1个回答
启动文件
1、几种启动方式 STM32芯片自带的启动方式有3种,通过设置BOOT1、BOOT0的引脚的高低电平即可选择。
2、启动前的准备 stm32的汇编启动文件(部分) 1.设置堆栈 __user_initial_stackheap LDR R0, = Heap_Mem LDR R1, =(Stack_Mem + Stack_Size) LDR R2, = (Heap_Mem + Heap_Size) LDR R3, = Stack_Mem BX LR Stack_Size EQU 0x00000400 AREA STACK, NOINIT, READWRITE, ALIGN=3 Stack_Mem SPACE Stack_Size __initial_sp ; Heap Configuration ; Heap Size (in Bytes) <0x0-0xFFFFFFFF:8> Heap_Size EQU 0x00000200 AREA HEAP, NOINIT, READWRITE, ALIGN=3 __heap_base Heap_Mem SPACE Heap_Size __heap_limit 此条语句即设置栈Stack_Size EQU 0x00000400;此条语句即设置堆Heap_Size EQU 0x00000200 ; 这一段代码在单片机运行前设置好了程序的堆栈,一般来说,裸机程序中不对内存进行管理,堆栈设置是静态的,程序初始化后不会再进行修改。 2.初始化中断向量表 __Vectors DCD __initial_sp ; Top of Stack DCD Reset_Handler ; Reset Handler DCD NMI_Handler ; NMI Handler DCD HardFault_Handler ; Hard Fault Handler DCD MemManage_Handler ; MPU Fault Handler DCD BusFault_Handler ; Bus Fault Handler DCD UsageFault_Handler ; Usage Fault Handler DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD SVC_Handler ; SVCall Handler DCD DebugMon_Handler ; Debug Monitor Handler DCD 0 ; Reserved DCD PendSV_Handler ; PendSV Handler DCD SysTick_Handler ; SysTick Handler ; External Interrupts DCD WWDG_IRQHandler ; Window Watchdog DCD PVD_IRQHandler ; PVD through EXTI Line detect DCD TAMPER_IRQHandler ; Tamper DCD RTC_IRQHandler ; RTC DCD FLASH_IRQHandler ; Flash DCD RCC_IRQHandler ; RCC DCD EXTI0_IRQHandler ; EXTI Line 0 DCD EXTI1_IRQHandler ; EXTI Line 1 DCD EXTI2_IRQHandler ; EXTI Line 2 27 DCD EXTI3_IRQHandler ; EXTI Line 3 DCD EXTI4_IRQHandler ; EXTI Line 4 DCD DMA1_Channel1_IRQHandler ; DMA1 Channel 1 DCD DMA1_Channel2_IRQHandler ; DMA1 Channel 2 DCD DMA1_Channel3_IRQHandler ; DMA1 Channel 3 DCD DMA1_Channel4_IRQHandler ; DMA1 Channel 4 DCD DMA1_Channel5_IRQHandler ; DMA1 Channel 5 DCD DMA1_Channel6_IRQHandler ; DMA1 Channel 6 DCD DMA1_Channel7_IRQHandler ; DMA1 Channel 7 DCD ADC1_2_IRQHandler ; ADC1 & ADC2 DCD USB_HP_CAN1_TX_IRQHandler DCD USB_LP_CAN1_RX0_IRQHandler DCD CAN1_RX1_IRQHandler ; CAN1 RX1 DCD CAN1_SCE_IRQHandler ; CAN1 SCE DCD EXTI9_5_IRQHandler ; EXTI Line 9..5 DCD TIM1_BRK_IRQHandler ; TIM1 Break DCD TIM1_UP_IRQHandler ; TIM1 Update DCD TIM1_TRG_COM_IRQHandler DCD TIM1_CC_IRQHandler ; TIM1 Capture Compare DCD TIM2_IRQHandler ; TIM2 DCD TIM3_IRQHandler ; TIM3 DCD TIM4_IRQHandler ; TIM4 DCD I2C1_EV_IRQHandler ; I2C1 Event /*** 很多 不一一列举 ***/ 这个是作为其他所有中断的默认处理函数,作用就是死循环,所以你假如开启了某个中断,请按照这里面的中断函数名给它写中断处理函数,例如串口中断处理函数名是 USART1_IRQHandler,你开了串口中断,如果不重写USART1_IRQHandler,就默认执行Default_Handler,死循环了。