Dear Flora Wang :
我用PPS生成的代码写入AIC3254只听到杂音,没有声音输入,请您帮我看看哪里出了问题。
下面的配置写入预置模式就有声音输入输出,写入PPS生成的minDsp代码就只能听到一点杂音。
reg_value REG_Section_program[] = [
[ 0,0x00],
// # reg[ 0][ 1] = 0x01 ; Initialize the device through software reset
[ 1,0x01],
[ 0,0x00],
// 0x00 16bit, I2S, BCLK is input to the device
[ 27,0x00],
[ 0,0x01],
// # reg[ 1][ 2] = 0xa9 ; Power up AVDD LDO
[ 2,0x01],
// # reg[ 1][ 1] = 0x08 ; Disable weak AVDD to DVDD connection
[ 1,0x08],
// # reg[ 1][ 2] = 0xa1 ; Enable Master Analog Power Control, AVDD LDO Powered
[ 2,0x01],
// # reg[ 1][ 71] = 0x32 ; Set the input power-up time to 3.1ms
[ 71,0x32],
// # reg[ 1][123] = 0x05 ; Force REF charging time to 40ms
[123,0x01],
// miniDSP_D programming mode
[255,0x00],
[255,0x01],
[ 0,0x00],
// # reg[ 0][ 60] = 0x00 ; Use miniDSP_D for signal processing
[ 60,0x00],
// # reg[ 0][ 61] = 0x00 ; Use miniDSP_A for signal processing
[ 61,0x00],
// # reg[ 0][ 17] = 0x08 ; 8x Interpolation
[ 17,0x08],
// # reg[ 0][ 23] = 0x04 ; 4x Decimation
[ 23,0x04],
[ 15,0x18],
[ 16,0x00],
[ 21,0x03],
[ 22,0x88],
//miniDSP 预置模式
[ 0,0x00],
[ 60,0x02],
[ 0,0x2c],
[ 1,0x04],
[ 0,0x08],
// # reg[ 8][ 1] = 0x04 ; adaptive mode for ADC
[ 1,0x04],
[ 0,0x00],
// # reg[ 0][ 5] = 0x94 ; // PLL is powered up, P=1, R=4
[ 5,0x94],
// # reg[ 0][ 6] = 0x2A ;J=42
[ 6,0x2A],
// # reg[ 0][ 7] = 0x00 ; D=0000 (MSB)
[ 7,0x00],
// # reg[ 0][ 8] = 0x00 ; D=0000 (LSB)
[ 8,0x00],
// # reg[ 0][ 4] = 0x03 ; PLL Clock is CODEC_CLKIN
[ 4,0x03],
// # reg[ 0][254] = 0x0a ; Delay 10ms for PLL to lock
[254,0x0A],
// # reg[ 0][ 12] = 0x82 ; MDAC = 14, divider powered on
[ 12,0x8E],
// # reg[ 0][ 13] = 0x01 ; DOSR = 384(MSB)
[ 13,0x01],
// # reg[ 0][ 14] = 0x80 ; DOSR = 384(LSB)
[ 14,0x80],
// # reg[ 0][ 18] = 0x82 ; // NADC divider powered up, NADC = 2
[ 18,0x82],
// # reg[ 0][ 19] = 0x95 ; MADC = 21, divider powered on
[ 19,0x95],
// # reg[ 0][ 20] = 0x00 ; AOSR = 256
[ 20,0x00],
// # reg[ 0][ 11] = 0x8E ; NDAC = 2, divider powered on
[ 11,0x82],
//clk output set
[ 25,0x04], // DAC_CLK
[ 26,0x81],
[ 55,0x06], // MOSI OUTPUT CLK
[ 0,0x01],
// # reg[ 1][ 51] = 0x40 ; // MICBIAS powered up ON Board Mic
[ 51,0x40],
// # reg[ 1][ 52] = 0x00 ; not routed to Left MICPGA
[ 52,0x00],
// # reg[ 1][ 54] = 0x04 ; IN3R is routed to Left MICPGA with 10k resistance
[ 54,0x04],
// # reg[ 1][ 55] = 0x04 ; IN3R is routed to Right MICPGA with 10k resistance
[ 55,0x54],
// # reg[ 1][ 57] = 0x40 ; CM is routed to Right MICPGA via CM1R with 10k resistance
[ 57,0x40],
// IN3R input is weakly driven to common mode.
[ 58,0x04],
// # reg[ 1][ 59] = 0x5E ; //make channel gain 0dB, since 20K input //impedance is used single ended
[ 59,0x00],
// # reg[ 1][ 60] = 0x00 ; Enable MicPGA_R Gain Control, 0dB
[ 60,0x00],
[ 83,0x68],
[ 84,0x68],
[ 0,0x00],
// # reg[ 0][ 81] = 0xc0 ; Power up LADC/RADC
[ 81,0xC0],
// # reg[ 0][ 82] = 0x00 ; Unmute LADC/RADC
[ 82,0x00],
[ 0,0x01],
// # reg[ 1][ 20] = 0x25 ; De-pop: 5 time constants, 6k resistance
[ 20,0x25],
// # reg[ 1][ 12] = 0x08 ; Route LDAC to HPL
[ 12,0x08],
// # reg[ 1][ 13] = 0x08 ; Route RDAC to HPR
[ 13,0x08],
// # reg[ 1][ 14] = 0x08 ; Route LDAC to LOL
[ 14,0x08],
// # reg[ 1][ 15] = 0x08 ; Route LDAC to LOR
[ 15,0x08],
[ 9,0x3C],
[ 0,0x01],
// # reg[ 1][ 16] = 0x00 ; Unmute HPL driver, 27dB Gain
[ 16,0x1B],
// # reg[ 1][ 17] = 0x00 ; Unmute HPR driver, 27dB Gain
[ 17,0x1B],
// # reg[ 1][ 18] = 0x00 ; Unmute LOL driver, 28dB Gain
[ 18,0x1c],
// # reg[ 1][ 19] = 0x00 ; Unmute LOR driver, 28dB Gain
[ 19,0x1c],
// # reg[ 1][ 20] = 0x25 ; // Headphone ramps power up time is determined with 6k resistance,
[ 0,0x00],
[ 61,0x02],
[ 0,0x00],
// # Digital Volume Control = 64.0dB
[ 65,0x93],
[ 66,0x93],
[ 0,0x00],
// # reg[ 0][ 63] = 0xd4 ; Power up LDAC/RDAC w/ soft stepping
[ 63,0xD6],
[ 64,0x00],
[ 0,0x00],
[ 86,0x20],
// # reg[0][87] = 254
[ 87,0xFE],
// # reg[0][88] = 0
[ 88,0x00],
// # reg[0][89] = 104
[ 89,0x68],
// # reg[0][90] = 168
[ 90,0xA8],
// # reg[0][91] = 6
[ 91,0x06],
// # reg[0][92] = 0
[ 92,0x00],
2019-8-15 11:11:08
举报
