电子发烧友论坛扫一扫,分享给好友
联系人:黄鑫城 电话:*** 0755-82078692 QQ:759728988 mail:Nick@cyberwin.com.cn 我们有专业的工程师,提供全方位的技术支持和解决方案。 FT4232HL关键特性 --Single chip USB to quad serial ports with a variety of configurations. --Entire USB protocol handled on the chip. No USB specific firmware programming required. --USB 2.0 High Speed (480Mbits/Second) and Full Speed (12Mbits/Second) compatible. --Two Multi-Protocol Synchronous Serial Engine (MPSSE) on channel A and channel B, to simplify synchronous serial protocol (USB to JTAG, I2C, SPI or bit-bang) design. --Independent Baud rate generators. --RS232/RS422/RS485 UART Transfer Data Rate up to 12Mbaud. (RS232 Data Rate limited by external level shifter). --FTDI’s royalty-free Virtual Com Port (VCP) and Direct (D2XX) drivers eliminate the requirement for USB driver development in most cases. --Optional traffic TX/RX indicators can be added with LEDs and an external 74HC595 shift register. --Adjustable receive buffer timeout. --Support for USB suspend and resume conditions via PWREN#, SUSPEND# and RI# pins. --Highly integrated design includes +1.8V LDO regulator for VCORE, integrated POR function and on chip clock multiplier PLL (12MHz – 480MHz). --FTDI FT232B style, asynchronous serial UART interface option with full hardware handshaking and modem interface signals. --Fully assisted hardware or X-On / X-Off software handshaking. --UART Interface supports 7/8 bit data, 1/2 stop bits, and Odd/Even/Mark/Space/No Parity. --Auto-transmit enable control for RS485 serial applications using TXDEN pin. --Operational configuration mode and USB Description strings configurable in external EEPROM over the USB interface. --Low operating and USB suspend current. --Configurable I/O drive strength (4,8,12 or 16mA) and slew rate. --Supports bus powered, self powered and high-power bus powered USB configurations. --UHCI/OHCI/EHCI host controller compatible. --USB Bulk data transfer mode (512 byte packets in Hi-Speed mode). --Dedicated Windows DLLs available for USB to JTAG, USB to SPI, and USB to I2C applications. --+1.8V (chip core) and +3.3V I/O interfacing (+5V Tolerant). --Extended -40oC to 85oC industrial operating temperature range. --Compact 64-LD Lead Free LQFP or LQFN package. --+3.3V single supply operating voltage range. 支持的OS Windows Server 2008 R2 Windows 7 Windows 7 x64 Windows Server 2008 Windows Server 2008 x64 Windows Vista Windows Vista x64 Windows Server 2003 Windows Server 2003 x64 Windows XP Windows XP x64 Windows 2000 Windows ME Windows 98 Linux Mac OS X Mac OS 9 Mac OS 8 Windows CE.NET (Version 4.2 and greater) [x86, ARM & others] |
只有小组成员才能发言,加入小组>>
4507 浏览 0 评论
9671 浏览 0 评论
6359 浏览 0 评论
4775 浏览 1 评论
5758 浏览 0 评论
请问一下qspi mtsr引脚传输一次32bit后引脚不拉低怎么解决?
750浏览 2评论
1030浏览 2评论
12646浏览 2评论
最近UJA1023开发遇到问题了,各位大神有谁知道可以替代这颗芯片的
938浏览 1评论
1295浏览 1评论
/9
GMT+8, 2025-12-3 17:28 , Processed in 0.660386 second(s), Total 76, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
