用于3G网络分析仪85036A校准器 75欧姆85036B 安捷伦85036E深圳10套
出售85036A,出租85036A,回收85036A,回收机械校准件,回收电子校准件 出售85036B,出租85036B,回收85036B,回收机械校准件,回收电子校准件 出售85036E,出租85036E,回收85036E,回收机械校准件,回收电子校准件 技术员:(曾工-1-3-9-2--3-8-5-0-5--1-5--)给彼此一个了解的机会,感谢您的支持!!! 大量是德科技keysight,惠普hp,安捷伦agilent回收校准套件,大量租售校准套件,以下型号: 机械校准件: 85031A,85031B,85032A,85032B,85032E,85032F,85033A,85033B, 85033C,85033D,85033E,85034A,85035A,85036A,85036B,85036E。 85050B,85050C,85050D,85051A,85051B,85052A,85052B,85052C,85052D,85052E, 85053A,85053B,85054A,85054B,85054D,85055A,85056A,85056K, 85056KE01,85056KE02,85056D,85057A,85057B, 85058B,85058D,85058E,85058V, 85059A,85059B,85059V。85514A,85515A,85518A,85519A,85520A,85521A 电子校准件: 85060A,85060B,85060C, 85062A,85062B,85062C, 85064A,85064B. N4430A,N4431A,N4432A,N4433A,N4434A,N4690A,N4690B,N4690C,N4690D,N4691A,N4691B,N4691D, N4692A,N4692D,N4693A,N4693D,N4694A,N4694D,N4696A,N4696B,N4696D,N7550A,N7551A,N7552A, N7553A,N7554A,N7555A. 波导校准件:X11644A,P11644A ,K11644A,R11644A ,Q11644A ,U11644A ,V11644A ,W11644A 。 测试电缆:85130A,85130B,85130C,85130D,85130E,85130F,85130G,85131A,85131B,85131C, 85131D,85131E,85131F,85131G,85131H,85132A,85132B,85132C,85132D,85132E,85132F, 85133C,85133D,85133E,85133F,85133G,85133H,85134C,85134D,85134E,85134F,85134G,85134H, 85135C,85135D,85135E,85135F。 机械校准套件说明: 85031A(APC-7), 85031B,机械校准套件,频率范围从直流至6GHz, ,7 mm 85032A,85032B,85032E,机械校准套件,频率范围从直流至6GHz,Type-N 85032F,机械校准套件,频率范围从直流至9GHz,N型,50欧姆 85033A SMA校准套件,50欧姆 ,85033B APC-3.5校准套件,85033C 3.5mm校准套件 85033D 3.5mm校准件,频率范围从直流至6GHz 85033E,3.5 mm机械校准套件,频率范围从直流至9GHz, 85034A GR-900校准套件,85035A校准套件 85036A N型校准套件 85036B,85036E校准套件,N型,频率范围从直流至3 GHz,75欧姆 85038A,85038F,85038M校准套件,7-16频率范围从直流至7.5 GHz(可用频率达8 GHz) 85039A,85039B, F型校准套件,频率范围从直流至3 GHz,75欧姆 85050A,85050B,85050C,85050D,机械校准套件, 频率范围从直流至18GHz7 mm 85051A,85051B,机械校准套件, 频率范围从300KHz至18GHz,7 mm 85052A,85052B,85052C,85052D,85052E机械校准套件,频率范围从直流至26.5GHz, 3.5 mm 85053A,85053B,机械校准套件,频率范围从300KHz至26.5GHz, 3.5 mm 85054A,85054B,85054D,机械校准套件,频率范围从直流至18GHz, Type-N, 50 ohm 85055A,机械校准套件,频率范围从300KHz至18GHz, Type-N, 50 ohm 85056A,85056D, 机械校准套件,频率范围直流至50GHz,2.4 mm 85056K,85056KE01,85056KE02, 机械校准套件,直流至40GHz,2.4 mm(阴头)至 2.92 mm(阴头) 85057A,85057B, 机械校准套件,频率范围40MHz至50GHz,2.4 mm 85058B,85058D,85058E,85058V,机械校准套件,频率范围从直流至67GHz, 1.85 mm 