扫一扫,分享给好友
1. 寄存器
1.1 状态寄存器 1.2 控制寄存器CR1 1.3 控制寄存器CR3 2. 代码分析 stm32f1xx_hal_uart.c /** * @brief This function handles UART interrupt request. * @param huart Pointer to a UART_HandleTypeDef structure that contains * the configuration information for the specified UART module. * @retval None */ void HAL_UART_IRQHandler(UART_HandleTypeDef *huart) { uint32_t isrflags = READ_REG(huart->Instance->SR); uint32_t cr1its = READ_REG(huart->Instance->CR1); uint32_t cr3its = READ_REG(huart->Instance->CR3); uint32_t errorflags = 0x00U; uint32_t dmarequest = 0x00U; /* If no error occurs */ errorflags = (isrflags & (uint32_t)(USART_SR_PE | USART_SR_FE | USART_SR_ORE | USART_SR_NE)); if (errorflags == RESET) { /* UART in mode Receiver -------------------------------------------------*/ if (((isrflags & USART_SR_RXNE) != RESET) && ((cr1its & USART_CR1_RXNEIE) != RESET)) { UART_Receive_IT(huart); return; } } /* If some errors occur */ if ((errorflags != RESET) && (((cr3its & USART_CR3_EIE) != RESET) || ((cr1its & (USART_CR1_RXNEIE | USART_CR1_PEIE)) != RESET))) { /* UART parity error interrupt occurred ----------------------------------*/ if (((isrflags & USART_SR_PE) != RESET) && ((cr1its & USART_CR1_PEIE) != RESET)) { huart->ErrorCode |= HAL_UART_ERROR_PE; } /* UART noise error interrupt occurred -----------------------------------*/ if (((isrflags & USART_SR_NE) != RESET) && ((cr3its & USART_CR3_EIE) != RESET)) { huart->ErrorCode |= HAL_UART_ERROR_NE; } /* UART frame error interrupt occurred -----------------------------------*/ if (((isrflags & USART_SR_FE) != RESET) && ((cr3its & USART_CR3_EIE) != RESET)) { huart->ErrorCode |= HAL_UART_ERROR_FE; } /* UART Over-Run interrupt occurred --------------------------------------*/ if (((isrflags & USART_SR_ORE) != RESET) && ((cr3its & USART_CR3_EIE) != RESET)) { huart->ErrorCode |= HAL_UART_ERROR_ORE; } /* Call UART Error Call back function if need be --------------------------*/ if (huart->ErrorCode != HAL_UART_ERROR_NONE) { /* UART in mode Receiver -----------------------------------------------*/ if (((isrflags & USART_SR_RXNE) != RESET) && ((cr1its & USART_CR1_RXNEIE) != RESET)) { UART_Receive_IT(huart); } /* If Overrun error occurs, or if any error occurs in DMA mode reception, consider error as blocking */ dmarequest = HAL_IS_BIT_SET(huart->Instance->CR3, USART_CR3_DMAR); if (((huart->ErrorCode & HAL_UART_ERROR_ORE) != RESET) || dmarequest) { /* Blocking error : transfer is aborted Set the UART state ready to be able to start again the process, Disable Rx Interrupts, and disable Rx DMA request, if ongoing */ UART_EndRxTransfer(huart); /* Disable the UART DMA Rx request if enabled */ if (HAL_IS_BIT_SET(huart->Instance->CR3, USART_CR3_DMAR)) { CLEAR_BIT(huart->Instance->CR3, USART_CR3_DMAR); /* Abort the UART DMA Rx channel */ if (huart->hdmarx != NULL) { /* Set the UART DMA Abort callback : will lead to call HAL_UART_ErrorCallback() at end of DMA abort procedure */ huart->hdmarx->XferAbortCallback = UART_DMAAbortOnError; if (HAL_DMA_Abort_IT(huart->hdmarx) != HAL_OK) { /* Call Directly XferAbortCallback function in case of error */ huart->hdmarx->XferAbortCallback(huart->hdmarx); } } else { /* Call user error callback */ #if (USE_HAL_UART_REGISTER_CALLBACKS == 1) /*Call registered error callback*/ huart->ErrorCallback(huart); #else /*Call legacy weak error callback*/ HAL_UART_ErrorCallback(huart); #endif /* USE_HAL_UART_REGISTER_CALLBACKS */ } } else { /* Call user error callback */ #if (USE_HAL_UART_REGISTER_CALLBACKS == 1) /*Call registered error callback*/ huart->ErrorCallback(huart); #else /*Call legacy weak error callback*/ HAL_UART_ErrorCallback(huart); #endif /* USE_HAL_UART_REGISTER_CALLBACKS */ } } else { /* Non Blocking error : transfer could go on. Error is notified to user through user error callback */ #if (USE_HAL_UART_REGISTER_CALLBACKS == 1) /*Call registered error callback*/ huart->ErrorCallback(huart); #else /*Call legacy weak error callback*/ HAL_UART_ErrorCallback(huart); #endif /* USE_HAL_UART_REGISTER_CALLBACKS */ huart->ErrorCode = HAL_UART_ERROR_NONE; } } return; } /* End if some error occurs */ /* UART in mode Transmitter ------------------------------------------------*/ if (((isrflags & USART_SR_TXE) != RESET) && ((cr1its & USART_CR1_TXEIE) != RESET)) { UART_Transmit_IT(huart); return; } /* UART