扫一扫,分享给好友
1、可设置4位密码
2、用户可自行设定和修改密码 3、若密码错误,报警5S,连续错3次,报警1分钟 4、锁由继电器模拟 #include unsigned char ps[]={1,2,3,4,5}; //设定密码 unsigned char code dispbit[]={0xfe,0xfd,0xfb,0xf7, 0xef,0xdf,0xbf,0x7f}; unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f,0x66, 0x6d,0x7d,0x07,0x7f,0x6f, //数字0~9 0x77,0x7c,0x39,0x5e,0x79,0x71, //字母A~F 0x00,0x40,0x73,0xff}; //字符 -P8. unsigned char dispbuf[8]={18,16,16,16,16,16,16,16}; unsigned char dispcount; //显示计数 unsigned char flashcount; //闪烁计数 unsigned char temp; //临时变量 unsigned char key; //按键 unsigned char keycount; //按键计数 unsigned char pslen=5; //密码长度 unsigned char getps[6]; //得到的密码 bit keyoverflag; //密码输入超位 bit errorflag; //错误标志位 bit rightflag; // 正确标志位 unsigned int second3; unsigned int aa,bb; unsigned int cc; bit okflag; bit alarmflag; //报警标志 bit hibitflag; //高位 unsigned char oka,okb; void main(void) { unsigned char i,j; TMOD=0x01; TH0=(65536-500)/256; //TH0初始化 TL0=(65536-500)%256; //TL0初始化 TR0=1; ET0=1; EA=1; while(1) { P3=0xff; //P3赋值255 P3_4=0; temp=P3; temp=temp & 0x0f; if (temp!=0x0f) { for(i=10;i>0;i--) for(j=248;j>0;j--); temp=P3; temp=temp & 0x0f; if (temp!=0x0f) { temp=P3; temp=temp & 0x0f; switch(temp) { case 0x0e: key=7; break; case 0x0d: key=8; break; case 0x0b: key=9; break; case 0x07: key=10; break; } temp=P3; // P1_1=~P1_1; if((key>=0) && (key<10)) { if(keycount<6) { getps[keycount]=key; dispbuf[keycount+1]=19; //向后显示8. ? } keycount++; if(keycount==6) { keycount=6; } else if(keycount>6) { keycount=6; keyoverflag=1;//key overflow } } else if(key==12)//delete key { if(keycount>0) { keycount--; getps[keycount]=0; //最近1次输入的数值清0 dispbuf[keycount+1]=16; //? } else { keyoverflag=1; //未输入密码按功能键,报错 } } else if(key==15)//enter key { if(keycount!=pslen) //密码输入出错 { errorflag=1; rightflag=0; second3=0; // } else { for(i=0;i if(getps[i]!=ps[i]) { i=keycount; errorflag=1; rightflag=0; second3=0; goto a; } } errorflag=0; rightflag=1; a: i=keycount; } } temp=temp & 0x0f; while(temp!=0x0f) //判断按键是否弹回 { temp=P3; temp=temp & 0x0f; } keyoverflag=0; } } P3=0xff; P3_5=0; temp=P3; temp=temp & 0x0f; if (temp!=0x0f) { for(i=10;i>0;i--) for(j=248;j>0;j--); temp=P3; temp=temp & 0x0f; if (temp!=0x0f) { temp=P3; temp=temp & 0x0f; switch(temp) { case 0x0e: key=4; break; case 0x0d: key=5; break; case 0x0b: key=6; break; case 0x07: key=11; break; } temp=P3; // P1_1=~P1_1; if((key>=0) && (key<10)) { if(keycount<6) { getps[keycount]=key; dispbuf[keycount+1]=19; } keycount++; if(keycount==6) { keycount=6; } else if(keycount>6) { keycount=6; keyoverflag=1;//key overflow } } else if(key==12)//delete key { if(keycount>0) { keycount--; getps[keycount]=0; dispbuf[keycount+1]=16; } else { keyoverflag=1; } } else if(key==15)//enter key { if(keycount!=pslen) { errorflag=1; rightflag=0; second3=0; } else { for(i=0;i if(getps[i]!=ps[i]) { i=keycount; errorflag=1; rightflag=0; second3=0; goto a4; } } errorflag=0; rightflag=1; a4: i=keycount; } } temp=temp & 0x0f; while(temp!=0x0f) { temp=P3; temp=temp & 0x0f; } keyoverflag=0; } } P3=0xff; P3_6=0; temp=P3; temp=temp & 0x0f; if (temp!=0x0f) { for(i=10;i>0;i--) for(j=248;j>0;j--); temp=P3; temp=temp & 0x0f; if (temp!