85059A,85059B,85059V,机械校准套件,频率范围从直流至120GHz, 1 mm 85514A , 4 合1 OSLT 机械校准套件,率范围从DC 至 9 GHz,N 型(阳头),50 85515A ,4 合1 OSLT 机械校准套件,率范围从DC 至 9 GHz,N 型(阴头),50 85518A ,4 合1 OSLT 机械校准套件,率范围从DC 至 18 GHz,N 型(阳头)50 85519A, 4 合1 OSLT 机械校准套件,率范围从DC 至 18 GHz,N 型(阴头)50 85520A ,4 合1 OSLT 机械校准套件,率范围从DC 至 26.5 GHz,3.5 mm(阳头)50 85521A ,4 合1 OSLT 机械校准套件,率范围从DC 至 26.5 GHz,3.5 mm(阴头)50 电子校准件说明: 85060A,85060B,85060C, 2端口电子校准(ECal),频率范围1GHz至18 GHz,7mm 85062A,85062B,85062C, 2端口电子校准(ECal),频率范围1GHz至26.5GHz,3.5mm 85064A,85064B,2端口电子校准(ECal),频率范围1GHz至18GHz,Type-N N4430A ,4端口射频ECal模块,频率范围30 kHz至6 GHz,3.5mm(阴)连接器 N4430B ,4端口ECal模块,频率范围300 kHz至9 GHz,3.5mm(阴)连接器 N4431A ,4 端口射频电子校准件(ECal),频率范围9 kHz至 9GHz,(可选3.5 mm,N 型 50Ω 和 7-16) N4431B ,4 端口射频电子校准件(ECal),频率范围9 kHz至13.5 GHz,(可选3.5 mm,N 型 50Ω 和 7-16) N4431D ,4 端口射频电子校准件(ECal),直流至13.5GHz,(可选 N 型、3.5 mm、7-16 和 4.3-10) N4432A,4 端口电子校准件,频率范围300kHz到18 GHz,(可选3.5 mm和N型) N4432D,4 端口电子校准件,频率范围300kHz到18 GHz,(可选3.5 mm和N型) N4433A ,4端口微波电子校准件, 频率范围300 kHz至20 GHz,(3.5mm阴和阳可选) N4433D ,4 端口射频电子校准件(ECal),频率范围直流/300 kHz 至 26.5 GHz(3.5mm阴和阳可选) N4696A,N4696B,N4696D,2端口电子校准件(ECal),频率范围从直流/10MHz至18GHz,(7 mm阴和阳可选) N4690A ,N4690B ,N4690C ,N4690D ,2 端口微波电子校准件,频率范围从300 kHz至18GHz,(N型阴和阳可选) N4691A,N4691B,N4691D ,2端口微波电子校准件, 频率范围从直流/300 kHz至26.5 GHz,(3.5 mm阴和阳可选) N4692A,N4692D,2端口电子校准件(ECal),频率范围从直流/10MHz至40 GHz,(2.92 mm阴和阳可选) N4693A,N4693D,2端口电子校准件(ECal),频率范围从直流/10MHz至50 GHz,(2.4 mm阴和阳可选) N4694A,N4694D,2端口电子校准件(ECal),频率范围从直流/10MHz至67 GHz,(1.85 mm阴和阳可选) N7550A ,2端口电子校准件(ECal),频率范围从DC至4 GHz,(可选N型和3.5mm) N7551A ,2端口电子校准件(ECal),频率范围从DC至6.5GHz,(可选N型和3.5mm) N7552A ,2端口电子校准件(ECal),频率范围从DC至9GHz,(可选N型和3.5mm) N7553A ,2端口电子校准件(ECal),频率范围从DC至14GHz,(可选N型和3.5mm) N7554A ,2端口电子校准件(ECal),频率范围从DC至18GHz,(可选N型和3.5mm) N7555A ,2端口电子校准件(ECal),频率范围从DC至26.5GHz,(3.5mm) 波导校准套件说明: X11644A,波导机械校准套件,频率范围从8.2GHz至12.4 GHz,WR-90 P11644A ,波导机械校准套件,频率范围从12.4GHz至18.0 GHz,WR-62 K11644A,波导机械校准套件,频率范围从18GHz至 26.5 GHz,WR-42 R11644A ,波导机械校准套件,频率范围从26.5GHz至40GHz,WR-28 Q11644A ,波导机械校准套件,频率范围从33GHz至50GHz,WR-22 U11644A ,波导机械校准套件,频率范围从40GHz至60GHz,WR-19 V11644A ,波导机械校准套件,频率范围从50 至 75 GHz,WR-15 W11644A ,波导机械校准套件,频率范围从75 至 110 GHz,WR-10 校准件篇 校准套件组成部分:开路(Open),短路(Short),负载(load),直通(Through) 很多工程师在使用网络分析仪的时候对于校准都很头痛。怎么做?做什么?这些都是工程师要考虑的问题,下面为大家分享网络分析仪校准的注意事项: 是不是每次测量一个新的项目前都必须做校准? 