概述:8809CSBNG4H99是一款双列密64脚封装。
引脚功能和电压参数值
| 脚号 | 符号 | 有信号电压/V | 黑笔接地电阻/KΩ | 红笔接地电阻/KΩ | 功能说明 | | 1 | SVIDEO | 4.6 | 7 | 11 | S端子亮度输入 | | 2 | MUTE | 0 | 7 | 11 | 静音输出 | | 3 | KEY in | 0.3 | 7 | 9.4 | 按键矩阵输入 | | 4 | UP Dvss | 0 | 0 | 0 | 接地端 | | 5 | RESET | 4.8 | 4.6 | 4.6 | 复位脚 | | 6 | X in | 2.1 | 7.7 | 12.2 | 晶振输入 | | 7 | X out | 0.9 | 7.7 | 12.2 | 晶振输出 | | 8 | TEST | 0 | 0 | 0 | 测试脚 | | 9 | UP Dvvd | 4.8 | 2.2 | 2.2 | +5V供电 | | 10 | UP Dvss | 0 | 0 | 0 | 接地脚 | | 11 | TV AGND | 0 | 0 | 0 | 接地脚 | | 12 | FBP | 1 | 1 | 27.8 | 回扫脉冲输入 | | 13 | Hout | 1.8 | 1.8 | 0.5 | 行激励输出端 | | 14 | HAFC | 6.4 | 6.4 | +∞ | 行同步信号分离滤波 | | 15 | VSAW | 4 | 4 | 27.5 | 常锯齿波滤波端 | | 16 | Vout | 4.6 | 4.6 | 13.5 | 场激励输出端 | | 17 | HvCC | 9.2 | 9.2 | 9.1 | 行启动电源 | | 18 | NC | 0.9 | 0.9 | 0.8 | 空脚 | | 19 | Cb in | 9.9 | 9.9 | 13 | B-Y信号输入 | | 20 | Y in | 9.7 | 9.7 | 13 | Y信号输入端 | | 21 | Cr in | 9.9 | 9.9 | 12.8 | R-Y信号输入端 | | 22 | VD AND | 0 | 0 | 0 | 接地端 | | 23 | C in | 9.8 | 9.8 | 12.8 | 色度信号输入端 | | 24 | V2 in | 9.8 | 9.8 | 12.8 | 视频2信号输入端 | | 25 | TV DVcc | 3.4 | 3.4 | 9.1 | 罗辑电源端 | | 26 | VI in | 2 | 2 | 12.8 | 视频输入端 | | 27 | ABCL | 3.8 | 3.8 | 12 | 自动亮度色度控制端 | | 28 | AU out | 3.4 | 3.4 | 11 | 音频信号输出端 | | 29 | IF Vcc | 8.7 | 8.7 | 0.3 | 中频+9V供电端 | | 30 | TV out | 3.5 | 3.5 | 10.2 | 视频信号输出端 | | 31 | SIF out | 1.8 | 1.8 | 13 | 伴音信号输出端 | | 32 | EXT AU in | 3.1 | 10 | 12 | 外部音频信号输入端 | | 33 | SIF in | 2.1 | 9.5 | 13 | 伴音信号输入端 | | 34 | DC NF | 2 | 9.9 | 12 | 直流负反馈外接电容 | | 35 | PIF PLL | 2.4 | 9.9 | 12.8 | PIF锁相环 | | 36 | IF Vcc | 4.4 | 0.8 | 0.8 | +5V供电脚(IF) | | 37 | Reg Fil | 2 | 9.5 | 11 | 外接电容滤波端 | | 38 | Deempha | 4.2 | 9.7 | 12 | SIF去加重 | | 39 | IF AGC | 1.5 | 9.8 | 12.8 | IF AGC滤波 | | 40 | IF GND | 0 | 0 | 0 | 接地端(IF) | | 41 | IF in | 0 | 9 | 12.2 | 中频信号输入 | | 42 | IF in | 0 | 9 | 12.2 | 中频信号输入 | | 43 | RF AGC | 1.6 | 9.5 | 11.2 | RI AGC输出端 | | 44 | TV YC VCC | 4.4 | 0.8 | 0.8 | +5V供电端 | | 45 | Monitoy out | 1.7 | 3 | 3 | 监测输出 | | 46 | BLACK DET | 2.4 | 10 | 12.5 | 黑电平检波 | | 47 | Chroma PLL | 1.7 | 9.9 | 13 | 彩色锁相环 | | 48 | IK in | 0 | 0 | 0 | 阴极检测电流输入端 | | 49 | RGB Vcc | 8.7 | 0..3 | 0.3 | R G B电源 | | 50 | Rout | 2.5 | 9.7 | 9.8 | 红基色信号输出 | | 51 | Gout | 2.5 | 9.7 | 9.8 | 绿基色信号输出 | | 52 | Bout | 2.5 | 9.7 | 9.8 | 蓝基色信号输出 | | 53 | TV AGND | 0 | 0 | 0 | 接地端 | | 54 | UP AGND | 0 | 0 | 0 | 接地脚 | | 55 | UP AVdd | 4.8 | 2.2 | 2.2 | +5V供电 | | 56 | BAND | 4.8 | 5.6 | 6 | 波段控制 | | 57 | SDA | 4.6 | 6.2 | 10.8 | I2C串行数据入/出 | | 58 | SCL | 4.6 | 6.8 | 10.8 | I2C串行数据入/出 | | 59 | VOL | 2.3 | 2.2 | 2.4 | 音量控制 | | 60 | VT | 4.6 | 7.5 | 11.8 | 调谐控制输出 | | 61 | BAND | 0.1 | 5 | 5.1 | 波段控制1 | | 62 | HSYNC | 3.4 | 7.4 | 11.2 | 行同步脉冲输入 | | 63 | RMT in | 4.2 | 7.2 | 12 | 遥控信号输入 | | 64 | power | 0.1 | 3.4 | 3.5 | 电源待机控制输出 |
