下面这段代码来自TMDSHVMTRPFCKIT的HVACI_Sensored。每次看到这段代码我就略过,突然想问一下,这段代码是干嘛用的啊?
我看到C1控制了控制卡上面3个LED的状态,我猜测这段代码实现了一个类似操作系统的功能,对不对?这段代码还涉及到串口通讯,是不是电机控制的上位机(GUI)对应的DSP程序也在这里面? void A0(void) [ // loop rate synchronizer for A-tasks if(Cputimer0Regs.TCR.bit.TIF == 1) [ CpuTimer0Regs.TCR.bit.TIF = 1; // clear flag //----------------------------------------------------------- (*A_Task_Ptr)(); // jump to an A Task (A1,A2,A3,...) //----------------------------------------------------------- VTimer0[0]++; // virtual timer 0, instance 0 (spare) SerialCommsTimer++; ] Alpha_State_Ptr = &B0; // Comment out to allow only A tasks ] void B0(void) [ // loop rate synchronizer for B-tasks if(CpuTimer1Regs.TCR.bit.TIF == 1) [ CpuTimer1Regs.TCR.bit.TIF = 1; // clear flag //----------------------------------------------------------- (*B_Task_Ptr)(); // jump to a B Task (B1,B2,B3,...) //----------------------------------------------------------- VTimer1[0]++; // virtual timer 1, instance 0 (spare) ] Alpha_State_Ptr = &C0; // Allow C state tasks ] void C0(void) [ // loop rate synchronizer for C-tasks if(CpuTimer2Regs.TCR.bit.TIF == 1) [ CpuTimer2Regs.TCR.bit.TIF = 1; // clear flag //----------------------------------------------------------- (*C_Task_Ptr)(); // jump to a C Task (C1,C2,C3,...) //----------------------------------------------------------- VTimer2[0]++; //virtual timer 2, instance 0 (spare) ] Alpha_State_Ptr = &A0; // Back to State A0 ] //================================================================================= // A - TASKS (executed in every 1 msec) //================================================================================= //-------------------------------------------------------- void A1(void) // SPARE (not used) //-------------------------------------------------------- [ //------------------- //the next time CpuTimer0 'counter' reaches Period value go to A2 A_Task_Ptr = &A2; //------------------- ] …… //----------------------------------------- void C3(void) // SPARE //----------------------------------------- [ //----------------- //the next time CpuTimer2 'counter' reaches Period value go to C1 C_Task_Ptr = &C1; //----------------- ] |
3 个讨论
只有小组成员才能发言,加入小组>>
228 浏览 0 评论
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1916 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3671 浏览 4 评论
5042 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1742 浏览 1 评论
CC3100BOOST使用CC3200lunchXL进行烧录
694浏览 2评论
742浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
714浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1212浏览 1评论
1798浏览 1评论
GMT+8, 2024-5-16 07:20 , Processed in 0.742005 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
