1个回答
STM32实验——4×4按键
实验要求:使用一个4×4键盘输入到单片机 单片机在通过USART端口输出到上位机。 第一部分:对按键的检测,原理具体通过百度可知。大体原理为通过4行输出低电平,分别检测四列的电平,确定按键在哪一列上。再通过对那一列输出高电平,检测在哪一个行上。 代码部分: #include "4X4.h" #include "delay.h" #include "usart.h" void LED_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOD, ENABLE); //使能PB,PE端口时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //LED0-->PB.5 端口配置 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz GPIO_Init(GPIOA, &GPIO_InitStructure); //根据设定参数初始化GPIOB.5 GPIO_SetBits(GPIOA,GPIO_Pin_8); //PB.5 输出高 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //LED1-->PE.5 端口配置, 推挽输出 GPIO_Init(GPIOD, &GPIO_InitStructure); //推挽输出 ,IO口速度为50MHz GPIO_SetBits(GPIOD,GPIO_Pin_2); //PE.5 输出高 } void LED_R_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOB, ENABLE); //使能PB,PC端口时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //PB0 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉输入 GPIO_Init(GPIOB, &GPIO_InitStructure); //根据设定参数初始化GPIOB0 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //PB1 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉输入 GPIO_Init(GPIOB, &GPIO_InitStructure); //根据设定参数初始化GPIOB1 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //PB5 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉输入 GPIO_Init(GPIOB, &GPIO_InitStructure); //根据设定参数初始化GPIOB5 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; //PB6 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //上拉输入 GPIO_Init(GPIOB, &GPIO_InitStructure); //根据设定参数初始化GPIOB6 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PC9 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); //根据设定参数初始化GPIOC9 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //PC8 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); //根据设定参数初始化GPIOC8 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; //PC7 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); //根据设定参数初始化GPIOC7 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; //PC6 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOC, &GPIO_InitStructure); //根据设定参数初始化GPIOC6 } void LED_C_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOB, ENABLE); //使能PB,PC端口时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; //PC9 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //下拉输入 GPIO_Init(GPIOC, &GPIO_InitStructure); //根据设定参数初始化GPIOC9 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //PC8 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //下拉输入 GPIO_Init(GPIOC, &GPIO_InitStructure); //根据设定参数初始化GPIOC8 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7; //PC7 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //下拉输入 GPIO_Init(GPIOC, &GPIO_InitStructure); //根据设定参数初始化GPIOC7 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; //PC6 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD; //下拉输入 GPIO_Init(GPIOC, &GPIO_InitStructure); //根据设定参数初始化GPIOC6 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //PB0 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); //根据设定参数初始化GPIOB0 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //PB1 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); //根据设定参数初始化GPIOB1 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //PB5 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); //根据设定参数初始化GPIOB5 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6; //PB6 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); //根据设定参数初始化GPIOB6 } char key; u8 KEY_Scan(void) { uart_init(9600); LED_R_Init(); GPIO_ResetBits(GPIOC,GPIO_Pin_9); GPIO_ResetBits(GPIOC,GPIO_Pin_8); GPIO_ResetBits(GPIOC,GPIO_Pin_7); GPIO_ResetBits(GPIOC,GPIO_Pin_6); delay_ms(10); if(C1==0) { LED_C_Init(); GPIO_SetBits(GPIOB,GPIO_Pin_0); delay_ms(10); if(R2==1) key= '4' ; else if(R1==1) key='1'; else if(R3==1) key='7'; else if(R4==1) key= '*'; else key='z'; } else if(C2==0) { LED_C_Init(); GPIO_SetBits(GPIOB,GPIO_Pin_1); delay_ms(10); if(R1==1) key= '2'; else if(R2==1) key= '5'; else if(R3==1) key= '8'; else if(R4==1) key= '0'; else key='z'; } else if(C3==0) { LED_C_Init(); GPIO_SetBits(GPIOB,GPIO_Pin_5); delay_ms(10); if(R1==1) key= '3'; else if(R2==1) key= '6'; else if(R3==1) key= '9'; else if(R4==1) key= '#'; else key='z'; } else if(C4==0) { LED_C_Init(); GPIO_SetBits(GPIOB,GPIO_Pin_6); delay_ms(10); if(R1==1) key= 'A'; else if(R2==1) key= 'B'; else if(R3==1) key= 'C'; else if(R4==1) key= 'D'; else key='z'; } else key='z'; return key; } 这一部分的注释又可能有问题,并没有仔细检查。 附上.h文件 #ifndef __4X4_H #define __4X4_H #include "sys.h" #define R1 GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9) #define R2 GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8) #define R3 GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_7) #define R4 GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_6) #define C1 GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_0) #define C2 GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_1) #define C3 GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_5) #define C4 GPIO_ReadInputDataBit(GPIOB,GPIO_Pin_6) void LED_R_Init(void);//初始化 void LED_C_Init(void);//初始化 void LED_Init(void); u8 KEY_Scan(void); #endif 第二部分:主函数 主函数主要实现在键盘中读取数字字符后再转换成数字,并且可以输入一定长度的数字,其中(R4,C4)按键为确定键。例如输入三个数字‘1’,‘1’,‘3’,再按下确定键即可输出113数字到PC机上。按下按键的时候有LED灯提示。输出到PC上同样有LED灯提示。 /************************ 名称:用4X4键盘来输入数据显示到PC 时间:2020.3.22 作者:L.J.W 变量作用:arr数组用来储存键盘输入的数据 D代表输入结束 i计数来统计一共输入多少个数据 add是最后显示的数据 按下按键led亮 输出数据另一个led亮 ************************/ #include "4X4.h" #include "usart.h" #include "delay.h" #include "math.h" char t; int main() { LED_Init(); //初始化与LED连接的硬件接口 uart_init(9600); delay_init(); int arr[9]; int i; int count=0; int add=0; int z; while(1) { t=KEY_Scan(); if(t=='z') t=t; else { if(t=='D') { //用来把arr数组里的数转换到add for(count=0;count { add+=arr[count]*(int)pow((float)10,(i-count-1)); } printf("%dnr",add); GPIO_ResetBits(GPIOD,GPIO_Pin_2);//LED1输出低 delay_ms(300); GPIO_SetBits(GPIOD,GPIO_Pin_2);//LED0输出高 add=0;//add清零 for(z=0;z<9;z++) { arr[z]=0;//数组清零 } count=0; i=0;//统计数据清零 } else { //用来i计数并且写入arr数组 arr=t-'0'; GPIO_ResetBits(GPIOA,GPIO_Pin_8); //LED0输出低 delay_ms(300); GPIO_SetBits(GPIOA,GPIO_Pin_8);//LED1输出高 i++; } } delay_ms(300); } } 这次按键代码除了0~9个数字键还有一个确认键之外,还有5个按键,但是代码部分并没有进行处理。由于新手写代码有很多疏漏的地方,多多包涵。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
868 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
649 浏览 1 评论
410 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
324 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
725 浏览 2 评论
1470浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
143浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
180浏览 3评论
164浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
165浏览 3评论
GMT+8, 2024-6-26 15:10 , Processed in 1.067197 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