in mode Transmitter end --------------------------------------------*/ if (((isrflags & USART_SR_TC) != RESET) && ((cr1its & USART_CR1_TCIE) != RESET)) { UART_EndTransmit_IT(huart); return; } } /** * @brief Tx Transfer completed callbacks. * @param huart Pointer to a UART_HandleTypeDef structure that contains * the configuration information for the specified UART module. * @retval None */ __weak void HAL_UART_TxCpltCallback(UART_HandleTypeDef *huart) { /* Prevent unused argument(s) compilation warning */ UNUSED(huart); /* NOTE: This function should not be modified, when the callback is needed, the HAL_UART_TxCpltCallback could be implemented in the user file */ } /** * @brief Tx Half Transfer completed callbacks. * @param huart Pointer to a UART_HandleTypeDef structure that contains * the configuration information for the specified UART module. * @retval None */ __weak void HAL_UART_TxHalfCpltCallback(UART_HandleTypeDef *huart) { /* Prevent unused argument(s) compilation warning */ UNUSED(huart); /* NOTE: This function should not be modified, when the callback is needed, the HAL_UART_TxHalfCpltCallback could be implemented in the user file */ } /** * @brief Rx Transfer completed callbacks. * @param huart Pointer to a UART_HandleTypeDef structure that contains * the configuration information for the specified UART module. * @retval None */ __weak void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart) { /* Prevent unused argument(s) compilation warning */ UNUSED(huart); /* NOTE: This function should not be modified, when the callback is needed, the HAL_UART_RxCpltCallback could be implemented in the user file */ } /** * @brief Rx Half Transfer completed callbacks. * @param huart Pointer to a UART_HandleTypeDef structure that contains * the configuration information for the specified UART module. * @retval None */ __weak void HAL_UART_RxHalfCpltCallback(UART_HandleTypeDef *huart) { /* Prevent unused argument(s) compilation warning */ UNUSED(huart); /* NOTE: This function should not be modified, when the callback is needed, the HAL_UART_RxHalfCpltCallback could be implemented in the user file */ } /** * @brief UART error callbacks. * @param huart Pointer to a UART_HandleTypeDef structure that contains * the configuration information for the specified UART module. * @retval None */ __weak void HAL_UART_ErrorCallback(UART_HandleTypeDef *huart) { /* Prevent unused argument(s) compilation warning */ UNUSED(huart); /* NOTE: This function should not be modified, when the callback is needed, the HAL_UART_ErrorCallback could be implemented in the user file */ } /** * @brief UART Abort Complete callback. * @param huart UART handle. * @retval None */ __weak void HAL_UART_AbortCpltCallback(UART_HandleTypeDef *huart) { /* Prevent unused argument(s) compilation warning */ UNUSED(huart); /* NOTE : This function should not be modified, when the callback is needed, the HAL_UART_AbortCpltCallback can be implemented in the user file. */ } /** * @brief UART Abort Complete callback. * @param huart UART handle. * @retval None */ __weak void HAL_UART_AbortTransmitCpltCallback(UART_HandleTypeDef *huart) { /* Prevent unused argument(s) compilation warning */ UNUSED(huart); /* NOTE : This function should not be modified, when the callback is needed, the HAL_UART_AbortTransmitCpltCallback can be implemented in the user file. */ } /** * @brief UART Abort Receive Complete callback. * @param huart UART handle. * @retval None */ __weak void HAL_UART_AbortReceiveCpltCallback(UART_HandleTypeDef *huart) { /* Prevent unused argument(s) compilation warning */ UNUSED(huart); /* NOTE : This function should not be modified, when the callback is needed, the HAL_UART_AbortReceiveCpltCallback can be implemented in the user file. */ } |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1274 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1287 浏览 1 评论
689 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
512 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1291 浏览 2 评论
1710浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
409浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
377浏览 3评论
364浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
339浏览 3评论
GMT+8, 2024-9-17 03:49 , Processed in 0.894029 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
