请问EQEP 的索引(index)事件与锁存(strobe)事件到底什么意思是,功能如何理解;还有位置计数器(QPOSCNT)如何工作计数的,谢谢
1 个讨论
· eQEPI: Index or Zero Marker
The eQEP encoder uses an index signal to assign an absolute start position from which position information is incrementally encoded using quadrature pulses. This pin is connected to the index output of the eQEP encoder to optionally reset the position counter for each revolution. This signal can be used to initialize or latch the position counter on the occurrence of a desired event on the index pin. · QEPS: Strobe Input This general-purpose strobe signal can initialize or latch the position counter on the occurrence of a desired event on the strobe pin. This signal is typically connected to a sensor or limit switch to notify that the motor has reached a defined position. QPOSCNT只要当A或者B出现电平变化都会累加,累加方向与转动方向一致 |
只有小组成员才能发言,加入小组>>
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
919 浏览 1 评论
531 浏览 0 评论
普中科技F28335开发板每次上电复位后数码管都会显示,如何熄灭它?
408 浏览 1 评论
962 浏览 0 评论
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
2125 浏览 0 评论
55浏览 3评论
CC3100BOOST使用CC3200lunchXL进行烧录
909浏览 2评论
151浏览 2评论
192浏览 2评论
170浏览 2评论
GMT+8, 2024-9-27 10:34 , Processed in 0.899045 second(s), Total 62, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
