_ATTR=""0x25"" -DPRJ_IMAGE_TZ_XIP_ATTR=""0x26"" -DPRJ_IMAGE_TZ_PSRAM_ATTR=""0x25"" -DPRJ_APP_BIN_CERT=""null"" -DPRJ_APP_XIP_BIN_CERT=""null"" -DPRJ_APP_PSRAM_BIN_CERT=""null"" -DPRJ_IMAGE_APP_ATTR=""0x1"" -DPRJ_IMAGE_APP_XIP_ATTR=""0x2"" -DPRJ_IMAGE_APP_PSRAM_ATTR=""0x1"" -DCONFIG_RAM_START=0x00201000 -DPRJ_RAM_SIZE=300K -DPRJ_PSRAM_START_OFFS=""0x01400000"" -DCONFIG_PSRAM_START=0x01400000 -DPRJ_PSRAM_SIZE=0K -DPRJ_IMAGE_BOOT_BIN=""boot_"40"M.bin"" -DPRJ_IMAGE_SYS_SDD_BIN=""sys_sdd_"40"M.bin"" -I../../../../../include/generated -include autoconf.h -o .image.cfg - < image.cfg && [OHOS ERROR] true && [OHOS ERROR] chmod 777 ../../../../../tools/mkimage && ../../../../../tools/mkimage -c .image.cfg -o xr_system.img [OHOS ERROR] err: bin 1 and bin 2 were overlaped! [OHOS ERROR] Overlapped size: 1024 Byte(1kB) [OHOS ERROR] bin 1 name:app.bin begin: 0x00008000 end: 0x00018000 [OHOS ERROR] bin 2 name:app_xip.bin begin: 0x00017C00 [OHOS ERROR] [OHOS ERROR] We've rearranged bin files and generated new cfg file 'image_auto_cal.cfg', the new one is recommended. [OHOS ERROR] Generate image file failed [OHOS ERROR] cfg string: [OHOS ERROR] /* [OHOS ERROR] * [OHOS ERROR] * Automatically generated file; DO NOT EDIT. [OHOS ERROR] * XR806 SDK Configuration [OHOS ERROR] * [OHOS ERROR] */ [OHOS ERROR] { [OHOS ERROR] "magic" : "AWIH", [OHOS ERROR] "version" : "0.5", [OHOS ERROR] "image" : {"max_size": "1532K"}, [OHOS ERROR] "section" :[ [OHOS ERROR] {"id": "0xa5ff5a00", "bin" :"boot_40M.bin", "cert": "null", "flash_offs": "0K", "sram_offs": "0x00230000", "ep": "0x00230101", "attr":"0x1"}, [OHOS ERROR] {"id": "0xa5fe5a01", "bin" :"app.bin", "cert": "null", "flash_offs": "32K", "sram_offs": "0x00201000", "ep": "0x00201101", "attr":"0x1"}, [OHOS ERROR] {"id": "0xa5fd5a02", "bin" :"app_xip.bin", "cert": "null", "flash_offs": "95K", "sram_offs": "0xffffffff", "ep": "0xffffffff", "attr":"0x2"}, [OHOS ERROR] {"id": "0xa5fa5a05", "bin" :"wlan_bl.bin", "cert": "null", "flash_offs": "1166K", "sram_offs": "0xffffffff", "ep": "0xffffffff", "attr":"0x1"}, [OHOS ERROR] {"id": "0xa5f95a06", "bin" :"wlan_fw.bin", "cert": "null", "flash_offs": "1169K", "sram_offs": "0xffffffff", "ep": "0xffffffff", "attr":"0x1"}, [OHOS ERROR] {"id": "0xa5f85a07", "bin" :"sys_sdd_40M.bin", "cert": "null", "flash_offs": "1194K", "sram_offs": "0xffffffff", "ep": "0xffffffff", "attr":"0x1"}, [OHOS ERROR] {} [OHOS ERROR] ] [OHOS ERROR] } [OHOS ERROR] [OHOS ERROR] make[2]: *** [../../../../project/project.mk:520: image] Error 255 [OHOS ERROR] make[2]: Leaving directory '/home/openharmony/device/xradio/xr806/xr_skylark/project/demo/audio_demo/gcc' [OHOS ERROR] make[1]: *** [../../../../project/project.mk:493: __build] Error 2 [OHOS ERROR] make[1]: Leaving directory '/home/openharmony/device/xradio/xr806/xr_skylark/project/demo/audio_demo/gcc' [OHOS ERROR] make: *** [Makefile:164: build] Error 2 [OHOS ERROR] you can check build log in /home/openharmony/out/xr806/wifi_skylark/build.log [OHOS ERROR] command: "/home/tools/ninja/ninja -w dupbuild=warn -C /home/openharmony/out/xr806/wifi_skylark" failed [OHOS ERROR] return code: 1 [OHOS ERROR] execution path: /home/openharmony 看日志像是bin地址重叠了,不知道是什么情况 |
2个回答
是鸿蒙系统太臃肿了,什么都没用就已经占了很多空间了,只能裁剪。从目前体验来看,鸿蒙还是不适合用在IOT WIFI上
其实只是旧的flash内存分配策略不管用了,文档里面有介绍的,这时候生成了一个auto.cfg,把auto.cfg的内容复制到image.cfg里面即可。
只有小组成员才能发言,加入小组>>
【实测】用全志A733平板搭建一个端侧Deepseek算力平台
1669 浏览 0 评论
2540 浏览 0 评论
1590 浏览 0 评论
1780 浏览 0 评论
全志T113双核异构处理器的使用基于Tina Linux5.0——RTOS系统定制开发
2474 浏览 0 评论
6154浏览 1评论
花费200元,我用全志H616和雪糕棒手搓了一台可UI交互的视觉循迹小车
9490浏览 1评论
用39块钱的全志V851se视觉开发板做了个小相机,还可以物品识别、自动追焦!
11225浏览 1评论
2327浏览 1评论
1635浏览 0评论
/9
GMT+8, 2025-12-3 07:39 , Processed in 0.682878 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
965
