电子发烧友论坛|
ARM主要是做控制的,但我一直没找到合适的集成EMAC+PHY,ADC,USB外设的DSP,OMAP单价太高,不太适合成本敏感型,或者能帮推荐吗?
6 个讨论
要做什么样的算法?
Stellaris系列MCU可以使用TI的IQmath库,对于乘除运算,三角运算等能大幅度提升运算速度。 bbs.eeworld.com.cn/thread-307058-1-1.html 另外你也可以考虑TI的集成了Cortex M3和C2000的双核MCU——Concerto系列 http://focus.ti.com.cn/cn/mcu/docs/mcuproductcontentnp.tsp?sectionId=95&familyId=2049&tabId=2743 enjoy! Young Hu C2000 FAE |
你可以考虑使用Cortex-M4系列的MCU,它内部集成了FPU,框图如下:
看TI对其M4的描述: The new Cortex-M4 expands the instruction offering of the Cortex-M3 by adding digital signal processing (DSP) extensions and single instruction, multiple data (SIMD) instructions. The Stellaris LM4F series also includes the floating point option (the “F” in the Cortex-M4F) across the entire offering of LM4F products. The DSP operations of the Stellaris LM4F series include single-cycle 32-bit or dual 16-bit multiply-accumulate (MAC) instructions and saturating arithmetic instructions. Optimized SIMD instructions can perform four 8-bit or two 16-bit arithmetic operations in a single cycle and are therefore very effective at performing arithmetic operations on large arrays of data. The hardware divide logic produces a result in between 2 and 12 clock cycles. Together, these instructions add DSP-like capability to a responsive controller core. The single precision floating-point instructions are compliant with the IEEE 754 standard and include functions such as square root and a fused MAC that enable higher precision. Numerous data type conversions are available, speeding transitions between domains. Besides providing a significant performance increase for math-intensive operations, floating-point support greatly simplifies the implementation and programming of floating-point routines. It is not uncommon for a customer to spend one week developing a digital filter then spend another month converting the filter to a fixed-point implementation to ensure it is both precise and stable. This development time is not required when programmers can program their filters in the native floating-point format. 可以看到它在DSP方面还是有很大优势的。功能更强劲,功耗更低,看起来很诱人。可以参考 http://focus.ti.com/lit/wp/spmy007/spmy007.pdf |
只有小组成员才能发言,加入小组>>
550 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1514 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1338 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2783浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 17:01 , Processed in 0.614058 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1129
