S参数测试仪,天线/滤波器测试仪(9G) 是德科技E5080A-ENA系列 2端口与4端口可选
出售E5080A,出租E5080A,回收E5080A,回收4.5G网络分析仪,6.5G网络分析仪,回收9G网络分析仪 华易测-曾工-1-3-9-2--3-8-5-0-5--1-5--给彼此一个了解的机会,感谢您的支持!! 是德科技E5080A矢量网络分析仪频率范围: E5080A频率范围:9KHz-4.5GHz(两端口,245选件) E5080A频率范围:9KHz-4.5GHz(四端口,445选件) E5080A频率范围:9KHz-6.5GHz(两端口,265选件) E5080A频率范围:9KHz-6.5GHz(四端口,465选件) E5080A频率范围:9KHz-9GHz(两端口,295选件) E5080A频率范围:9KHz-9GHz(四端口,495选件) 以下大量回收及常备安捷伦/惠普网络分析仪:8753A,8753B,8753,8753D,8753E,8753ET,8753ES,8711B, 8712B,8714A,8714B,8714C,8714ET,E5061A,E5062A,E5063A,E8356A,E8357A,E8358A,E8362A,E8362B,E8362C, E8363A,E8363B,E8363,E8364A,E8364B,E8364C,E8361A,E8361C,N5230A,N5230C,N3381A,N3382A,N3383A, E5070A,E5070B,E5071A,E5071B,E5071C,E5072A,E5080A,E5080B,E5061B,N5221A,N5222A,N5224A, N5225,N5227A,N5221B,N5222B,N5224B,N5225B,N5227B,N5241A,N5241B,N5242A,N5242B, N5245,N5245B,N5247A,N5247B,8719A,8719C,8719D,8719ET,8719ES,8720A,8720B,8720C,8720D,8720ET, 8720ES,8722A,8722C,8722D,8722ET,8722ES。 机械/电子校准件:85050B,85050C,85050D,85052B,85052C,85052D,85054B,85054D,85056A,85056D,85058B,85058E, N4430A,N4431A,N4432A,N4433A,N4434A,N4690A,N4690B,N4690C,N4690D,N4691A,N4691B,N4691D, N4692A,N4692D,N4693A,N4693D,N4694A,N4694D,N4696A,N4696B,N4696D,N7550A,N7551A,N7552A, N7553A,N7554A,N7555.85031A,85031B,85032A,85032B,85032E,85032F,85033A,85033B,85033, 85033D,85033E,85036A,85036B,85036E。 测试电缆:85130A,85130B,85130C,85130D,85130E,85130F,85130G,85131A,85131B,85131C, 85131D,85131E,85131F,85131G,85131H,85132A,85132B,85132C,85132D,85132E,85132F, 85133,85133D,85133E,85133F,85133G,85133H,85134C,85134D,85134E,85134F,85134G,85134H, 85135C,85135D,85135E,85135F。 安捷伦ENA系列4.5GHz,6.5GHz,8.5GHz矢量网络分析仪,Keysight是德科技E5080A简要说明: 1,E5080A频率范围9 kHz -4.5GHz,6.5GHz,9 GHz,2 或 4 端口,50 Ω 2,152 dB(典型值)宽广的动态范围 3,3 ms(401 点)快速测量速度 4,0.0005 dBrms(典型值)低迹线噪声 5,0.005 dB/°C 高温度稳定度 6,-90 +15 dBm(技术指标)宽信号源功率范围 7,谐波-20dbm 8,集成的2、3和4端口,带有平衡测量能力 9,夹具嵌入/反嵌和端口特性阻抗转换 10,用于变频设备的频率偏置模式 11,内置Visual Basic . for Applications(VBA) 12,测量向导助手软件 13,直观的触摸屏图形用户界面和宽大的高分辨率 12.1 英寸显示屏 14,与E5071C/8753 代码兼容性 15,与 E5092A 测试仪结合使用可测试多达 40 个端口 , Agilent/E5080A,Keysight/E5080A矢量网络分析仪特性: Keysight E5080A 是是德科技新YI代 ENA 系列网络分析仪,提供业界领XIAN的性能、灵活的功能和XIAN进的可用性。凭借直观的触摸屏界面,E5080A 可以YOU化您的测量流程,帮助您在更短时间内获得更好的测量结果。这款新仪器采用了综合性的平台,将 ENA 和 PNA 系列的优势结合于一身。 E5080A 提供的测量功能,可测量放大器、混频器、滤波器、双工器、天线和电缆(包括平衡被测器件)等有源和无源器件。 在生产线上,改善的模拟测试性能可以确保GENG快的测试吞吐量。在研发实yan室中,更出SE的性能能够为您提供更DA的设计裕量,增的可用性使您对测试结果更加充满信心,并更快将设计的产品推向市场。E5080A 的增性能包括极宽的动态范围,可以满足JIAN端射频器件的重要测量需求。 