Microchip公司的PIC32系列MCU采用5级流水线MIPS32® M4K® 32位内核,工作频率80MHz,在零等待状态闪存接入时的性能为1.56 DMIPS/MHz (Dhrystone 2.1), MCU工作电压2.3V- 3.6V,具有众多的外设,有两个编程和调试接口,多达16路10位ADC和两个模拟比较器,主要用于超小型图像/用户接口,以太网/USB/CAN/连接,多任务嵌入控制和高性能音频。本文介绍了PIC32 MCU主要特性,方框图,以及PIC32音频开发板主要特性及主要元件,电路图和PCB布局图。
Microchip’s 32-bit portfolio with the MIPS® M4K® offers high performance microcontrollers, and all the tools needed to develop your embedded project. With free software, low cost development tools, and pin/peripheral compatibility from 16-bit product lines, PIC32 MCUs shorten time to market and allow your designs to grow. PIC32 gives your application the processing power, memory and peripherals your design needs! PIC32 MCU主要特性: High-Performance 32-bit RISC CPU: • MIPS32® M4K® 32-bit core with 5-stage pipeline • 80 MHz maximum frequency • 1.56 DMIPS/MHz (Dhrystone 2.1) performance at zero Wait state Flash access • Single-cycle multiply and high-performance divide unit • MIPS16e® mode for up to 40% smaller code size • Two sets of 32 core register files (32-bit) to reduce interrupt latency • Prefetch Cache module to speed execution from Flash Microcontroller Features: • Operating voltage range of 2.3V to 3.6V • 64K to 512K Flash memory (plus an additional 12 KB of Boot Flash) • 16K to 128K SRAM memory • Pin-compatible with most PIC24/dsPIC® DSC devices • Multiple power management modes • Multiple interrupt vectors with individually programmable priority • Fail-Safe Clock Monitor mode • Configurable Watchdog Timer with on-chip Low-Power RC oscillator for reliable operation Peripheral Features: • Atomic SET, CLEAR and INVERT operation on select peripheral registers • Up to 8-channels of hardware DMA with automatic data size detection • USB 2.0-compliant full-speed device and On-The-Go (OTG) controller: - Dedicated DMA channels • 10/100 Mbps Ethernet MAC with MII and RMII interface: Dedicated DMA channels • CAN module: - 2.0B Active with DeviceNet™ addressing support - Dedicated DMA channels • 3 MHz to 25 MHz crystal oscillator Peripheral Features (Continued): • Internal 8 MHz and 32 kHz oscillators • Six UART modules with: - RS-232, RS-485 and LIN support - IrDA® with on-chip hardware encoder and decoder • Up to four SPI modules • Up to five I2C™ modules • Separate PLLs for CPU and USB clocks • Parallel Master and Slave Port (PMP/PSP) with 8-bit and 16-bit data, and up to 16 address lines • Hardware Real-Time Clock and Calendar (RTCC) • Five 16-bit Timers/Counters (two 16-bit pairs combine to create two 32-bit timers) • Five Capture inputs • Five Compare/PWM outputs • Five external interrupt pins • High-speed I/O pins capable of toggling at up to 80 MHz • High-current sink/source (18 mA/18 mA) on all I/O pins • Configurable open-drain output on digital I/O pins Debug Features: • Two programming and debugging Interfaces: - 2-wire interface with unintrusive access and real-time data exchange with application - 4-wire MIPS® standard enhanced Joint Test Action Group (JTAG) interface • Unintrusive hardware-based instruction trace • IEEE Standard 1149.2 compatible (JTAG) boundary scan Analog Features: • Up to 16-channel, 10-bit Analog-to-Digital Converter: - 1 Msps conversion rate - Conversion available during Sleep and Idle • Two Analog Comparators PIC32 MCU主要应用: High Impact Graphics/User Interfaces Ethernet/USB/CAN/Connectivity Multitasking Embedded Control High Performance Audio 20120524092519313.gif 图1.PIC32 MCU方框图 PIC32音频开发板 Audio Development Board The audio development board for PIC32 (DM320011) provides developers a flexible platform for 24-bit audio record and playback, USB Digital Audio, MP3 Decode and Sample Rate Conversion. The board also provides an interface to Microchip’s 16/32-bit PIC® MCU Accessory Development Platform for iPod and iPhone enabling Apple® authorized MFi licensees. PIC32音频开发板主要特性: • High-performance MCU • Wolfson WM8960 audio codec with up to 48 kHz sampling rate and up to 24-bit resolution • Headphone out, Line-in jacks, and an on-board MIC • TFT color display with 220x176 resolution • PICtail™ Plus Connector • General purpose user switches and LEDs 20120524092520357.gif 图2.音频开发板外形图和元件分布图 音频开发板元件表: 20120524092520528.gif 20120524092520376.gif 图3.音频开发板电路图:显示电路 20120524092520956.gif 图4.音频开发板电路图:音频电路 20120524092520503.gif 图5.音频开发板电路图:MCU和USB电路 20120524092520607.gif 图6.开发板电路图:电源电路 2012052409252077.gif 图7.音频开发板电路图:通信电路(扩展连接器,ICSP,开关和LED) 20120524092520166.gif 图8.音频开发板PCB布局图:顶层 详情请见: 61156G.pdf(5.22 MB)2012-5-24 11:37 上传 -1 和 ADB for PIC32 User Guide.pdf(1.08 MB)2012-5-24 11:37 上传 -1 |
只有小组成员才能发言,加入小组>>
771 浏览 0 评论
1146 浏览 1 评论
2527 浏览 5 评论
2858 浏览 9 评论
移植了freeRTOS到STMf103之后显示没有定义的原因?
2709 浏览 6 评论
keil5中manage run-time environment怎么是灰色,不可以操作吗?
1054浏览 3评论
189浏览 2评论
453浏览 2评论
364浏览 2评论
M0518 PWM的电压输出只有2V左右,没有3.3V是怎么回事?
449浏览 1评论
GMT+8, 2024-12-18 13:30 , Processed in 1.692585 second(s), Total 81, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