而如果你有重写,那么中断向量表中的处理函数的地址就会更新为你自己写的那个函数的地址了。为什么会这样呢?因为此文件的末尾用了类似这样的语句: weak USART1_IRQHandler .thumb_set USART1_IRQHandler,Default_Handler 它给中断处理函数提供了弱(weak)别名(Default_Handler),如果不重写,中断了默认执行Default_Handler,如果重写了,因为是弱别名,所以会被你写的同名函数覆盖。WEAK声明其他的同名标号优先于该标号被引用,就是说如果外面声明了的话,;会调用外面的 最后定义了一个中断向量表的段(.section .isr_vector,“a”,%progbits),这个表将会放置在0x0000 0000那里,第二个字(0x0000 0004)是复位向量,复位之后从这地址所指的函数执行。 3、main()执行前过程 Reset_Handler PROC EXPORT Reset_Handler [WEAK] IMPORT __main IMPORT SystemInit LDR R0, =SystemInit BLX R0 LDR R0, =__main BX R0 ENDP 这个文件里面首先定义了复位中断(复位入口矢量被硬件固定在地址0x0000_0004)的处理函数:Reset_Handler,它的作用就是将保存于flash中的初始化数据复制到sram中,调用上面说到的SystemInit来初始化时钟,接着跳转到main执行。 在进入main函数之前,我们要进行系统初始化:SystemInit( ),这个函数在system_stm32f10x.c中。 SystemInit():在"startup_stm32f10x_xx.s"文件中被调用,功能是设置系统时钟(包括时钟源,PLL系数,AHB/APBx的预分频系数还有 flash的设定),这个函数会在系统复位之后首先被执行。文件中默认的一些设置:允许HSE(外部时钟),FLASH(允许预取缓冲区,设置2个等待周期),PLL系数为9,开启PLL并选择PLL输出作为时钟源(SYSCLK),后续设置SYSCLK = HCLK = APB2 = 72MHz,APB1 = HCLK/2 = 36MHz,HCLK即AHB的时钟。 SystemCoreClockUpdate():在系统时钟HCLK变化的时候调用,以更新一个全局变量SystemCoreClock,这个变量可以为应用程序使用,必须保证正确。默认不调用这个函数,因为SystemCoreClock默认被设置为设定的频率了。 4、整个过程 在.s文件中,已经将中断向量表定义完整,系统会跳转到固定地址进行执行。第一条执行 Reset_handler。接着执行SystemInit设置运行时钟信息(72MHz)。 __main函数是内部的一个库函数,在此函数中调用了_scatter_load, _scatterload_null, _scatterload_copy 等函数,负责初始化堆栈,RW-DATA搬运,ZI段初始化等等操作。(编译后的镜像下载文件包含Code:代表程序代码段、RO_DATA:代表只读数据段、RW_DATA:代表已经初始化全局数据、ZI_DATA:代表未初始化全局数据,其中ZI不会被下载,其他的都会被下载到单片机的Flash,stm32在运行时会把RW从Flash搬运到RAM,RO不会搬运。) 走完前面的路最终跳转到 main 函数,执行用户程序。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
1386 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
1377 浏览 1 评论
801 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
574 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
1414 浏览 2 评论
1764浏览 9评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
497浏览 4评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
433浏览 3评论
420浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
398浏览 3评论
GMT+8, 2024-10-3 02:49 , Processed in 0.588312 second(s), Total 45, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
