MIPI® DSI BRIDGE TO FLATLINK LVDS
Introduction ICN6201 is a bridge chip which receives MIPI® DSI inputs and sends LVDS outputs. MIPI® DSI supports up to 4 lanes and each lane operates at 1Gbps maximum; the totally maximum input bandwidth is 4Gbps; and the MIPI defined ULPS(ultra-low-power state) is also supported. ICN6201 decodes MIPI® DSI 18bepp RGB666 and 24bpp RGB888 packets. The LVDS output 18 or 24 bits pixel with 25MHz to 154MHz, by VESA or JEIDA format. ICN6201 support video resolution up to FHD (1920x1080) and WUXGA(1920x1200). ICN6201 adopts QFN40 and QFN 48pins package. Feature List Supports MIPI ® D-PHY Version 1.00.00 and MIPI ® DSI Version 1.02.00. Single Channel DSI Receiver with One, Two, Three and Four lanes configurable, each lanes operates up to 1Gbps. Receives 18bpp RGB666 and 24bpp RGB888 packets defined by DSI. Supports MIPI Low State, Ultra-Low Power State, Shut Down mode. Single Channel LVDS with output clock range of 25MHz to 154MHz. LVDS can be generated from MIPI HS clock or external reference clock. Support LVDS clock with center spreading up to 2%, modulation 30KHz ~ 60KHz. LVDS output with VESA or JEIDA format. LVDS output pin order can be swapped flexible. supply voltage: 1.8V. provide I2C slave interface. package: QFN40-pins with e-pad. Package: QFN48-pins with e-pad.
488 浏览 0 评论
1591 浏览 0 评论
5877 浏览 0 评论
图腾柱PFC无法上升至400V,且电感电流为正弦波形,但是幅值极小
9869 浏览 0 评论
飞凌嵌入式ElfBoard-Vim编辑器之静态链接和动态链接
2955 浏览 0 评论
/9
GMT+8, 2025-12-18 14:07 , Processed in 0.555313 second(s), Total 70, Slave 50 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
