电子发烧友论坛|
1个回答
本文使用的松下伺服为A6B系列, EtherCAT主站搭建方法为IGH EtherCAT Master第三方协议栈。
/***************************************************************************** * Example of Panasonic A6B servo drive setup with IgH EtherCAT Master library * that starts the servo drive in profile velocity mode. * * Licence: the same than IgH EtherCAT Master library * * ABSTRACT: * * This small program shows how to configure a Panasonic A6B servo drive * with IgH EtherCAT Master library. It illustrates the flexible PDO mapping * and the DS402 command register programming in order to start the servo drive * in profile velocity mode. * * Because the Panasonic A6B servo drive follows the DS402 standard, several * sections of this example may apply also to other servo drive models. * * The code is based on a previous example from IgH EtherCAT Master * * Author: Zhou Yonghong * Date: 2018/04/04 * Compile with: gcc testbyesm.c -Wall -I /opt/etherlab/include -l ethercat -L /opt/etherlab/lib -o testbyesm ****************************************************************************/ #include #include #include #include #include #include #include #include #include /****************************************************************************/ #include "ecrt.h" /****************************************************************************/ /*Application Parameters*/ #define TASK_FREQUENCY 100 /*Hz*/ #define TIMOUT_CLEAR_ERROR (1*TASK_FREQUENCY) /*clearing error timeout*/ #define TARGET_VELOCITY 8388608 /*target velocity*/ #define PROFILE_VELOCITY 3 /*Operation mode for 0x6060:0*/ /*****************************************************************************/ /*EtherCAT*/ static ec_master_t *master = NULL; static ec_master_state_t master_state = {}; static ec_domain_t *domain1 = NULL; static ec_domain_state_t domain1_state = {}; static ec_slave_config_t *sc_A6B; static ec_slave_config_state_t sc_A6B_state = {}; /****************************************************************************/ /*Process Data*/ static uint8_t *domain1_pd = NULL; #define A6BSlavePos 0,0 /*EtherCAT address on the bus*/ #define Panasonic 0x0000066F,0x60380004 /*Vendor ID, product code*/ /*Offsets for PDO entries*/ static struct{ unsigned int operation_mode; unsigned int ctrl_word; unsigned int target_velocity; unsigned int status_word; unsigned int mode_display; unsigned int current_velocity; // signed int current_velocity; }offset; const static ec_pdo_entry_reg_t domain1_regs[] = { {A6BSlavePos, Panasonic, 0x6040, 0, &offset.ctrl_word}, {A6BSlavePos, Panasonic, 0x6060, 0, &offset.operation_mode }, {A6BSlavePos, Panasonic, 0x60FF, 0, &offset.target_velocity}, {A6BSlavePos, Panasonic, 0x6041, 0, &offset.status_word}, {A6BSlavePos, Panasonic, 0x6061, 0, &offset.mode_display}, {A6BSlavePos, Panasonic, 0x606C, 0, &offset.current_velocity}, {} }; static unsigned int counter = 0; //static int state = -500; /***************************************************************************/ /*Config PDOs*/ static ec_pdo_entry_info_t A6B_pdo_entries[] = { /*RxPdo 0x1600*/ {0x6040, 0x00, 16}, {0x6060, 0x00, 8 }, {0x60FF, 0x00, 32}, /*TxPdo 0x1A00*/ {0x6041, 0x00, 16}, {0x6061, 0x00, 8}, {0x606C, 0x00, 32} }; static ec_pdo_info_t A6B_pdos[] = { //RxPdo {0x1600, 3, A6B_pdo_entries + 0 }, //TxPdo {0x1A00, 3, A6B_pdo_entries + 3 } }; static ec_sync_info_t A6B_syncs[] = { { 0, EC_DIR_OUTPUT, 0, NULL, EC_WD_DISABLE }, { 1, EC_DIR_INPUT, 0, NULL, EC_WD_DISABLE }, { 2, EC_DIR_OUTPUT, 1, A6B_pdos + 0, EC_WD_DISABLE }, { 3, EC_DIR_INPUT, 1, A6B_pdos + 1, EC_WD_DISABLE }, { 0xFF} }; /**************************************************************************/ /*************************************************************************/ void check_domain1_state(void) { ec_domain_state_t ds; ecrt_domain_state(domain1, &ds); if (ds.working_counter != domain1_state.working_counter) { printf("Domain1: WC %u.n", ds.working_counter); } if (ds.wc_state != domain1_state.wc_state) { printf("Domain1: State %u.n", ds.wc_state); } domain1_state = ds; } void check_master_state(void) { ec_master_state_t ms; ecrt_master_state(master, &ms); if (ms.slaves_responding != master_state.slaves_responding) { printf("%u