电子发烧友论坛|
1个回答
In the example, we synchronize Timer 1 and Timer 2. Timer 1 is the master and starts from 0. Timer 2 is the slave and starts from 0xE7. The prescaler ratio is the same for both timers. Timer 2 stops when Timer 1 is disabled by writing ‘0 to the CEN bit in the TIM1_CR1 register:
• Configure Timer 1 master mode to send its Output Compare 1 Reference (OC1REF) signal as trigger output (MMS=100 in the TIM1_CR2 register). 定时器主模式选择器:MMS Bits 6:4 MMS[2:0]: Master mode selection These bits allow to select the information to be sent in master mode to slave timers for synchronization (TRGO). The combination is as follows: 000: Reset - the UG bit from the TIMx_EGR register is used as trigger output (TRGO). If the reset is generated by the trigger input (slave mode controller configured in reset mode) then the signal on TRGO is delayed compared to the actual reset. 001: Enable - the Counter enable signal, CNT_EN, is used as trigger output (TRGO). It is useful to start several timers at the same time or to control a window in which a slave timer is enabled. The Counter Enable signal is generated by a logic OR between CEN control bit and the trigger input when configured in gated mode. When the Counter Enable signal is controlled by the trigger input, there is a delay on TRGO, except if the master/slave mode is selected (see the MSM bit description in TIMx_SMCR register). 010: Update - The update event is selected as trigger output (TRGO). For instance a master timer can then be used as a prescaler for a slave timer. 011: Compare Pulse - The trigger output send a positive pulse when the CC1IF flag is to be set (even if it was already high), as soon as a capture or a compare match occurred. (TRGO) 100: Compare - OC1REF signal is used as trigger output (TRGO) 101: Compare - OC2REF signal is used as trigger output (TRGO) 110: Compare - OC3REF signal is used as trigger output (TRGO) 111: Compare - OC4REF signal is used as trigger output (TRGO) • Configure the Timer 1 OC1REF waveform (TIM1_CCMR1 register). 定时器捕捉输入模式,这种T1的输出波形 • Configure Timer 2 to get the input trigger from Timer 1 (TS=000 in the TIM2_SMCR register). T2的主从控制寄存器,设置触发选择器, T2设置为T1触发输入 • Configure Timer 2 in gated mode (SMS=101 in TIM2_SMCR register). T2主从控制器,从模式选择器,选择T2为Gate模式 • Reset Timer 1 by writing ‘1 in UG bit (TIM1_EGR register). • Reset Timer 2 by writing ‘1 in UG bit (TIM2_EGR register). 重置,T1,T2的更新位, Bit 0 UG: Update generation This bit can be set by software, it is automatically cleared by hardware. 0: No action 1: Reinitialize the counter and generates an update of the registers. Note that the prescaler counter is cleared too (anyway the prescaler ratio is not affected). The counter is cleared if the center-aligned mode is selected or if DIR=0 (upcounting), else it takes the auto-reload value (TIMx_ARR) if DIR=1 (downcounting). • Initialize Timer 2 to 0xE7 by writing ‘0xE7’ in the timer 2 counter (TIM2_CNT). 初始化T2的计数器, • Enable Timer 2 by writing ‘1 in the CEN bit (TIM2_CR1 register). • Start Timer 1 by writing ‘1 in the CEN bit (TIM1_CR1 register). • Stop Timer 1 by writing ‘0 in the CEN bit (TIM1_CR1 register). 定时器1 ,定时器2 本来各自运行,然后,T1,T2都初始化到0,T2给出初始值;这时候,T2为T1触发,T1后面使能,T2之前付的初值开始计数,T1后又停止计数,T1波形为GATE波形,T2在T1之后也停止计数。 |
只有小组成员才能发言,加入小组>>
调试STM32H750的FMC总线读写PSRAM遇到的问题求解?
4168 浏览 1 评论
X-NUCLEO-IHM08M1板文档中输出电流为15Arms,15Arms是怎么得出来的呢?
3246 浏览 1 评论
2776 浏览 2 评论
STM32F030F4 HSI时钟温度测试过不去是怎么回事?
2206 浏览 2 评论
ST25R3916能否对ISO15693的标签芯片进行分区域写密码?
15067 浏览 2 评论
STM32仿真器是选择ST-LINK还是选择J-LINK?各有什么优势啊?
3134浏览 4评论
stm32f4下spi+dma读取数据不对是什么原因导致的?
1923浏览 3评论
STM32F0_TIM2输出pwm2后OLED变暗或者系统重启是怎么回事?
2092浏览 3评论
2003浏览 3评论
stm32cubemx生成mdk-arm v4项目文件无法打开是什么原因导致的?
2200浏览 3评论
/9
GMT+8, 2025-12-8 09:48 , Processed in 0.735200 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
801