这个是不一定需要的,尽量将每次校准的state存入VNA,名字zu1好为校准状态,例如频率范围,输入激励功率等。如果有新的测试项目,但是它的测试条件和已有状态相似,且loadstate后,检查校准状态良好,就可用使用以前的校准状态,而不需要重新校准。将校准state保存并调用的好处在于:CalibrationKit也是有使用寿命的,多次的校准,会是的校准件多次和校准电缆接触,可能污染校准件,使得校准件特性发生改变,影响下一次校准。 尽量养成如下习惯:将网络分析仪的port不用的时候加上防尘套;对测试电缆进行标号,使得VNA每个port尽可能固定连接某个电缆;对测试电缆不用时,也需要加上防尘套;尽量不用很脏的测试电缆等。 VNA的校准是j1ng确测量前必要的准备 以单端口DUT测量为例,测试模型参考oneporterrormodel。 由于VNA的输出和DUT的待测输入一般都存在中间过渡件/连接件,使得理想网络分析仪的测试平面和DUT的待测平面间出现了一个误差网络。对于单端口误差模型,有三个误差项。为了求解三个误差项,由线性矩阵理论,需要建立三个不相关的方程来求解。校准的原理就是建立这三个方程。 通过在测试面加入三个已知特性的校准件,例如开路件,反射系数理论上为1,短路件,反射系数理论上为-1,负载件反射系数理论上为0。通过VNA测量这三个校准件,得到实际测量结果。也就得到包含三个误差模型的线性方程,通过求解就能得到三个误差项。在后续的测量中,在直接获得的测试结果中,先通过数学运算,消除三个误差项带来的影响,显示给用户的就是校准后DUT的特性。 当然两端口误差模型更加复杂,分为正向和反向,正向具有6个误差项,反向也有6个误差项,总共有12个误差项需要求解,求解方法可用参考"RFMeasurementofDieandPackages" 当然一般网络分析仪提供的二端口矢量校准方法为SOLT,通过单端口的分析,其实校准件的本质是建立误差模型方程,选择不同已知反射系数的校准件,就得到了很多不同的校准方法,例如LRM,LRRM,TRL等等。 当然校准的本质也是去嵌入(De-embedding)的过程,去嵌入的本质得到误差网络的S参数,通过转换到T参数,运用级联运算进行消除。去嵌入还能够消除非传输线网络的S参数,应用也比校准guang泛。 实际校准的方法: 尽管一般VNA的UserGuider上都有仪器校准的方法,但是还有很多细节需要注意的: 1、设定测试参数 选择测试频率范围:一般的频率范围要稍微大于测试指标规定的范围,选择VNA Port激励功率,对于无源器件,可以选择稍微大的激励功率,例如0dBm,但是对于测试Amplifier等小信号器件,一般激励信号要小于器件的1dB压缩点,对于PowerAmplifier等大功率器件,需要减小VNA的输入信号功率,同时要在PA的输出和VNA的输入间加入衰减器。 但是过分减小VNA的输入信号功率,可能会使得S11和S22测量误差增大。如果对于多端口VNA,还需要选择测试port。 2、选择校准件,选择校准方法,通过仪器校准的Guide完成校准 每个公司都有不同的规格的校准件,例如N型的,SMA型的,这个在校准之前一定要选择好,这个是因为厂家提供的校准件,开路短路负载等也不是理想的反射系数分别为1,-1和0。同公司的VNA中会定义校准件,将校准件的特性预先存入VNA,以便校准时求解误差方程。因此,如果校准件选择不当,校准的意义也就没有了。 在校准过程中,显示format对于校准是没有影响的,可用选择显示S11或者S21,显示可用为VSWR或者SmithChart,这个不影响校准。已SOLT为例,首先进行单端口校准,分别将开路短路负载加至VNA的port1和port2,按照仪器指示进行完成校准,再连接Thru件,完成直通校准。 3、校准结果检查 这一步不是必须的,但个人觉得作为一个you秀的射频工程师,这一步是至关重要的。 开路校准特性的检查:校准完成后,将开路件取下,显示S11和S22的SmithChart,良好的校准使得测试显示曲线在整个测量频率范围内都在SmithChart的开路点。负载校准特性的检查:校准完成后,将测试端口连接负载件,测试S11和S22的SmithChart,良好的校准使得测试曲线在整个测量频率范围内都在SmithChart的中心点。 直通检查:校准完成后,将两端口连接Thru件,测试S12或者S21的dB曲线,良好的校准使得测试曲线在整个频率范围内平坦,且都在0dB。 用于3G网络分析仪85036A校准器 75欧姆85036B 安捷伦85036E深圳10套 |
相关推荐 |
BP86211D 12V/0.5A家用电器方案DEMO资料分析(电路原理图及BOM)
1500 浏览 0 评论
PD诱骗取电芯片_PD_Sink端芯片之XSP05实战应用电路
2514 浏览 1 评论
BLDC、PMSM电机智能栅极驱动芯片之TMC6140知识分享
1258 浏览 0 评论
国产电源芯片DP4054 软硬件兼容TP4054 规格书资料
1720 浏览 0 评论
3532 浏览 3 评论
/9
GMT+8, 2025-12-12 04:51 , Processed in 1.095706 second(s), Total 60, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
469
