扫一扫,分享给好友
1个回答
目录
STM32F4 Libraries and projects Here are listed all libraries for STM32F4 devices.Libraries are designed to work with STM32F4xx series of MCU. Every project hereis created with Keil uVision, but tested with GCC compiler too (Coocox). Eachproject includes 4 targets: STM32F429-Discovery board (STM32F429ZI, 180MHz) STM32F4-Discovery board (STM32F407VG, 168MHz) STM32F401-Discovery (STM32F401, 84MHz) STM32F411C-Discovery (STM32F411, 100MHz) Nucleo F411-RE (STM32F411RE, 100MHz) Nucleo F401-RE (STM32F401RE, 84MHz) STM32F446xx (180MHz) STM32439-Eval (STM32F439NI, 180MHz) When you download repository and open project, you haveto set correct your target, for device you use. If you use other device in yourproject, then set your project and copy settings there from target options. More information below http://stm32f4-discovery.com First time with Discovery board? http://stm32f4-discovery.com Current librarires: All libraries listed at one place for easy editing them from one place and use them for all projects Two default projects are included Default Keil project, with CMSIS files v.1.5.0 included Default Keil project, with CMSIS files v.1.5.0 included and clock for STM32F429-Discovery/STM32F446 slowed down to 168MHz and for Nucleo F411 down to 96MHz for USB communication LED_BUTTON - Project example for STM32F4/29 Discovery DELAY - Delay library for STM32F4/29 USART - USART library for STM32F4/29 SPI - SPI library for STM32F4/29 ADC - ADC library for STM32F4/29 DAC - DAC library for STM32F4/29 ILI9341 LCD - STM32F429 Discovery ILI9341 LCD library I2C - I2C library for STM32F4/29 STMPE811 touch driver for STM32F4/29 Discovery board ILI9341 Button - Button library for ILI9341 LCD and STMPE811 Touch driver on STM32F429 ONEWIRE - OneWire library for STM32F4/29 DS18B20 - DS18B20 OneWire temperature sensor library for STM32F4/29 SDRAM - ISSI 8MByte SDRAM on STM32F429 Discovery board DS1307 - DS1307 RTC modeule for STM32F429 Discovery HD44780 - HD44780 Alpha numeric LCD driver for STM32F429 discovery NRF24L01+ - NRF24L01+ 2.4 GHz transceiver library ILI8341 LTDC - ILI9341 LCD with LTDC hardware only for STM32F429 Internal RTC - Library for internal RTC on STM32F4xx devices Independent watchdog - Library for watchdog on STM32F4xx devices FATFS - Read SDcard with STM32F4xx using SDIO or SPI communication RNG - Use of True random number generator peripheral on STM32F4xx devices MFRC522 - Read RFID Cards with STM32F4xx devices USB VCP - Use STM32F4xx as USB VCP device (Virtual COM Port) AM2301 - AM2301 (DHT21) temperature and humidity sensor ROTARY ENCODER - Connect Rotary Encoder to STM32F4xx device GPS - Read GPS data on STM32F4xx devices L3GD20 - Measure rotation of all 3 axis with L3GD20 gyro sensor USB MSC HOST - Read USB flash drive with STM32F4xx HC-SR04 - Measure distance with ultrasonic sensor on STM32F4xx USB HID HOST - Read USB mouse and keyboard on STM32F4xx 4x4 KEYPAD - Read matrix keypad up to 4x4 with STM32F4xx PWM - Use PWM on all possible timers for STM32F4xx device USB HID Device - Turn STM32F4 into USB HID Device LIS302DL/LIS3DSH - Accelerometers on STM32F4-Discovery board. Also can be used with any STM32F4 device DAC SIGNAL - Output predefined signals with STM32F4 using DAC, DMA and TIM BMP180 - Read atmosferic pressure on STM32F4 device EXTI - Use external interrupts with STM32F4 LOW POWER - Power consumption modes for STM32F4 MCO OUTPUT - Output different clocks from STM32F4 STDIO - Use printf and fprintf/vfprintf on STM32F4 SERVO - Control RC servo with STM32F4 MPU-6050 - Read accelerometer and gyroscope data with STM32F4 Identification - Read identification bytes and 96-bits long UNIQUE ID from STM32F4 BKPSRAM - Interface backup SRAM on STM32F4 SWO DEBUG - Debug STM32F4 using SWO output CRC - STM32F4 CRC Hardware module PWM IN - Measure input PWM signal on STM32F4 OTP - One-time programmable memory on STM32F4 STemWin - STemWin implementation for STM32F429-Discovery DMA2D GRAPHIC- Chrom-ART Accelerator on STM32F429-Discovery board ETHERNET - Connect ethernet to STM32F4xx GPIO - GPIO pins on STM32F4 GENERAL - General library for STM32F4 USART DMA - Extend USART with DMA TX functionality SPI DMA - Extend SPI with DMA functionality BUTTON - Use buttons with STM32F4xx STRING - Dynamic string allocation for STM32F4xx RCC - Dynamic PLL settings for STM32F4xx CPU LOAD - CPU load monitoring for STM32F4xx SSD1306 - Use OLED LCD with STM32F4 FFT - FFT Library for STM32F4xx devices DMA - DMA library for STM32F4xx PCD8544 LCD (Nokia 5110/3310) - Library for LCD 来看看真正的东西吧~~~激动 随意show两个代码: (IIC) (GPIO) 老外写的很是完善,英文的注释就连小编这种英语渣渣都能简单易懂,能直接用,不用怎么配置了,当然可以改装成为我们自己习惯的库。 虽然st的库很完善,但是以后我们写代码都可以有自己的库,拿来即用,很是方便。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1364 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1359 浏览 1 评论
780 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
562 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1394 浏览 2 评论
1758浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
484浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
420浏览 3评论
414浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
389浏览 3评论
GMT+8, 2024-9-28 23:00 , Processed in 0.798233 second(s), Total 48, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
