各位大神,小弟新使用msp430F6726AIPZ做开发,遇到晶振不起振问题,头疼不已,还请各位大神指点迷津。
主要问题:使用32.768kHz晶振接MCU24,25管脚(XIN,XOUT),根据规格书使用12pF的匹配电容,晶振不起振,更换3pF,6pF,9pF,15pF,22pF,30pF,47pF匹配电容还是不起振,询问ti技术人员也没给出具体解决办法,基本上也是从PCB布线,电容匹配方面给分析的,但都已试过,没起作用,由于此款MCU自带晶振,外部晶振不起振会转到内部晶振起振,以下是源码部分从TI官网上弄得: vint main(void) { WDTCTL = WDTPW | WDTHOLD; // Stop WDT // Setup P1.0 output, J1.0 SMCLK, J1.1 MCLK, J1.3 ACLK P1DIR |= BIT0; // Set P1.0 to output direction P1OUT &= ~BIT0; // Clear P1.0 PJDIR |= BIT0 | BIT1 | BIT3; // ACLK, MCLK, SMCLK set out to pins PJSEL |= BIT0 | BIT1 | BIT3; // PJ.0,1,3 for debugging purposes. // Setup LFXT1 UCSCTL6 &= ~(XT1OFF); // XT1 On UCSCTL6 |= XCAP_3; // Internal load cap // Loop until XT1 fault flag is cleared do { UCSCTL7 &= ~XT1LFOFFG; // Clear XT1 fault flags } while (UCSCTL7 & XT1LFOFFG); // Test XT1 fault flag // Initialize DCO to 2.45MHz __bis_SR_register(SCG0); // Disable the FLL control loop UCSCTL0 = 0x0000; // Set lowest possible DCOx, MODx UCSCTL1 = DCORSEL_3; // Set RSELx for DCO = 4.9 MHz UCSCTL2 = FLLD_1 | 74; // Set DCO Multiplier for 2.45MHz // (N + 1) * FLLRef = Fdco // (74 + 1) * 32768 = 2.45MHz // Set FLL Div = fDCOCLK/2 __bic_SR_register(SCG0); // Enable the FLL control loop // Worst-case settling time for the DCO when the DCO range bits have been // changed is n x 32 x 32 x f_MCLK / f_FLL_reference. See UCS chapter in 5xx // UG for optimization. // 32 x 32 x 2.45 MHz / 32,768 Hz = 76563 = MCLK cycles for DCO to settle __delay_cycles(76563); // Loop until XT1, XT2 & DCO fault flag is cleared do { UCSCTL7 &= ~(XT2OFFG | XT1LFOFFG | DCOFFG); // Clear XT2,XT1,DCO fault flags SFRIFG1 &= ~OFIFG; // Clear fault flags } while (SFRIFG1 & OFIFG); // Test oscillator fault flag while (1) { P1OUT ^= BIT0; // Toggle P1.0 __delay_cycles(600000); // Delay } } } 实在不清楚到底哪出问题了,还望使用过此芯片的大神给指导一二。
3 个讨论
这是晶振的电路部分
看来大家没大用过此芯片,我只能曲线救国了
问题已解决,例程没问题
只有小组成员才能发言,加入小组>>
3327个成员聚集在这个小组
加入小组9555 浏览 1 评论
10355 浏览 1 评论
MSP430FR5994 使用库函数 定时器触发AD问题请教
10677 浏览 2 评论
请问怎么把下面51单片机的代码改成msp430 g2 pocket的代码,还有改下时间变成30秒
2657 浏览 1 评论
5114 浏览 1 评论
10677浏览 2评论
10355浏览 1评论
9555浏览 1评论
8214浏览 0评论
/9
GMT+8, 2025-12-1 22:12 , Processed in 0.820818 second(s), Total 59, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2952
