电子发烧友论坛扫一扫,分享给好友
1个回答
Cirrus公司的CS4953xx是32位音频DSP系列,工作频率150MHz,在片内的ROM中包括所有主流音频处理代码,从而节省了外接存储器和代码存储.不需要昂贵的外接SDRAM存储器就能完成Dolby数字环绕EX®, AAC多路, DTS-ES 96/24, THX Ultra2影院和Dolby耳机的译码任务,是下一代音频解决方案.本文介绍了CS4953xxx系列主要特性,方框图,CDB49x主板框图和相应的元件,DC4953x子板框图和相应的元件以及板的建立和连接图.
The CS4953xx DSP family are the enhanced versions of the CS495xx DSP family with higher overall performance and lower system cost. The CS4953xx includes all mainstream audio processing codes in on-chip ROM. This saves external memory for code storage. In addition, the intensive decoding tasks of Dolby Digital Surround EX®, AAC multi-channel, DTS-ES 96/24, THX Ultra2 Cinema and Dolby Headphone can be accomplished without the expense of external SDRAM memory. With larger internal memories than the CS495xx, the CS49531x is designed to support up to 150 ms per channel of lip-sync delay. With 150 MHz internal clock speed, the CS4953xx supports the most demanding post-processing requirements. It is also designed for easy upgrading. Customers currently using the CS495xx can upgrade to the CS4953xx with minor hardware and software changes The CS4953xx DSP Family, together with Cirrus Logic’s comprehensive library of audio processing algorithms enables the development of next-generation audio solutions. There are twoses of devices in the CS4953xx DSP family: • CS4953x3 Class (ROM ID 3), comprising the CS495303 and the CS495313 • CS4953x4 Class (ROM ID 4), comprising the CS495304 and the CS495314 The primary difference between the CS4953x3 and the CS4953x4ses is the support of the DSP Condenser application on the CS4953x4s of products only. The DSP Condenser is a tool set that enables the DSP to automatically boot and configure itself from an external serial FLASH, thus reducing the traditional heavy loading on the part of the system microcontroller. CS4953xxx系列主要特性: Multi-standard 32-bit Audio Decoding plus Post processing Supports legacy audio formats and a wide array of postprocessing — Dolby Digital® EX, Dolby Pro Logic® II, IIx, IIz 7.1,Dolby Headphone® 2, Dolby Virtual Speaker® 2,Dolby Volume® (original), Dolby Volume 258™ (lite),Audistry® — DTS-ES 96/24™ Discrete 7.1, DTS-ES™ Discrete 7.1,DTS-ES™ Matrix 6.1, DTS Neo:6®, DTS Neural Surround™ DTS Surround Sensation Speaker — MPEG-2 AAC™ LC 5.1 — SRS® Circle Surround® II, SRS Circle Surround Auto,SRS Circle Surround Decoder Optimized, SRS TruVolume™ 7.1 (V 2.1.0.0), SRS TruSurround HD/HD4®, SRS WOW HD™, SRS CS Headphone™, SRS Circle Cinema 3D™, SRS Studio Sound HD™ — THX® Ultra2™, THX Select2™ Cirrus Logic’s Applications Library — Cirrus Original Multi-Channel Surround 2 (COMS2), Cirrus Band XpandeR™, Cirrus Virtualization Technology (CVT), Cirrus Intelligent Room Calibration 2 (IRC2), Cirrus Bass Enhancement (CBE) — Cros***ar Mixer, Signal Generator — Advanced Post-Processors including: 7.1 Bass Manager Quadruple Crossover, Tone Control, 11-Band Parametric EQ, Delay, 2:1/4:1 Decimator, 1:2/1:4 Upsampler Up to 12 Channels of 32-bit Serial Audio Input 图1.CS4953x4功能框图 图2.CDB49x主板外形图 图2 CDB49x主板对应的元件: 1. LCD 2. HDMI Receiver (Rx) 3. Extended Display Identification Data (EDID) Programming Header 4. HDMI Input Connector 5. Hot Plug Indicator 6. HDMI Transmitter (Tx) 7. HDMI Output Connector 8. S/PDIF Optical Tx 9. S/PDIF Coax Rx 10. S/PDIF Optical Rx 11. +5V Header 12. +1.8V Header 13. Dual Zone Analog Outputs 14. Headphone Output 15. Main Analog Line-Level Outputs (Left/Right; Left Surround/Right Surround; Center/Subwoofer;Surround Back Left/Surround Back Right) 16. Cirrus Logic CS42528 CODEC 17. Cirrus Logic CS2000 Clock Generator and Clock Multiplier/Jitter-Reduced Clock Frequency Synthesizer 18. DAO Selection 19. Analog Line-Level Input 20. Mic Input 21. Power Indicator LEDs (4) 22. Slave Boot Control 23. Power Switch 24. +9V Power Connector 25. DAO Mux Header 26. +3.3V Header 27. Daughter Card Connectors (2) 28. DAI 1, 2, and 3 Header 29. DSD/I2S Mux LED 30. MCU Programming Header (C2 Header) 31. USB Connector 32. USB Active LED 33. 8051 MCU 34. IR Receiver 35. System Reset 36. Rotary Encoder Knob 37. MCU Buttons (4) (Menu, Left, Right, Exit) 38. MCU LEDs (4) 图3. DC4953x/DC4953x3/DC4970x4子板外形图 DC4953x子板对应的元件: 1. Cirrus Logic CS4953x DSP (U1) 2. 24.576 MHz Crystal (Y1) 3. Debug Header (P5) 4. ESMT 16-Mbit SDRAM (U2) 5. Power LEDs (2) 图4.CDB49x主板框图 图5.DC4953x 子板框图 图6.板的建立和连接图 详情请见: -1 和 -1 |
只有小组成员才能发言,加入小组>>
1027 浏览 1 评论
1856 浏览 0 评论
1837 浏览 1 评论
3261 浏览 5 评论
3587 浏览 9 评论
1031浏览 1评论
1855浏览 1评论
如何知道嵌入式电子控制单元 (ECU) 中的RAM使用情况?
1367浏览 1评论
1860浏览 0评论
1185浏览 0评论
/9
GMT+8, 2025-12-3 17:28 , Processed in 0.640474 second(s), Total 74, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1196
