CS5212资料
1》 Introduction The CS5212 DisplayPort to VGA converter combines a DisplayPort input interface and an analog RGB DAC output. The embedded MCU is based on an industrial standard 8051 core. The CS5212 is suitable for multiple market segments and display applications, such as laptop, motherboard, desktop, dongle, and docking system. 2》Features General 2-lane VESA DisplayPort v1.1 compliant receiver VGA output interface, DAC speed up to 210-MHz, 8-bit Max. resolution up to 1920x1200x60 (RB, reduced blanking) with 24-bit color depth, 1920x1440x60 (RB, reduced blanking) with 18-bit color depth, or 2048x1152x60 (RB, reduced blanking) with 24-bit color depth, or 2048x1536x60 (RB, reduced blanking) with 18-bit color depth. Embedded oscillator and there’s no need for the external crystal Embedded linear dropout regulator (LDO) Embedded MCU Embedded EDID (CS5212 will response EDID if terminal device doesn’t have it) Embedded V-sync/H-sync 5V buffer Support EEPROM Free mode by using the internal pre-blew ROM Internal power-on-reset (POR) QFN32 4x4 package DisplayPort Digital Input Support 2-lane digital input, speed up to RBR(1.62-Gbps) / HBR (2.7-Gbps) VESA DisplayPort v1.1 compliant Built-in high-performance adaptive equalizer Support 1-MHz AUX channel Support HPD VGA Output Interface Triple 8-bit DAC (Digital-to-Analog Converter) with clock up to 210-MHz Support up to 1920x1200x60, 1920x1440x60 (reduced blanking), 2048x1152x60 (reduced blanking), and 2048x1536x60 (reduced blanking) Embedded V-sync/ H-sync 5V buffer HBM 4-KV for VGA connector pins VESA VSIS v1r2 compliant Embedded MCU Industrial standard 8051 core Support I2C Master and Slave up to 400-KHz. Power & Technology Single 3.3V power supply 5V Option for V-sync/ H-sync 5V buffer Ultralow standby power < 100uW HBM 8-KV for all pins |
说得好,说得好,说得好,说得好,说得好说得好,说得好,说得好说得好。
BP86211D 12V/0.5A家用电器方案DEMO资料分析(电路原理图及BOM)
1475 浏览 0 评论
PD诱骗取电芯片_PD_Sink端芯片之XSP05实战应用电路
2496 浏览 1 评论
BLDC、PMSM电机智能栅极驱动芯片之TMC6140知识分享
1251 浏览 0 评论
国产电源芯片DP4054 软硬件兼容TP4054 规格书资料
1708 浏览 0 评论
3513 浏览 3 评论
/9
GMT+8, 2025-12-3 20:03 , Processed in 0.474456 second(s), Total 44, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
