Avnet公司的DVI I/O FMC模块提供数字视频接口,直接连接到Xilinx® Spartan®-6或 Virtex®-6 FMC使能的基板,数字DVI视频源为模块提供视频内容,而模块提供数字DVI和DisplayPort输出,用来显示FPGA驱动的视频内容。本文介绍了DVI I/O FMC模块主要特性,框图,DVI输入和输出框图,DisplayPort输出框图,以及模块电路图和材料清单(BOM)。
This FMC module provides a direct interface to digital video to Xilinx® Spartan®-6 or Virtex®-6 FMC-enabled baseboards. A digital DVI video source can provide video content to the module. The module also provides digital DVI and DisplayPort outputs to display FPGA driven video content. The DVI I/O FMC Module is not a stand-alone module, but rather a plug-in module designed to interface with FMC compatible baseboards. In that role, the DVI I/O FMC Module provides a number of video interfaces to its host via a LPC FMC connector. The DVI I/O FMC Module is a low pin count (LPC) FMC module containing interfaces intended for video processing. This module contains no processing intelligence and requires that it be plugged into a compatible baseboard for power, control and data processing. DVI I/O FMC模块主要特性: Video Input — DVI input interface (HDMI connector) Video Output — DVI output interface (HDMI connector) — DisplayPort output interface Clock Source — Video clock synthesizer I2C Configuration — IPMI Identification EEPROM — Peripheral configuration Other I/O — General-purpose I/O pins 13.gif 图1.DVI I/O FMC模块外形图 12.gif 图2.DVI I/O FMC模块框图 11.gif 图3.DVI I/O FMC模块DVI输入框图 10.gif 图4.DVI I/O FMC模块DVI输出框图 9.gif 图5.DVI I/O FMC模块DisplayPort输出框图 8.gif 图6.DVI I/O FMC模块电路图(1) 7.gif 图7.DVI I/O FMC模块电路图(2) 6.gif 图8.DVI I/O FMC模块电路图(3) 5.gif 图9.DVI I/O FMC模块电路图(4) 4.gif 图10.DVI I/O FMC模块电路图(5) 3.gif 图11.DVI I/O FMC模块电路图(6) DVI I/O FMC模块材料清单(BOM): 2.gif 1.gif 详情请见: https://www.em.avnet.com/Support%20And%20Downloads/AES-FMC-DVI-G-01_HG.pdf 和 https://www.em.avnet.com/Support%20And%20Downloads/AES-FMC-DVI-G-01-SCH_041310.pdf |
只有小组成员才能发言,加入小组>>
791 浏览 0 评论
1151 浏览 1 评论
2527 浏览 5 评论
2860 浏览 9 评论
移植了freeRTOS到STMf103之后显示没有定义的原因?
2710 浏览 6 评论
keil5中manage run-time environment怎么是灰色,不可以操作吗?
1070浏览 3评论
193浏览 2评论
455浏览 2评论
368浏览 2评论
M0518 PWM的电压输出只有2V左右,没有3.3V是怎么回事?
453浏览 1评论
GMT+8, 2024-12-22 16:12 , Processed in 1.111759 second(s), Total 77, Slave 58 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
