电子发烧友论坛|
是否可以预先定位XY轨迹的标记?我有一个程序,操作员手动将标记放在XY轨迹上然后点击一个按钮,根据标记的位置进行一些计算。
重新显示XY跟踪,但标记重新出现在默认位置。 在重新显示跟踪之前,是否可以将标记显示在操作员放置的相同位置? 以上来自于谷歌翻译 以下为原文 Is it possible to preposition the markers of a XY Trace?I have a program where the operator manually places the markers on the XY Trace then hits a button that does some calculations based on the position of the of the markers. The XY Trace is redisplayed but the markers reappear in a default position. Is it possible to have the markers appear in the same location the operator placed them prior to the redisplay of the trace? John---You are currently subscribed to vrf as: r***@soco.agilent.comTo subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
4个回答
Hello all, Well, it's nice to see someone else have the same problem as I had, several months ago.In that situation, I was reading using the STR in several transactions. When all the transactions were in the same Direct I/O box, everything worked correctly.When I separated them into different I/O boxes I got problems. I was reading characters without a CR/LF in the batch (big strings of ascii data). My conclusion: the read str reads 1024 characters (as stated below) and buffers them up. If you pick out less than 1024, the buffer is still there for the next transaction, so no harm. But, if you go to a different transaction box, the buffer must be cleared, so your next read picks up the 1025th character. I completely agree with Warren: Read Str == bad thing JoelFrom: Kjeld Alexander [mailto:k.alexander@get2net.dk] Sent: Thursday, September 22, 2005 1:54 AMTo: VRFSubject: Re: [vrf] hhhmmmmmmThanks Warren I needed that ! Thinking I was going mad ! I will wait 24 hour to see what others have to say. Kjeld ----- Original Message ----- From: Pickles, Warren To: VRF Sent: Thursday, September 22, 2005 9:40 AM Subject: RE: [vrf] hhhmmmmmm Kjeld, I see what you mean. Defintely something iffy going on. Try it with C:WINDOWSMedia ada.wav (because chances are we all have that one). Now b, c, d show the 5th, 6th, 7th bytes but e shows something else altogether. Once again, replacing READ TEXT with READ CHAR fixes it. I think it's one for Agilent. Regards, Warren -----Original Message-----From: Kjeld Alexander [mailto:k.alexander@get2net.dk]Sent: 22 September 2005 07:52To: VRFSubject: Fw: [vrf] hhhmmmmmm Hi guys, Nobody comment on this !!!!!!!! >>Data on b,c,d and e are (Probed) 84,90,153 and 0, it indicate that only 4 byte are read. I still do not see any reason why it should go wrong As I see it , having the correct data on b,c,d and e indicate that only 4 byte are read in the first READ transaction. If not, what am I missing ??????? Please explain attached ----- Original Message ----- From: Pickles, Warren To: VRF Sent: Wednesday, September 21, 2005 11:39 AM Subject: RE: [vrf] hhhmmmmmm Kjeld, If you're trying to read WAV files why not try Georg Nied's program posted a few years ago. Search the archive for "WAV File Library". Regarding your question, I agree it looks like the two displays should match. But does "READ TEXT X STR MAXFW:4" read only 4 bytes? Might it not read until it gets "
", or something like that? Try changing that to "READ BINARY X BYTE ARRAY:4". Bet it works. Alternatively "READ TEXT X CHAR:4" ought to work as well. Regards, Warren -----Original Message-----From: Kjeld Alexander [mailto:k.alexander@get2net.dk]Sent: 21 September 2005 10:15To: VRFSubject: [vrf] hhhmmmmmm Hi, Can anyone tell what is wrong with this "picture" ! Should'nt there be a relationship between data in the to displays. (besides the first 8 byte ) Also the file size are different 10050140 comp. to 8+100+10049015 = 10049123 File size seems to have an influence Best regards Kjeld Alexander--- You are currently subscribed to vrf as: Warren.Pickles@tycoelectronics.com To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". --- You are currently subscribed to vrf as: k.alexander@get2net.dk To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". --- You are currently subscribed to vrf as: k.alexander@get2net.dk To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". --- You are currently subscribed to vrf as: Warren.Pickles@tycoelectronics.com To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". --- You are currently subscribed to vrf as: k.alexander@get2net.dk To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". --- You are currently subscribed to vrf as: joel_dunsmore@agilent.com To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". ---You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
重新显示XY跟踪,但标记重新出现在默认位置。 在重新显示跟踪之前,是否可以将标记显示在操作员放置的相同位置?John ---您目前订阅vrf为:r***@soco.agilent.com要订阅,请发送空白电子邮件至“ join-vrf@it.lists.it.agilent.com“。要取消订阅,请发送一封空白电子邮件至”leave-vrf@it.lists.it.agilent.com“。要发送邮件到此邮件列表,请发送电子邮件至”vrf @“ agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Is it possible to preposition the markers of a XY Trace?I have a program where the operator manually places the markers on the XY Trace then hits a button that does some calculations based on the position of the of the markers. The XY Trace is redisplayed but the markers reappear in a default position. Is it possible to have the markers appear in the same location the operator placed them prior to the redisplay of the trace? John---You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]To subscribe send a blank email to "join-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 10:05 , Processed in 0.699979 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1690
