电子发烧友论坛|
嗨,
我需要知道CPG196封装(Spartan-6 LX16)可接受的最大压力。 我必须弄清楚压缩导热垫对包装施加的压力是否正常。 我已经发现了u112.pdf,其中列出了所列Xilinx封装的压力处理能力为每球最大5.0g。 但是我没有在列表中找到CPG196。 此约束是否也适用于CPG196? 谢谢, 雅尼克。 以上来自于谷歌翻译 以下为原文 Hi, I need to know the maximum pressure acceptable for a CPG196 package (Spartan-6 LX16). I must find out if the pressure applied on the package by a compressed thermal pad will be OK. I have found ug112.pdf where it is stated that the pressure handling capacity of listed Xilinx packages is 5.0g per ball maximum. However I don't find CPG196 in the list. Does this constraint apply to CPG196 as well? Thank you, Yannick. |
4个回答
Y,
包装是非密封的,因此压力将相等。 空隙中残留的任何残留气体都很小(存在于基板中)。 您尝试设计的环境是什么? Austin Lesea主要工程师Xilinx San Jose 以上来自于谷歌翻译 以下为原文 y, The package is non-hermetic, so the pressure will equalize. Any residual trapped gasses in voids is vanishingly small (present in the substrate). What environment are you attempting to design for? Austin Lesea Principal Engineer Xilinx San Jose |
嗨奥斯汀,
谢谢您的回答。 我不关心环境压力,但是在包装顶部施加直接机械压力。 FPGA将安装在安装在相机内的PCB上。 我想放一个导热垫来填补FPGA和机箱背面之间的空隙。 导热垫将被压缩,因此将在CPG196封装上施加恒定压力。 我想确保不超过包装压力处理能力。 对于其他Xilinx封装,每个球CPG196手动5g,还是不同? 谢谢, 雅尼克。 以上来自于谷歌翻译 以下为原文 Hi Austin, Thank you for your answer. I'm not concerned about environmental pressure, but with direct mechanical pressure applied on top of the package. The FPGA will be mounted on a PCB installed inside a camera. I want to put a thermal pad to fill the gap between the FPGA and the back of the enclosure. The thermal pad will be compressed and will therefore be applying constant pressure on the CPG196 package. I want to make sure I don't exceed the package pressure handling capability. Will CPG196 handle 5g per ball as for other Xilinx packages, or is it different? Thanks, Yannick. |
CPG是BGA封装(ug112的第17页),BGA封装的压力处理能力是5g /球(ug112的第119页)。
-------------------------------------------------- ----------------------------别忘了回复,给予kudo并接受为解决方案--------- -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 CPG is BGA package (page 17 of ug112) and pressure handling capacity of BGA package is 5g/ball (page 119 of ug112). ------------------------------------------------------------------------------ Don't forget to reply, give kudo and accept as solution ------------------------------------------------------------------------------ |
谢谢您的回答。
关于这个话题我还有另一个问题; 由于焊盘尚未压缩,因此散热垫通常会在安装时在芯片上施加更大的压力。 随着热材料的扩散,压力将减小。 在安装过程中,安全时间是否会超过5g /球,但在此之后永远保持在5g /球之内? 我很担心,因为这5g / ballmax似乎是一个非常有限的因素。 我相信大多数人通常不会关心这一点,但是如果你开始使用热界面数据表中的压缩/力数来进行数学计算,很多人会意识到它们超过5g /球。 世界上任何使用Xilinx BGA上的导热垫的人都会遇到故障,这听起来不对,所以我想知道5g / ballnumber是否真的正确......? 谢谢, 雅尼克。 以上来自于谷歌翻译 以下为原文 Thank you for your answer. I have another question on this topic; Thermal pads will typically apply more pressure on the chip at the moment of installation because the pad is not yet compressed. The pressure will diminish as the thermal material spreads around. Is it safe to exceed 5g/ball for a few seconds during installation, but remain within 5g/ball forever after? I am concerned because this 5g/ball max seems like a very constraining factor. I believe most people don't usually care about this, but if you start doing the maths using compression/force numbers from thermal interface datasheets, many would realize they're exceeding 5g/ball. It doesn't sound right that anyone in the world who uses a thermal pad on a Xilinx BGA would encounter failures so I wonder if the 5g/ball number is truly right...? Thanks, Yannick. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 16:02 , Processed in 0.932151 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1583