slave(s).n", ms.slaves_responding); } if (ms.al_states != master_state.al_states) { printf("AL states: 0x%02X.n", ms.al_states); } if (ms.link_up != master_state.link_up) { printf("Link is %s.n", ms.link_up ? "up" : "down"); } master_state = ms; } /*****************************************************************************/ void check_slave_config_states(void) { ec_slave_config_state_t s; ecrt_slave_config_state(sc_A6B, &s); if (s.al_state != sc_A6B_state.al_state) { printf("A6B: State 0x%02X.n", s.al_state); } if (s.online != sc_A6B_state.online) { printf("A6B: %s.n", s.online ? "online" : "offline"); } if (s.operational != sc_A6B_state.operational) { printf("A6B: %soperational.n", s.operational ? "" : "Not "); } sc_A6B_state = s; } /*******************************************************************************/ void cyclic_task() { static unsigned int timeout_error = 0; static uint16_t command=0x004F; static int32_t target_velocity = TARGET_VELOCITY; uint16_t status; int8_t opmode; int32_t current_velocity; // int32_t command_value; /*Receive process data*/ ecrt_master_receive(master); ecrt_domain_process(domain1); /*Check process data state(optional)*/ check_domain1_state(); counter = TASK_FREQUENCY; //Check for master state check_master_state(); //Check for slave configuration state(s) check_slave_config_states(); /*Read inputs*/ status = EC_READ_U16(domain1_pd + offset.status_word); opmode = EC_READ_U8(domain1_pd + offset.mode_display); current_velocity = EC_READ_S32(domain1_pd + offset.current_velocity); printf("A6B: act velocity = %d , cmd = 0x%x , status = 0x%x , opmode = 0x%xn", (current_velocity*60)/target_velocity, command, status, opmode); //DS402 CANOpen over EtherCAT status machine if( (status & command) == 0x0040 ) { EC_WRITE_U16(domain1_pd + offset.ctrl_word, 0x0006 ); EC_WRITE_S8(domain1_pd + offset.operation_mode, PROFILE_VELOCITY); command = 0x006F; } else if( (status & command) == 0x0021) { EC_WRITE_U16(domain1_pd + offset.ctrl_word, 0x0007 ); command = 0x006F; } else if( (status & command) == 0x0023) { EC_WRITE_U16(domain1_pd + offset.ctrl_word, 0x000f ); EC_WRITE_S32(domain1_pd + offset.target_velocity, target_velocity); command = 0x006F; } //operation enabled else if( (status & command) == 0x0027) { EC_WRITE_U16(domain1_pd + offset.ctrl_word, 0x001f); } /*Send process data*/ ecrt_domain_queue(domain1); ecrt_master_send(master); } /****************************************************************************/ int main(int argc, char **argv) { master = ecrt_request_master(0); if (!master) { exit(EXIT_FAILURE); } domain1 = ecrt_master_create_domain(master); if (!domain1) { exit(EXIT_FAILURE); } if (!(sc_A6B = ecrt_master_slave_config(master, A6BSlavePos, Panasonic))) { fprintf(stderr, "Failed to get slave configuration for A6B!n"); exit(EXIT_FAILURE); } // printf("alias=%d,vid=%d,watchdog_divider=%d",sc_A6B->alias,sc_A6B->position,sc_A6B->watchdog_divider); printf("Configuring PDOs...n"); if (ecrt_slave_config_pdos(sc_A6B, EC_END, A6B_syncs)) { fprintf(stderr, "Failed to configure A6B PDOs!n"); exit(EXIT_FAILURE); } else { printf("*Success to configuring A6B PDOs*n"); } if (ecrt_domain_reg_pdo_entry_list(domain1, domain1_regs)) { fprintf(stderr, "PDO entry registration failed!n"); exit(EXIT_FAILURE); } else { printf("*Success to configuring A6B PDO entry*n"); printf("operation_mode=%d, ctrl_word=%d, target_velocity=%d, status_word=%d, mode_display=%d, current_velocity=%dn", offset.operation_mode,offset.ctrl_word,offset.target_velocity,offset.status_word,offset.mode_display,offset.current_velocity); } printf("Activating master...n"); if (ecrt_master_activate(master)) { exit(EXIT_FAILURE); } else { printf("*Master activated*n"); } if (!(domain1_pd = ecrt_domain_data(domain1))) { exit(EXIT_FAILURE); } printf("*It's working now*n"); while (1) { usleep(100000/TASK_FREQUENCY); cyclic_task(); } ecrt_master_deactive(master); return EXIT_SUCCESS; } |
只有小组成员才能发言,加入小组>>
3045 浏览 0 评论
10790 浏览 4 评论
39008 浏览 19 评论
5802 浏览 0 评论
27512 浏览 34 评论
1609浏览 0评论
/9
GMT+8, 2025-12-2 06:21 , Processed in 0.389447 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2119
