电子发烧友论坛|
除了检测信用卡大小标签外,它能否可靠地检测出较小的标签,例如四分之一大小的标签?是否有误报警问题,如附近有意外的金属板或微波炉等外部无线电源,高功率接入点等?谢谢。
以上来自于谷歌翻译 以下为原文
3个回答
嗨约瑟夫,
我相信所有的读者都准备好检测一个四分之一信用卡形状因子的标签,其天线根据NFC / RFID标准/标准调整。你指的是哪种类型的Reader / Tag? 您的第二点是有点通用的,请您澄清您的请求和设置? 谢谢 以上来自于谷歌翻译 以下为原文 Hi Joseph, I beleive that all the readers are ready to detect a tag with a quarter size of a credit card form factor with an antenna tuned according to NFC/RFID standart/norma. Which type of pair Reader /Tag do you refer to? You second point is a bit generic can you please clarify your request and your setup? Thank |
彼得,嗨,
谢谢回复。我有ST25R3911B-DISCO和X-NUCLEO-NFC05A1板。我将尝试不同的设置。 GUI也很有用。 以上来自于谷歌翻译 以下为原文 Hi Peter, Thanks for the reply. I have the ST25R3911B-DISCO and X-NUCLEO-NFC05A1 boards. I will experiment with different setup. The GUI is also useful. |
嗨约瑟夫,
ST25R3911B具有一些内置功能,可以克服唤醒模式下的环境变化。 例如,自动平均可用于过滤缓慢变化的影响,如温度变化或湿度变化。只会识别标签或手机失谐等“快速”变化。 增量窗口是另一种设置,可以更改唤醒功能的灵敏度。它允许设置参考值周围的范围,不触发中断。 中断也可以由在相同频率范围内工作的另一个设备触发。 BLE或WIFI器件的频率差异太大,无法在IC的输入引脚上产生幅度变化。同时主动发出13.56MHz的HF场的电话将干扰感应唤醒脉冲,因此当在更近的位置激活时也会触发中断。 BR Travis 以上来自于谷歌翻译 以下为原文 Hi Joseph, The ST25R3911B has some features build in to overcome environmental changes in wake-up mode. Automatic Averaging for example can be used to filter slow changing effects like temperature change or changing humidity. Only 'fast' changes like detuning by a tag or phone will be recognized. The delta-window is another setting that changes the sensitivity of the wake-up feature. It allows to set a range around the reference value, where no interrupt is triggered. An interrupt can also be triggered by another device which operates at the same frequency range. A BLE or WIFI device is too different in terms of frequency to generate an amplitude change on the IC's input pins. A phone which also sends out actively an HF field @ 13.56MHz will interfere with the inductive wake-up pulse and therefore also trigger an interrupt when being active in closer proximity. BR Travis |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
663浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 13:18 , Processed in 1.010942 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3440
