3 个讨论
//Set the peripheral muxing for the specified pin. The appropriate
//parameters can be found in the GPIO Muxed Pins table(4.4) in the datasheet. //Use the GPIO index row (0 to 15) to select a muxing option for the GPIO. void GPIO_SetupPinMux(Uint16 pin, Uint16 cpu, Uint16 peripheral) //Setup up the GPIO input/output options for the specified pin. //The flags are a 16-bit mask produced by ORing together options. //For input pins, the valid flags are: //GPIO_PULLUP Enable pull-up //GPIO_INVERT Enable input polarity inversion //GPIO_SYNC Synchronize the input latch to PLLSYSCLK (default -- you don't need to specify this) //GPIO_QUAL3 Use 3-sample qualification //GPIO_QUAL6 Use 6-sample qualification //GPIO_ASYNC Do not use synchronization or qualification //(Note: only one of SYNC, QUAL3, QUAL6, or ASYNC is allowed) // //For output pins, the valid flags are: //GPIO_OPENDRAIN Output in open drain mode //GPIO_PULLUP If open drain enabled, also enable the pull-up //and the input qualification flags (SYNC/QUAL3/QUAL6/SYNC) listed above. // //With no flags, the default input state is synchronous with no //pull-up or polarity inversion. The default output state is //the standard digital output. void GPIO_SetupPinOptions(Uint16 pin, Uint16 output, Uint16 flags) |
009712 发表于 2020-7-16 06:27 其实我就是这些注释话没看懂,后面两个参数我懂,就是第一个参数是怎么对应到GPIO上的? |
只有小组成员才能发言,加入小组>>
326 浏览 1 评论
524 浏览 2 评论
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
768 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
647 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1122 浏览 1 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
33浏览 29评论
66浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
242浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
193浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
52浏览 13评论
GMT+8, 2024-12-21 00:48 , Processed in 0.927850 second(s), Total 51, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
