电子发烧友论坛|
嗨,我想知道是否有可能从Visual Studio创建一个控制GUI,然后可以与VEE接口,可以说发布一个VEE程序,作为一个DLL,它允许它直接与.NET接口。
我知道你现在可以将.NET对象添加到VEE中,但我仍然认为VEE的外观看起来有点过时了。任何帮助都会非常感激。杰克 以上来自于谷歌翻译 以下为原文 Hi Board, I was wondering if it was possible to create a control GUI from Visual Studio, which can then interface with VEE, is it possible to say publish a VEE program, as a DLL, which would allow it interface directly with .NET. I am aware you can add .NET objects into VEE now, but I still think the look and feel of VEE looks a bit dated. Any Help would be greatly appreciated. Jack |
4个回答
您无法从VEE创建DLL。
您可以做的是利用VEE的ActiveX Automation Server。 这允许您从任何自动化客户端调用VEE UserFunctions(以及VEE程序的Main)。 VB,C#和VEE附带的一些其他语言都有例子。 以上来自于谷歌翻译 以下为原文 You cannot create a DLL from VEE. What you can do is to take advantage of VEE's ActiveX Automation Server. This allows you to call VEE UserFunctions (and also Main of a VEE program) from any Automation client. There are examples for VB, C# and a few other languages included with VEE. |
除了VB6之外,Threre也是一个C#考试。将您的.NET项目的COM引用添加到Agilent VEE Callable VEE服务器。
就像任何其他参考一样。 我希望你找到了VEE服务器及其对象模型的帮助文件? 我认为它非常完整。 帮助文件中的VB6示例对于VB.NET也应该是有用的,代码的“VEE部分”将是相同的。 以上来自于谷歌翻译 以下为原文 Threre is an C# examle as well besides VB6 etc. Add a COM reference to your.NET project to the Agilent VEE Callable VEE server. Just as any other reference. I hope you have found the help-file for the VEE server and its object model? It is quite complete I think. The VB6 example in the help-file should be useful also for VB.NET, the 'VEE part' of the code will be the same. |
嗨,我还没有找到C#示例,这是在以后的版本中发布的吗?我只能看到VB6,vbScript和Visual C ++。杰克
以上来自于谷歌翻译 以下为原文 Hi I have not been able to find the C# example, is this came out in a later release? I can only see VB6, vbScript and Visual C++. Jack |
感谢这个gojoh,查看代码它看起来相当简单。定义你的程序位置和你想要访问的所有功能。你知道是否有可能运行一个vee程序而不必显示任何类型的
GUI,以便它有效地作为我的VB.NET应用程序的后台进程运行,我正计划为此任务开发?最好的RegardsJack 以上来自于谷歌翻译 以下为原文 Thanks for this gojoh, looking at the code it looks a fairly straightforward procedure. Of defining your program location and all the functions that you wish to access. Do you know if it is possible to run a vee program without having to display any sort of GUI, so that it is effectively running as a background process to my VB.NET application which I am planning on developing for this task? Best Regards Jack |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 22:03 , Processed in 0.864337 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1941
