电子发烧友论坛|
[C] 纯文本查看 复制代码
#include "sys.h"#include "delay.h"#include "usart.h"#include "led.h"#include "FreeRTOS.h"#include "task.h"#include "queue.h"#include "malloc.h"#include "string.h"#include "adc.h"/************************************************************************************************///任务优先级#define START_TASK_PRIO1//任务堆栈大小#define START_STK_SIZE 256 //任务句柄TaskHandle_t StartTask_Handler;//任务函数void start_task(void *pvParameters);//任务优先级#define LED0_TASK_PRIO2//任务堆栈大小#define LED0_STK_SIZE 256 //任务句柄TaskHandle_t LED0Task_Handler;//任务函数void led0_task(void *pvParameters);//任务优先级#define LED1_TASK_PRIO3//任务堆栈大小#define LED1_STK_SIZE 256 //任务句柄TaskHandle_t LED1Task_Handler;//任务函数void led1_task(void *pvParameters);#define MESSAGE_Q_NUM 1 //发送数据的消息队列的数量 QueueHandle_t Message_Queue;//信息队列句柄int main(void){NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);//设置系统中断优先级分组4 delay_init(); //延时函数初始化 uart_init(115200);//初始化串口uart_init_2(9600);LED_Init(); //初始化LED// P_IN1=0; //控制电机转动//P_IN2=1;//P_IN3=0;//P_IN4=1; RUN=1;STOP=1;//创建开始任务 xTaskCreate((TaskFunction_t )start_task, //任务函数 (const char* )"start_task", //任务名称 (uint16_t )START_STK_SIZE, //任务堆栈大小 (void* )NULL, //传递给任务函数的参数 (UBaseType_t )START_TASK_PRIO, //任务优先级 (TaskHandle_t* )&StartTask_Handler); //任务句柄 vTaskStartScheduler(); //开启任务调度}//开始任务任务函数void start_task(void *pvParameters){ taskENTER_CRITICAL(); //进入临界区 critical 临界的 //创建LED0任务Message_Queue=xQueueCreate(MESSAGE_Q_NUM,USART_REC_LEN); //创建消息Message_Queue,队列项长度是串口接收缓冲区长度 xTaskCreate((TaskFunction_t )led0_task, (const char* )"led0_task", (uint16_t )LED0_STK_SIZE, (void* )NULL, (UBaseType_t )LED0_TASK_PRIO, (TaskHandle_t* )&LED0Task_Handler); //创建LED1任务 xTaskCreate((TaskFunction_t )led1_task, (const char* )"led1_task", (uint16_t )LED1_STK_SIZE, (void* )NULL, (UBaseType_t )LED1_TASK_PRIO, (TaskHandle_t* )&LED1Task_Handler); vTaskDelete(StartTask_Handler); //删除开始任务 taskEXIT_CRITICAL(); //退出临界区}//LED0任务函数 void led0_task(void *pvParameters){ while(1) { LED0=~LED0; //PC12 RUNLED1=~LED1; vTaskDelay(500);//USART_SendData(USART2, 2); }} //LED1任务函数void led1_task(void *pvParameters){u8 *buffer;//BaseType_t xTaskWokenByReceive=pdFALSE;u8 i; while(1) {if(Message_Queue!=NULL){buffer=mymalloc(SRAMIN,USART_REC_LEN);memset(buffer,0,USART_REC_LEN);//清除缓冲区 把buffer的前 USART_REC_LEN 个字节设置为 0 }i=xQueueReceive(Message_Queue,buffer,10);//if(xQueueReceiveFromISR(Message_Queue,buffer,&xTaskWokenByReceive))if(xQueueReceive(Message_Queue,buffer,portMAX_DELAY)){i=buffer[2];switch(i){case 0X31:P_IN1=0; //前进P_IN2=1;P_IN3=0;P_IN4=1; RUN=0;STOP=1;break ;case 0X32:P_IN1=1; //后退P_IN2=0;P_IN3=1;P_IN4=0;RUN=0;STOP=1;break ;case 0X33 :P_IN1=0; //左P_IN2=1;P_IN3=0;P_IN4=0; RUN=0; STOP=1;break ;case 0X34 :P_IN1=0; //右P_IN2=0;P_IN3=0;P_IN4=1; RUN=0;STOP=1;break ;case 0X53 :P_IN1=0; //停止P_IN2=0;P_IN3=0;P_IN4=0; RUN=1;STOP=0;break ;}myfree(SRAMIN,buffer);//释放内存} vTaskDelay(10); }}[C] 纯文本查看 复制代码 void USART1_IRQHandler(void) //串口1中断服务程序{u8 a;BaseType_t xHigherPriorityTaskWoken;if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET) //接收中断(接收到的数据必须是0x0d 0x0a结尾){a=USART_ReceiveData(USART1);//读取接收到的数据USART_RX_BUF[Res++]=a;if(Res>=3){Res=0;Flag_message=1;}}if(Message_Queue!=NULL&&Flag_message==1){Flag_message=0;Res=0;xQueueSendFromISR(Message_Queue,USART_RX_BUF,&xHigherPriorityTaskWoken);//向队列中发送数据memset(USART_RX_BUF,0,USART_REC_LEN);//清除数据接收缓冲区USART_RX_BUF,用于下一次数据接收portYIELD_FROM_ISR(xHigherPriorityTaskWoken);//如果需要的话进行一次任务切换}} 这个是修改了原子的队列历程,然后串口接收后,通过队列发送到主函数,来判断后执行一些动作,现在程序是个小车测试用的。现在遇到的问题是,我在进行AD采集,那采集的值该怎么传倒一个任务中呢,裸机是通过全局数组,现在有了RTOS,得通过这些消息队列,信号之类的传送吗?还是说,直接全局数组也是可以的,但看原子的教程说,用全局变量会影响一些东西,那这样的话,上了系统后,编程不是变的很麻烦吗?每次要定义队列,传的时候还要申请内存之类的各种操作。。。。 |
5个回答
1、采集到AD值,然后通过队列发送出去。2、即使用了系统,你依旧也可以用全局数组,但是对系统不好,使用队列的话系统会统一进行资源管理。
3、所谓的麻烦是为了系统的性能。 |
我决定用队列吧。
刚刚看到 ,任务led1_tast,里面 i=xQueueReceive(Message_Queue,buffer,10); 这句应该注释掉的
不建议使用全局数组,如果实在要使用,在使用时也最好加临界区保护
那传递AD采集的值,一般是用队列了吧,我的理解是,信号量类似裸机的标志位,传递几个数据的话就用队列?
只有小组成员才能发言,加入小组>>
1022 浏览 1 评论
1852 浏览 0 评论
1833 浏览 1 评论
3258 浏览 5 评论
3585 浏览 9 评论
1022浏览 1评论
1850浏览 1评论
如何知道嵌入式电子控制单元 (ECU) 中的RAM使用情况?
1360浏览 1评论
1852浏览 0评论
1178浏览 0评论
/9
GMT+8, 2025-12-2 06:56 , Processed in 0.618849 second(s), Total 82, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2349