=0x0f) { temp=P3; temp=temp & 0x0f; switch(temp) { case 0x0e: key=1; break; case 0x0d: key=2; break; case 0x0b: key=3; break; case 0x07: key=12; break; } temp=P3; // P1_1=~P1_1; if((key>=0) && (key<10)) { if(keycount<6) { getps[keycount]=key; dispbuf[keycount+1]=19; } keycount++; if(keycount==6) { keycount=6; } else if(keycount>6) { keycount=6; keyoverflag=1;//key overflow } } else if(key==12)//delete key { if(keycount>0) { keycount--; getps[keycount]=0; dispbuf[keycount+1]=16; } else { keyoverflag=1; } } else if(key==15)//enter key { if(keycount!=pslen) { errorflag=1; rightflag=0; second3=0; } else { for(i=0;i if(getps[i]!=ps[i]) { i=keycount; errorflag=1; rightflag=0; second3=0; goto a3; } } errorflag=0; rightflag=1; a3: i=keycount; } } temp=temp & 0x0f; while(temp!=0x0f) { temp=P3; temp=temp & 0x0f; } keyoverflag=0; } } P3=0xff; P3_7=0; temp=P3; temp=temp & 0x0f; if (temp!=0x0f) { for(i=10;i>0;i--) for(j=248;j>0;j--); temp=P3; temp=temp & 0x0f; if (temp!=0x0f) { temp=P3; temp=temp & 0x0f; switch(temp) { case 0x0e: key=0; break; case 0x0d: key=13; break; case 0x0b: key=14; break; case 0x07: key=15; break; } temp=P3; // P1_1=~P1_1; if((key>=0) && (key<10)) { if(keycount<6) { getps[keycount]=key; dispbuf[keycount+1]=19; } keycount++; if(keycount==6) { keycount=6; } else if(keycount>6) { keycount=6; keyoverflag=1;//key overflow } } else if(key==12)//delete key { if(keycount>0) { keycount--; getps[keycount]=0; dispbuf[keycount+1]=16; } else { keyoverflag=1; } } else if(key==15)//enter key { if(keycount!=pslen) { errorflag=1; rightflag=0; second3=0; } else { for(i=0;i if(getps[i]!=ps[i]) { i=keycount; errorflag=1; rightflag=0; second3=0; goto a2; } } errorflag=0; rightflag=1; a2: i=keycount; } } temp=temp & 0x0f; while(temp!=0x0f) { temp=P3; temp=temp & 0x0f; } keyoverflag=0; } } } } void t0(void) interrupt 1 using 0 { TH0=(65536-500)/256; TL0=(65536-500)%256; flashcount++; if(flashcount==8) { flashcount=0; P0=dispcode[dispbuf[dispcount]]; P2=dispbit[dispcount]; dispcount++; if(dispcount==8) { dispcount=0; } } if((errorflag==1) && (rightflag==0)) { bb++; if(bb==800) { bb=0; alarmflag=~alarmflag; } if(alarmflag==1)//sound alarm signal { P1_7=~P1_7; } aa++; if(aa==800)//light alarm signal { aa=0; P1_0=~P1_0; } second3++; if(second3==6400) { second3=0; errorflag=0; rightflag=0; alarmflag=0; bb=0; aa=0; } } else if((errorflag==0) && (rightflag==1)) { P1_0=0; cc++; if(cc<1000) { okflag=1; } else if(cc<2000) { okflag=0; } else { errorflag=0; rightflag=0; P1_7=1; cc=0; oka=0; okb=0; okflag=0; P1_0=1; } if(okflag==1) { oka++; if(oka==2) { oka=0; P1_7=~P1_7; } } else { okb++; if(okb==3) { okb=0; P1_7=~P1_7; } } } if(keyoverflag==1) { P1_7=~P1_7; } } |
2个回答
怎么都没人回答啊~~~~~~
直接看不懂啊 怎么办
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-shell脚本编写之变量
447 浏览 0 评论
嵌入式学习-飞凌嵌入式ElfBoard ELF 1板卡-shell脚本编写之本地脚本的编写和执行
616 浏览 0 评论
【xG24 Matter开发套件试用体验】深入了解Silicon Labs xG24 Matter开发套件
749 浏览 0 评论
662 浏览 0 评论
688 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
10947 浏览 31 评论
GMT+8, 2024-9-1 20:26 , Processed in 0.554002 second(s), Total 75, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
