以下是关于labview 和Stellaris配合的相关内容请参考。
1> 目前labview支持的Stellaris只有LM3S8962 2> 要使EK-LM3S8962在labview下工作,要满足一下条件 2.1> A LabView for ARM license 2.2> Keil license 2.3> uLink2 3> 若要labview支持LM3S9B96,请参考以下NI给的移植说明 To port LabVIEW Embedded Module for ARM Microcontrollers to a Texas Instruments Stellaris Microcontroller use the following instructions first to create your port: 3.1> Create a new ARM Project in LabVIEW. 3.2>When asked to select a target type choose Other. 3.3> Select Luminary Micro LM3S8962 Stellaris for the processor. This will load a generic template. 3.4> In the project right-click on the LM3Sxxxx target and select the target processor to be Luminary Micro LM3S8962 Stellaris. Now you have a generic target for Luminary Micro parts. 3.5> If you are using Elemental I/O right-click on the LM3Sxxxx target and choose select elemental I/O... Select the LM3S8962 device. 3.6> Create an application build specification if there is not one already. 3.7> Right-click on the Application under Build Specifications and select Properties. 3.8> Go to the Advanced Compiler section. 3.9> Add a Preprocesser symbol of: LM3S_PART_DEFINED PART_LM3Sxxxx Where xxxx is the model number that you want to use. Note: The uVision project created for this target will assume a flash memory size of 256K and 64K of RAM (as configured for the LM3S8962 target). If the memory configuration for your microcontroller is different, edit your uVision project. If the Texas Instruments Stellaris Microcontroller that you are using is newer than the LM3S8962, you might need to upddate software support installed with LabVIEW. To update the software follow the instructions in KnowledgeBase 4YBA2IBN: Error: #20: Identifier is Undefined when Compiling for Texas Instruments (Formerly Luminary Micro) Stellaris TI StellarisWare 软件 |
只有小组成员才能发言,加入小组>>
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
666 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
597 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1047 浏览 1 评论
730 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
519 浏览 1 评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
157浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
119浏览 14评论
在使用3254进行录音的时候出现一个奇怪的现象,右声道有吱吱声,请教一下,是否是什么寄存器设置存在问题?
123浏览 13评论
TLV320芯片内部自带数字滤波功能,请问linein进来的模拟信号是否是先经过ADC的超采样?
121浏览 12评论
TPA6304-Q1: TPA6304 两片公用一组I2C的话,其中一片配置不成功怎么办
163浏览 10评论
GMT+8, 2024-11-22 01:52 , Processed in 0.949536 second(s), Total 59, Slave 48 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
