我有一个1017运行在一个DSPIC33 EP。我有一个随机的爆震/失火在马达开始大约1000转。我不知道怎么形容它,它就像是马达“失灵”,然后又“起火”,它会产生一点敲打或爆裂。我不太理解应用程序说明中设置的许多常数,但我认为这可能与我的问题有关:其他一些线程说你必须看后面电动势到霍尔定位。嗯,我正在看,我还不知道零相的情况。从哪个霍尔效应测量,从上升、下降、中心等测量吗?测量到哪个BEMF/驱动电压波形,测量到ZC,峰值(+/-),以及单位是什么?65536是完整的革命吗(在65535/6处如此显示),所以如果我的U-Hall上升到ZC,U-V BEMF上升到60度,我会放65536/60,并且哪个方向,它是大厅的bemf还是bemf到hall(即最后一个例子实际上是65536-65536/60)?
以上来自于百度翻译 以下为原文 I have AN1017 running on a dspic33ep. I have a random knock / misfire in the motor that starts at about 1000rpm. I don't know how else to describe it, it's like the motor "misses" and then "fires" and it produces a little knock or pop. I don't really understand a lot of the constants set up in the app note, but i think this might be related to my issue: // These Phase values represent the base Phase value of the sinewave for each one of the sectors (each sector is a translation of the hall effect sensors reading #define PHASE_ZERO 0 #define PHASE_ONE ((PHASE_ZERO + 65536/6) % 65536) #define PHASE_TWO ((PHASE_ONE + 65536/6) % 65536) #define PHASE_THREE ((PHASE_TWO + 65536/6) % 65536) #define PHASE_FOUR ((PHASE_THREE + 65536/6) % 65536) #define PHASE_FIVE ((PHASE_FOUR + 65536/6) % 65536) Some of the other threads said you had to look at the back emf to hall positioning. Well, I'm looking at it, and I still don't know what goes in phase zero. Which hall effect do i measure from, do i measure from rise, fall, center,etc. Which BEMF / drive voltage waveform do i measure to, and do i measure to ZC, peak (+/-), and what are the units? Is 65536 a full revolution (appears so byt the 65535/6), so if my rise of U-Hall to ZC rise of U-V BEMF is 60degrees, I would put 65536/60, and which direction, is it hall to bemf or bemf to hall (ie would that last example actually be 65536-65536/60? |
1个回答
由于在另一个帖子上访问被拒绝而忽略测试错误(忽略此)。
以上来自于百度翻译 以下为原文 Test post due to Access denied error on another post (ignore this). |
只有小组成员才能发言,加入小组>>
5079 浏览 9 评论
1954 浏览 8 评论
1888 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3115 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2186 浏览 5 评论
633浏览 1评论
506浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
370浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
535浏览 0评论
440浏览 0评论
GMT+8, 2024-9-29 04:59 , Processed in 1.245438 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
