N5173B
N5173B EXG X-Series Microwave Analog Signal Generator, up to 40 GHz 主要特性与技术指标 Signal characteristics 9 kHz to 13, 20, 31.8 or 40 GHz +20 dBm output power at 20 GHz -101 dBc/Hz phase noise at 10 GHz and 20 kHz offset High stability OCXO < ±5 x 10-10 per day Modulation and sweep AM, FM, ØM and narrow pulse Pulse train generator 10 MHz multifunction generator and LF out Digital step and list sweep modes with <600 µs switching speed Automation and communication interface 1000BaseT LAN, LXI, USB 2.0, and GPIB SCPI, IVI-COM, matlab drivers Backward compatible with all ESG, MXG, PSG and 8648x signal generators Agilent USB power sensor compatible with embedded display and SCPI control 描述 The cost-effective EXG When you need to balance budget and performance the EXG is the best choice. It provides the essential signals that address parametric testing of components and receivers. Maximize budget and performance with outstanding hardware Confidently test components with excellent level accuracy and repeatability Compensate for test system losses with best-in-class output power Maximize throughput with fast switching speed Shrink your test stand with two rack-unit height Get the performance and capabilities you need today and easily upgrade later Maximize resources with low cost of ownership Increase uptime with high mean time between failures (MTBF) based on first-generation MXG track record Minimize downtime and expenses with self-maintenance strategy and low-cost repairs Standard 3-year calibration cycle and warranty |
BP86211D 12V/0.5A家用电器方案DEMO资料分析(电路原理图及BOM)
1505 浏览 0 评论
PD诱骗取电芯片_PD_Sink端芯片之XSP05实战应用电路
2515 浏览 1 评论
BLDC、PMSM电机智能栅极驱动芯片之TMC6140知识分享
1260 浏览 0 评论
国产电源芯片DP4054 软硬件兼容TP4054 规格书资料
1726 浏览 0 评论
3534 浏览 3 评论
/9
GMT+8, 2025-12-14 10:16 , Processed in 0.652588 second(s), Total 48, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1239
