前辈好,我在做一个异步电机vvvf程序,设定pwm周期为10K,现在想将pwm周期改变成5k,做了如下更改(设定TBCLK=30MHz,updown计数方式)
EPwm1Regs.TBPRD = 3000; // Period = 2*PeriodMax*TBCLKs开关周期设置 10K频率对应TBPRD=1500,改为5K时,将此对应改为3000 EPwm1Regs.CMPA.half.CMPA = 3000/2; // 50% duty cycle first 占空比设置 EPwm1Regs.TBPHS.half.TBPHS = 0x0000; // Set phase register to zero移相设置 EPwm1Regs.TBCTR = 0x0000; // Clear counter PWM计数器清零 EPwm1Regs.TBCTL.all = 0; EPwm1Regs.TBCTL.bit.PHSDIR = TB_UP; // Count up after the synchronization event //同步信号到来计数器装载相位寄存器的值后递增计数 EPwm1Regs.TBCTL.bit.FREE_SOFT = 0; // Free run EPwm1Regs.TBCTL.bit.CTRMODE = TB_COUNT_UPDOWN; // Symmetrical mode计数模式 EPwm1Regs.TBCTL.bit.PHSEN = TB_ENABLE; // Enable phase loading EPwm1Regs.TBCTL.bit.PRDLD = TB_SHADOW; // Shadow period register EPwm1Regs.TBCTL.bit.SYNCOSEL = TB_SYNC_IN; // Sync flow-though EPwm1Regs.TBCTL.bit.HSPCLKDIV = TB_DIV2; // TBCLK = SYSCLKOUT/2/1(30M Hz) EPwm1Regs.TBCTL.bit.CLKDIV = TB_DIV1; // //TBCLK = SYSCLKOUT/(HSPCLKDIV*CLKDIV) EPwm1Regs.CMPCTL.bit.SHDWAMODE = CC_SHADOW; // Shadow counter-compare A register EPwm1Regs.CMPCTL.bit.SHDWBMODE = CC_SHADOW; // Shadow counter-compare B register EPwm1Regs.CMPCTL.bit.LOADAMODE = CC_CTR_ZERO; // Load on CTR=Zero EPwm1Regs.CMPCTL.bit.LOADBMODE = CC_CTR_ZERO; // Load on CTR=Zero EPwm1Regs.AQCTLA.all = 0; EPwm1Regs.AQCTLA.bit.CBU = AQ_NO_ACTION; // Do nothing (action disabled) EPwm1Regs.AQCTLA.bit.CBD = AQ_NO_ACTION; // Do nothing (action disabled) EPwm1Regs.AQCTLA.bit.PRD = AQ_NO_ACTION; // Do nothing (action disabled) EPwm1Regs.AQCTLA.bit.ZRO = AQ_NO_ACTION; // Do nothing (action disabled) //EPwm1Regs.AQCTLA.bit.CAU = AQ_CLEAR; // Force EPWM1A low (CTR = CMPA on up-count)上升计数触发时输出低 //EPwm1Regs.AQCTLA.bit.CAD = AQ_SET; // Force EPWM1A high (CTR = CMPA on down-count)下降计数触发时输出高 EPwm1Regs.AQCTLA.bit.CAU = AQ_SET; // Force EPWM1A high (CTR = CMPA on up-count) EPwm1Regs.AQCTLA.bit.CAD =AQ_CLEAR ; // Force EPWM1A low (CTR = CMPA on down-count) EPwm1Regs.DBCTL.all = 0; EPwm1Regs.DBCTL.bit.OUT_MODE = DB_FULL_ENABLE; // Enable dead-band module EPwm1Regs.DBCTL.bit.POLSEL = DB_ACTV_HIC; // Active high complementary EPwm1Regs.DBCTL.bit.IN_MODE = DBA_ALL; // EpwmxA in is source for all EPwm1Regs.DBRED = 50; // RED = Deadband*TBCLKs(30 correspond to 1uS)死区时间设置 EPwm1Regs.DBFED = 50; // FED = Deadband*TBCLKs(30 correspond to 1uS) EPwm1Regs.PCCTL.all = 0; // Disable PWM chopper control //禁止错误联防功能 EALLOW; EPwm1Regs.TZSEL.all = 0; // Disable TZ1-TZ6 as OSHT and CBC trip source EPwm1Regs.TZCTL.all = 0; // High impedance on EPWMxA and EPWMxB EDIS; //事件触发模块寄存器初始化 EPwm1Regs.ETSEL.all = 0; EPwm1Regs.ETSEL.bit.INTEN = 1; // Enable INT EPwm1Regs.ETSEL.bit.INTSEL = ET_CTR_PRD; // Select INT on PRD event // EPwm1Regs.ETSEL.bit.SOCAEN = 1; // 使能AD开始转换EPWMxSOCA脉冲 EPwm1Regs.ETPS.all = 0; EPwm1Regs.ETPS.bit.INTPRD = ET_1ST; // 在第一个事件时产生中断 PWM2.PWM3类似设置,主程序中SVPWM的每个开关周期矢量变化角度和开关管动作时间均依照频率的改变做了调整。如下 DELTA_PHASE = (float)(f_real*4096/10000) EPwm1Regs.CMPA.half.CMPA = (Uint16)(Pwm1*PWM_CLK*1500*2); //式子中,PWM_CLK=10e3,即10K Hz;1500为10K时的TBPRD, 改成5K时,对应PWM_CLK=5e3,TBPRD对应改成3000) EPwm2Regs.CMPA.half.CMPA = (Uint16)(Pwm2*PWM_CLK*1500*2); EPwm3Regs.CMPA.half.CMPA = (Uint16)(Pwm3*PWM_CLK*1500*2); 改动如上所述,但是改动后,无法得到正常的PWM输出,可以正常采样,但是中断函数中,采样后面部分无法执行。请教以下问题出在那里? |
1 个讨论
只有小组成员才能发言,加入小组>>
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
684 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
600 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1055 浏览 1 评论
741 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
525 浏览 1 评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
164浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
128浏览 14评论
在使用3254进行录音的时候出现一个奇怪的现象,右声道有吱吱声,请教一下,是否是什么寄存器设置存在问题?
127浏览 13评论
TLV320芯片内部自带数字滤波功能,请问linein进来的模拟信号是否是先经过ADC的超采样?
123浏览 12评论
GD32F303RCT6配置PA4 ADC引脚,将PA2代替key功能,PA2连接时无法实现预期功能,为什么?
43浏览 10评论
GMT+8, 2024-11-25 16:39 , Processed in 0.805842 second(s), Total 45, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
