对不起,迟到了 - 这比任何事都更重要。
请原谅我的讨价还价 - 我知道这是不必要的>我们不想发送到打印机,而是将其发送到word,acrobat> reader或其他类似的工具。 有可能吗?是的! Code Cow(嗯?是正确的,和其他人一样。如果你购买Acrobat,你会得到一个创建者,它会安装一个生成pdf文件的打印机驱动程序.Ghostscript是另一个很好的选择。我过去做的是添加Apple LaserWriter 打印机&将它连接到File:端口。结果是一个可以通过Ghostscript或任何后期脚本查看器查看的.eps文件,以及一个可以使用Copy / b命令发送到LaserWriter的文件。非常方便。 使用打印对象或打印机始终使用默认打印机,这有时不是您想要的。有一系列的讨论。您可以调用打印对话框,或者您可以使用DefaultPrinter.vee以编程方式设置打印机 你想要的。你可以在档案中找到所有这些东西。搜索http://www.oswegosw.com/vrf_archive/SearchVRF.htm-SHAWN----你目前订阅了vrf:r***@soco.agilent。 com订阅时发送一封空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至 “leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 以上来自于谷歌翻译 以下为原文 Sorry for late - this is more of a test than anything. Please excuse my prattling - I know it's unnecessary > Instead of sending to printer, we want to send it to word, acrobat > reader or another tool like them. Is it possible? Yes! Code Cow (huh? is right, along with everybody else. If you buy Acrobat you get a creator which installs a printer driver that makes pdf files. Ghostscript is another great choice. What I've done in the past is add an Apple LaserWriter printer & connect it to a File: port. The result is an .eps file that's viewable with Ghostscript or any post script viewer, as well as a file that you can send to a LaserWriter with a Copy /b command. Very handy. Using a print object or to printer always uses the default printer, which is sometimes not what you want. There was a whole series of discussions on this. You can invoke the Print dialog, or you can programmatically set the printer with DefaultPrinter.vee if you want. You can find all this stuff in the archive. Search at http://www.oswegosw.com/vrf_archive/SearchVRF.htm -SHAWN- --- You are currently subscribed to vrf as: r***@soco.agilent.com To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". |
1个回答
也许您可以将文件名更改为.txt然后使用acommand line prompt启动word来打开刚创建的txt文件.Regards,Gary -----原始消息-----来自:Murat COSKUN [mailto:
发送时间:2005年1月2日星期日10:35 PM:VRFS主题:[vrf] VEE programHi VRF的文档,我们希望将VEE Pro的打印程序属性用于不同的目的。而不是发送 对于打印机,我们希望将它发送到word,acrobat reader或其他类似工具。 可能吗? 如果是的话,请你指教。我会将此属性用于文档目的。 最好的问候Murat COSKUN ################################################## ####################### Dikkat:Bu elektronik posta mesaji kisisel ve ozeldir。 Eger size gonderilmediyse lutfen gondericiyi bilgilendirip mesaji siliniz。 Firmamiza gelen ve giden mesajlar virus taramasindan gecirilmekte,guvenlik nedeni ile kontrol edilerek saklanmaktadir。 Mesajdaki gorusler ve bakis acisi gondericiye ait olup Aselsan A.S. resmi gorusu olmak zorunda degildir。############################################ ##########################注意:此电子邮件具有特权和机密性。 如果您不是预期的收件人,请删除该邮件并通知发件人。 出于运营原因并根据合法的商业惯例监控进出公司的电子邮件。 所呈现的任何观点或意见仅为作者的观点或意见,并不一定代表公司的观点。############################ ##########################################bç®·&安培;vÚvHNnljzwnV [Xj z {d {nljzwnV [zÙ²ÛμrvgÚ†+ j)j)W!wvØ™xzwj z~ +Â'ÖŠW---您目前订阅的是vrf:r***@soco.agilent.com要订阅发送一个 空白电子邮件至“join-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件, 发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 以上来自于谷歌翻译 以下为原文 Maybe you could change the file name to .txt and then launch word using a command line prompt to open the txt file that you just created. Regards, Gary -----Original Message----- From: Murat COSKUN [mailto:mcoskun@aselsan.com.tr] Sent: Sunday, January 02, 2005 10:35 PM To: VRF Subject: [vrf] Documentation of VEE program Hi VRF, We want to use print program property of VEE Pro for a different purpose. Instead of sending to printer, we want to send it to word, acrobat reader or another tool like them. Is it possible? If yes, could you please advice me. I will use this property for documentation purposes. Best regards Murat COSKUN ###################################################################### Dikkat: Bu elektronik posta mesaji kisisel ve ozeldir. Eger size gonderilmediyse lutfen gondericiyi bilgilendirip mesaji siliniz. Firmamiza gelen ve giden mesajlar virus taramasindan gecirilmekte, guvenlik nedeni ile kontrol edilerek saklanmaktadir. Mesajdaki gorusler ve bakis acisi gondericiye ait olup Aselsan A.S. resmi gorusu olmak zorunda degildir. ###################################################################### Attention: This e-mail message is privileged and confidential. If you are not the intended recipient please delete the message and notify the sender. E-mails to and from the company are monitored for operational reasons and in accordance with lawful business practices. Any views or opinions presented are solely those of the author and do not necessarily represent the views of the company. ###################################################################### bç®·&vÚvHNnljzwnV[Xj z{d{nljzwnV[zÙ²ÛµrvgÚ†+j) j)W!wv Ø™xzwj z~+´֊W --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". |
只有小组成员才能发言,加入小组>>
1213 浏览 0 评论
2344 浏览 1 评论
2147 浏览 1 评论
2017 浏览 5 评论
2897 浏览 3 评论
949浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
691浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
793浏览 0评论
1213浏览 0评论
GMT+8, 2024-11-17 19:10 , Processed in 1.311358 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