是德科技E5080A-/安捷伦E5080A-功能选件说明: E5080A-010选件: 时域分析能力 E5080A-008选件: 频率偏置模式 E5080A-790选件: 测量向导助手软件 E5080A-1E5选件: 高稳定度时基 E5080A-017选件: 可移动数据存储 E5080A-019选件: 数据存储 E5080A-TDR选件: 时域分析 E5080A-UNQ选件:稳定性时基 E5080A网络分析仪附件: 11500F电缆,3.5 毫米(阳头) 3.5 mm(阳头),直流 26.5 GHz 11500E电缆,3.5 毫米(阳头) 3.5 mm(阳头),直流 26.5 GHz 85032F校准件 85033E校准件 85092C射频电子校准件 85093电子校准件 N6314A测试端口电缆,N 型,50 欧姆 N6315测试端口电缆,N 型,50 欧姆 ENA-L系列射频网络分析仪频率范围: E5061A频率范围:300KHz1.5GHz E5062A频率范围:300KHz3GHz ENA系列网络分析仪频率范围: E5061B频率范围:100KHz1.5GHz(215选件) E5061B频率范围:100KHz3GHz(235选件) E5061B频率范围:5Hz3GHz(3L5选件) E5063A频率范围:100KHz500MHz(205选件) E5063A频率范围:100KHz1.5GHz(215选件) E5063A频率范围:100KHz3GHz(235选件) E5063A频率范围:100KHz4.5GHz(245选件) E5063A频率范围:100KHz6.5GHz(265选件) E5063A频率范围:100KHz8.5GHz(285选件) E5063A频率范围:100KHz14GHz(2D5选件) E5063A频率范围:100KHz18GHz(2H5选件) E5070A频率范围:300KHz3GHz E5070B频率范围:300KHz3GHz E5071A频率范围:300KHz8.5GHz E5071B频率范围:300KHz8.5GHz E5071C频率范围:9KHz4.5GHz(两端口,240选件) E5071C频率范围:100KHz4.5GHz(两端口,245选件) E5071C频率范围:9KHz4.5GHz(四端口,440选件 ) E5071C频率范围:100KHz4.5GHz (四端口,445选件) E5071C频率范围:100KHZ6.5GHZ(两端口,265选件) E5071C频率范围:100KHZ-6.5GHZ(两端口,260选件) E5071C频率范围:100KHZ6.5GHZ(两端口,465选件) E5071C频率范围:9KHZ6.5GHZ(四端口,460选件) E5071C频率范围:9KHz8.5GHz(两端口,280选件) E5071C频率范围:100KHz8.5GHz(两端口,285选件) E5071C频率范围:9KHz8.5GHz(四端口,480选件) E5071C频率范围:100KHz8.5GHz(四端口,485选件) E5071C频率范围:300KHZ14GHZ(两端口,2D5选件) E5071C频率范围:300KHZ14GHZ(四端口,4D5选件) E5071C频率范围:300KHZ20GHZ(两端口,2K5选件) E5071C频率范围:300KHZ20GHZ(四端口,4K5选件) E5072A频率范围:30KHz4.5GHz(两端口,245选件) E5072A频率范围:30KHz8.5GHz(两端口,285选件) E5080A频率范围:9KHz4.5GHz(两端口,245选件) E5080A频率范围:9KHz4.5GHz(四端口,445选件) E5080A频率范围:9KHz6.5GHz(两端口,265选件) E5080A频率范围:9KHz6.5GHz(四端口,465选件) E5080A频率范围:9KHz9GHz(两端口,295选件) E5080A频率范围:9KHz9GHz(四端口,495选件) E5080B频率范围:9kHz4.5GHz(四端口,440选件) E5080B频率范围:9kHz4.5GHz(两端口,240选件) E5080B频率范围:9kHz4.5GHz(四端口,带二个源,442选件) E5080B频率范围:9kHz6.5GHz(两端口,260选件) E5080B频率范围:9kHz6.5GHz(四端口,460选件) E5080B频率范围:9kHz6.5GHz(四端口,带二个源,462选件) E5080B频率范围:9kHz9GHz(两端口,290选件) E5080B频率范围:9kHz9GHz(四端口,490选件) E5080B频率范围:9kHz9GHz(四端口,带二个源,492选件) E5080B频率范围:9kHz14GHz(两端口,2D0选件) E5080B频率范围:9kHz14GHz(四端口,4D0选件) E5080B频率范围:9kHz14GHz(四端口,带二个源,4D2选件) E5080B频率范围:9kHz18GHz(两端口,2H0选件) E5080B频率范围:9kHz18GHz(四端口,4H0选件 ) E5080B频率范围:9kHz18GHz(四端口,带二个源,4H2选件 ) E5080B频率范围:9kHz20GHz(两端口,2K0选件) E5080B频率范围:9kHz20GHz(四端口,4K0选件) E5080B频率范围:9kHz20GHz(四端口,带二个源,4K2选件) E5080B频率范围:100kHz26.5GHz(两端口,2L0选件) E5080B频率范围:100kHz26.5GHz(四端口,4L0 选件) E5080B频率范围:100kHz26.5GHz(四端口,带二个源,4L2选件) E5080B频率范围:100kHz32GHz(两端口,2M0选件) E5080B频率范围:100kHz32GHz(四端口,4M0选件) E5080B频率范围:100kHz32GHz(四端口,带二个源,4M2选件) E5080B频率范围:100kHz44GHz(两端口,2N0选件) E5080B频率范围:100kHz44GHz(四端口,4N0选件) E5080B频率范围:100kHz44GHz(四端口,带二个源,4N2选件) E5080B频率范围:100kHz53GHz(两端口,2P0选件) E5080B频率范围:100kHz53GHz(四端口,4P0选件) E5080B频率范围:100kHz53GHz(四端口,带二个源,4P2选件) S参数测试仪,天线/滤波器测试仪(9G) 是德科技E5080A-ENA系列 2端口与4端口可选 |
相关推荐 |
BP86211D 12V/0.5A家用电器方案DEMO资料分析(电路原理图及BOM)
1498 浏览 0 评论
PD诱骗取电芯片_PD_Sink端芯片之XSP05实战应用电路
2514 浏览 1 评论
BLDC、PMSM电机智能栅极驱动芯片之TMC6140知识分享
1258 浏览 0 评论
国产电源芯片DP4054 软硬件兼容TP4054 规格书资料
1720 浏览 0 评论
3530 浏览 3 评论
/9
GMT+8, 2025-12-11 05:01 , Processed in 0.791954 second(s), Total 54, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2919
