error #10234-D: unresolved symbols remain
error #10010: errors encountered during linking; "F2812_ADC_2.out" not built 请问一下这种问题一般是什么原因引起的 为什么编译器分析不出来。还有就为什么把h文件放在workspace里面不行编译还是出现这个问题 Thank you! 引起的 |
6 个讨论
你好,我的也是这个问题。 **** Build of configuration Debug for project sensor-close **** "E:\software\ccs6\ccsv6\utils\bin\gmake" -k all 'Building target: sensor-close.out' 'Invoking: C2000 Linker' "E:/software/ccs6/ccsv6/tools/compiler/ti-cgt-c2000_6.4.2/bin/cl2000" -v28 -ml --float_support=fpu32 -g --define="_DEBUG" --define="LARGE_MODEL" --diag_warning=225 --display_error_number --diag_wrap=off -z -m"sensor-close.map" --heap_size=1000 --stack_size=1000 --warn_sections -i"E:/software/ccs6/ccsv6/tools/compiler/ti-cgt-c2000_6.4.2/lib" -i"E:/software/ccs6/ccsv6/tools/compiler/ti-cgt-c2000_6.4.2/include" -i"E:/software/ccs6/workspace/sensor-close" -i"D:/楂樺嘲璁″垝/BLDC瀹為獙绠辫祫鏂?BLDC璇曢獙绠变緥绋?sensor-closeloop" --reread_libs --display_error_number --diag_wrap=off --xml_link_info="sensor-close_linkInfo.xml" --entry_point=code_strat --rom_model -o "sensor-close.out" "../CMD/DSP2833x_Headers_nonBIOS.cmd" "./Cap_Init.obj" "./DSP2833x_ADC_cal.obj" "./DSP2833x_Adc.obj" "./DSP2833x_CodeStartBranch.obj" "./DSP2833x_CpuTimers.obj" "./DSP2833x_DefaultIsr.obj" "./DSP2833x_EPwm.obj" "./DSP2833x_GlobalVariableDefs.obj" "./DSP2833x_PieCtrl.obj" "./DSP2833x_PieVect.obj" "./DSP2833x_Sci.obj" "./DSP2833x_SysCtrl.obj" "./DSP2833x_Xintf.obj" "./DSP2833x_usDelay.obj" "./Example_EPwmSetup.obj" "./weizhi.obj" "../CMD/28335_RAM_lnk.cmd" -l"rts2800_fpu32.lib" warning #16002-D: build attribute vendor section TI missing in "./Cap_Init.obj": compatibility cannot be determined warning #16002-D: build attribute vendor section TI missing in "./DSP2833x_ADC_cal.obj": compatibility cannot be determined warning #16002-D: build attribute vendor section TI missing in "./DSP2833x_Adc.obj": compatibility cannot be determined warning #16002-D: build attribute vendor section TI missing in "./DSP2833x_CodeStartBranch.obj": compatibility cannot be determined >> Compilation failure warning #16002-D: build attribute vendor section TI missing in "./DSP2833x_CpuTimers.obj": compatibility cannot be determined warning #16002-D: build attribute vendor section TI missing in "./DSP2833x_DefaultIsr.obj": compatibility cannot be determined warning #16002-D: build attribute vendor section TI missing in "./DSP2833x_EPwm.obj": compatibility cannot be determined warning #16002-D: build attribute vendor section TI missing in "./DSP2833x_GlobalVariableDefs.obj": compatibility cannot be determined warning #16002-D: build attribute vendor section TI missing in "./DSP2833x_PieCtrl.obj": compatibility cannot be determined warning #16002-D: build attribute vendor section TI missing in "./DSP2833x_PieVect.obj": compatibility cannot be determined warning #16002-D: build attribute vendor section TI missing in "./DSP2833x_SysCtrl.obj": compatibility cannot be determined warning #16002-D: build attribute vendor section TI missing in "./DSP2833x_Xintf.obj": compatibility cannot be determined warning #16002-D: build attribute vendor section TI missing in "./DSP2833x_usDelay.obj": compatibility cannot be determined warning #16002-D: build attribute vendor section TI missing in "./Example_EPwmSetup.obj": compatibility cannot be determined warning #16002-D: build attribute vendor section TI missing in "./weizhi.obj": compatibility cannot be determined undefined first referenced symbol in file --------- ---------------- code_strat error #10234-D: unresolved symbols remain warning #10062-D: entry-point symbol "code_strat" undefined error #10010: errors encountered during linking; "sensor-close.out" not built gmake: *** [sensor-close.out] Error 1 gmake: Target `all' not remade because of errors. **** Build Finished **** 请问是什么原因啊,楼主说的那个delay函数我这里是有的啊 |
只有小组成员才能发言,加入小组>>
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
538 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
987 浏览 1 评论
584 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
461 浏览 1 评论
996 浏览 0 评论
GMT+8, 2024-10-20 22:14 , Processed in 1.014324 second(s), Total 68, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
